Old 03-04-2009, 09:52 AM   #1
hatchbackkid82
Drives: .
3rd Gear grind
I just started to develop a 3rd gear grind. I don't know if anyone else has experienced this. Shifting from 2nd to 3rd, it will never be hard to get into gear, but on occasion there is a slight grind. Has anyone else experienced this? The other thing is does anyone know if having an intake on there will void the entire warranty?
Old 03-04-2009, 10:10 AM   #2
hatchbackkid82
Drives: .
I don't rough shift. Always make sure the clutch is all the way down when shift. It's driving me nuts. Even if i shift slow at a certain speed it will grind. The grinding sound is faint but still audible, but i can feel it through the shifter. It's like something is spinning in there
Old 03-04-2009, 10:13 AM   #3
hatchbackkid82
Drives: .
Well looks like i'm back under the hood tonight. Just put my intake on Sunday...this blows
Old 03-04-2009, 10:22 AM   #4
hatchbackkid82
Drives: .
I hope your right PK. I'm dreading having to shell out money. I'm out of the bumper to bumper warranty. Just have the powertrain warranty, i know they will tryto figure out a way to suck money out of me
Old 03-04-2009, 10:33 AM   #5
at3GG
at3GG's Avatar
Drives: 07 metmet LB
mine does the same downshifting from 2 to 3 sometimes, even with the clutch fully depressed and shifting sloowly, but only if i dont let the rpm drop. Fait but still there. Also, an intake will NOT void your entire warranty. If they KNOW that you installed an intake, it will void the stock airbox and intake system portion of the watrranty and nothing. This is straight from the mouth of my Toyota Dealer. Good Luck!
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 03-04-2009, 10:45 AM   #6
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
ahh the old weak synchro problem..
what gear oil are you using?
Originally Posted by xnamerxx
you nailed it sir.
Old 03-04-2009, 10:49 AM   #7
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I'd check your clutch hydraulics. If the slave has a slight leak or the fluid is old or you've somehow gotten a little air in the system, the clutch may not be releasing properly. What you describe is one of the first symptoms.
Old 03-04-2009, 11:00 AM   #8
hatchbackkid82
Drives: .
75w-90 Mobil 1 synthetic If i remember right. It's a grind for sure, doesn't happen all the time. It definitely happens at high rpm all the time. Shift from 1st to 2nd is fine, sfifting 2nd to 3rd, pressing clutch all the way still grinds. I can't shift from 2nd to 3rd in one smooth motion at high rpm without a grind. Actually have to wait for a second or so.
Old 03-04-2009, 11:01 AM   #9
Tamago
Tamago's Avatar
Drives: ZZW30
there's your problem
get rid of that mobil1
that's a synchro destroyer (ask me how i know)
you nailed it sir.
Old 03-04-2009, 11:06 AM   #10
hatchbackkid82
Drives: .
Ummmm....... lol.... so how do you know? You screwed your tranny up?
Old 03-04-2009, 11:07 AM   #11
hatchbackkid82
Drives: .
isn't 75w-90 the correct viscosity or weight?
Old 03-04-2009, 11:23 AM   #12
Tamago
Tamago's Avatar
Drives: ZZW30
it is the correct weight
but mobil1 is synchro death.
you nailed it sir.
Old 03-04-2009, 11:24 AM   #13
hatchbackkid82
Drives: .
Ok any recomendations on what other gear oil to use.
Old 03-04-2009, 11:26 AM   #14
Tamago
Tamago's Avatar
Drives: ZZW30
people here use Redline MT90
i use plain old valvoline
you nailed it sir.
Old 03-04-2009, 11:27 AM   #15
hatchbackkid82
Drives: .
Anyone use Lucas gear oil is that any better? I'm taking my car up to the dealership, to see what they say or what they can do, just want to be on the safe side. But i'll make sure to drain that Mobil 1 asap.
Old 03-04-2009, 11:30 AM   #16
Tamago
Tamago's Avatar
Drives: ZZW30
the dealership is gonna say to buy "toyota" oil (lol)
you nailed it sir.
Old 03-04-2009, 11:50 AM   #17
Tamago
Tamago's Avatar
Drives: ZZW30
what is "toyota" oil? hatchback did you switch the oil from OEM?
it's whatever they decide to throw their label on
i'm not gonna say what brand because i'm probably wrong anyway
i'm not the oil expert around here, there's like 53445 experts.
you nailed it sir.
Old 03-04-2009, 11:51 AM   #18
MUSKOKA800
MUSKOKA800's Avatar
Powertrain warranty should cover transmission problems.
Yaris 2007- How to Restart Multimode gear? ronen DIY / Maintenance / Service 1 02-21-2009 06:09 PM
Auto 'extra' gear? drecian General Yaris / Vitz Discussion 2 08-25-2007 09:01 AM
High RPM's in 3rd. Need some opinions falkor_99 General Yaris / Vitz Discussion 3 05-16-2007 09:23 PM
2nd to 3rd gear shift (manual tranny) tekmoe General Yaris / Vitz Discussion 13 12-11-2006 07:27 PM
clicking into first gear tekmoe General Yaris / Vitz Discussion 9 11-01-2006 03:44 AM
