Old 02-28-2009, 08:12 PM   #19
BrazdonW
What kind of car is that?
Drives: Yaris 3d liftback
explain how it works please
To put it simply it connects at the top of the rear suspention bracing it when the car takes a turn
It helps distribute weight more evenly
Old 02-28-2009, 10:08 PM   #20
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
So in your opinion i'd be better off spending that money on springs instead? I'm never going to race my Yaris. I think stock springs are too soft.
Yes, springs are always first when modifying suspension.
Old 02-28-2009, 10:44 PM   #21
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
Get a quick-release tab for your car, and you can remove the rear STB whenever easily!
anonymous user is offline   Reply With Quote
Old 02-28-2009, 11:07 PM   #22
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
well personally, and it is what i did do, lower it first (df210s). then i did the trd rear anti-sway,then front UR strut bar, now the miracle bar. i noticed a handling difference in a positive way with every one of those mods. IMO as long as the strut bar is SOLID with no joints, it will be functional. i wont get a rear bar though as i have the miracle bar.
mikenacarato is offline   Reply With Quote
Old 03-01-2009, 12:17 AM   #23
Tamago
Tamago's Avatar
Drives: ZZW30
what weight is it distributing, considering SHOCKS do not support weight of the vehicle?
Old 03-01-2009, 11:20 AM   #24
BrazdonW
the weight being thrown around
the shocks do take weight being added threw a turn, as do the springs which is why they are all a part of the same cluster and compress together
if your shocks are blown your ride is horrible and you hear loud slams when you hit pot holes or go over speed bumps if it doesn't support any weight why would that happen?
Old 03-01-2009, 11:45 AM   #25
Tamago
Tamago's Avatar
Drives: ZZW30
the shocks are NOT the same part of the "cluster" in the rear, as you say.
have you ever pushed on a shock? it resists your pressure. but it won't support weight.
if i carry a metal bucket full of bolts in the back of my car, and drive over bumps, it makes a loud slamming noise too.. does that mean that the bucket of bolts is supporting the weight of my car?
Old 03-01-2009, 01:24 PM   #26
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
[QUOTE=Tamago;255331]the shocks are NOT the same part of the "cluster" in the rear, as you say.
Shocks do transmit force. This will affect frame or strut rigidity.
Old 03-01-2009, 01:26 PM   #27
Tamago
Tamago's Avatar
Drives: ZZW30
yes, they do transmit FORCE. but in the case of the yaris, they transmit force in one direction. STRAIGHT UP. so attaching anything to the shock that doesn't resist this STRAIGHT UP FORCE (not weight) is useless, and should be considered a "looks-only" mod
guys.. just accept the fact that your spaghetti bar is mostly for looks. .
Old 03-01-2009, 02:04 PM   #28
BrazdonW
so you are saying that it does not resist body flex or distribute the weight/FORCE more evenly?
Old 03-01-2009, 02:10 PM   #29
Tamago
Tamago's Avatar
Drives: ZZW30
well let's see
it attaches to the shock.. in one place... only
the shock has a rubber grommet between it and the body
the bar pivots on both ends...
so no. it can't distribute force.. it bends like spaghetti when forces act on it.
Old 03-01-2009, 02:55 PM   #30
SailDesign
Drives: .
well let's see
Hmmm... In my book that says it can apply force, but cannot apply moment.
Old 03-01-2009, 03:16 PM   #31
Tamago
Tamago's Avatar
Drives: ZZW30
which means it's useless
have we finally come full circle here?
Old 03-01-2009, 04:21 PM   #32
YAR1S
YAR1S's Avatar
My car tends to wobble and sway on the highway at high speeds.... I was told putting a front strut bar on would be a good investment..... is this true and what could I get for a good price and where?
Thanks a lot.
ps: suspension is stock.
-Jen <3
Old 03-01-2009, 04:33 PM   #33
Benggolf2
Benggolf2's Avatar
...guys.. just accept the fact that your spaghetti bar is mostly for looks. .
This is hilarious! Thanks for the laugh Tamago. BTW, are you Japanese or you happen to like "Tamago"?
Benggolf2
Old 03-01-2009, 04:43 PM   #34
Tamago
Tamago's Avatar
Drives: ZZW30
Thanks a lot.
better tires will help the wobble more
but front upper strut bars are cheap, i say pick one up
Old 03-01-2009, 04:44 PM   #35
Tamago
Tamago's Avatar
Drives: ZZW30
the xA is white.. nicknamed the egg. tamago = egg lol
Old 03-01-2009, 04:46 PM   #36
Black Yaris
der Zeck
Black Yaris's Avatar
I added a front strut bar to the toaster, it was super cheep, and it looks better than it preforms
my $50 investment in hub adapters/spacers yielded a much better performance gain... that and awesome tires
Tanabe Front Strut Bar Benggolf2 Performance Modifications 57 08-15-2014 03:41 AM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 07:52 PM
Do you HAVE to remove the wheels to install strut bar? Yawesh Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 02-10-2009 03:35 PM
Installed the Tanabe Strut bar but had to remove my ground wire kit.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-01-2007 02:56 PM
C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 01-10-2007 07:53 PM
