Old 03-18-2009, 02:10 AM   #1
wildmongoose26
wildmongoose26's Avatar
Drives: 09 5dr Yaris
16x7 +38mm front, 16x8 +0 rear WILL IT FIT?
wanting new wheels, and i was informed the Yaris setup is like the xb, so you need a wide wheel or low offset to flush out the rear wheels.
Just wanna know if this offset is enough to get me remotely close to flush. I dont wanna know go totally flush, or have some poke until i get coilovers. As of now im just getting the lowest Tien springs.
Thanx
Angela
Old 03-18-2009, 02:12 AM   #2
White Yaris
Broke Tuner
White Yaris's Avatar
Drives: White Yaris
Front would work but little rubbing. Rear with that offset i highly doubt it. Maybe 30 or 35+ offset would be great.
EVERYTHING YOU KNOW IS WRONG
White Yaris is offline   Reply With Quote
Old 03-18-2009, 02:25 AM   #3
wildmongoose26
what is the problem going to be? I would be using 195/50/16's to help clear with a bit of stretch.
Old 03-18-2009, 12:14 PM   #4
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
16x8 with 0 offset you will be WAY outside the fender!
A 35+ rear should give you the flush look.
OH BTW, NO the Yaris is not like the xB...!
the xB has more room....
Old 03-18-2009, 12:59 PM   #5
I have a set of wheels like that, Nilos for sale.
Old 03-18-2009, 02:10 PM   #6
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
Here is a 16x7 +33 with a 205/50 for reference...
cm07yaris is offline   Reply With Quote
Old 03-18-2009, 02:40 PM   #7
Split
Drives: 2008 Yaris Sedan
Exclamation
^ that doesn't look lik eit would rub, but from what i've read, anything less than +42mm rubs. Hrm...
Split is offline   Reply With Quote
Old 03-18-2009, 02:44 PM   #8
Nagoya_TRD.
Drives: None.
best way to find out is to measure it up. a + 0 will definitely take some good coilovers and fender modifications (rolling and maybe a pull).
Nagoya_TRD. is offline   Reply With Quote
Old 03-18-2009, 05:01 PM   #9
cm07yaris
Can't always believe what you read...it's also lowered 1.75"
Old 03-18-2009, 05:26 PM   #10
kngrsll
Apexing Egg!!
kngrsll's Avatar
now thats how a wheel should fit.
im orginally from kenosha, WI. i live down in south carolina now, been here for ten years now.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 03-18-2009, 07:12 PM   #11
cm07yaris
Also, here's a 16x7 +42 with a 205/50 up front...
Old 03-18-2009, 07:31 PM   #12
Black Yaris
der Zeck
Black Yaris's Avatar
only true for the front.... and it depends upon the tire set-up as well
I could tuck those +0 offsets' no prob!
Old 03-19-2009, 07:30 AM   #13
UKblackyari
Drives: yaris
im not sure about other setups but here is my experience. Im running +38 16x6.5 all round and i have 0 rubbing and im sitting on Tein Basics. Sorry for the pics but i dont have any from the side looking down the car.
UKblackyari is offline   Reply With Quote
Old 03-19-2009, 10:56 AM   #14
wildmongoose26
those look good, but going for a bit of a different look. More flush, maybe even a little poke, with some mildly stretched tires.
Angela
Old 03-19-2009, 02:28 PM   #15
elmo
WFO
elmo's Avatar
Drives: 2008 hb
what do you want for them and pic please
elmo is offline   Reply With Quote
Old 03-19-2009, 04:46 PM   #16
CASTREX
CASTREX's Avatar
If you are not rubbing the crap out of the inner plastic fenders with the basics....
Then you are not driving fast enough !!
Old 03-20-2009, 01:05 PM   #17
UKblackyari
Drives: yaris
ill check the tire widths one i get home, but i know there 195/40 or 45. And i have never rubbed on this setup and believe me ive done some hard cornering in it and it still does not. The only time ive ever rubbed while havening the basics on was when i went to pick up the wheels with some friends in the back
Old 03-20-2009, 02:08 PM   #18
tonyg
Drives: yaris
so you're not rubbing because your running an improper tire size for the car? That would make your whole post irrelevant. You should be running 195/50/16 for a stock diameter.
You also say you have NEVER rubbed yet in the very next sentence you say you did rub. That’s contradictory.
So basically, yes you rub even though you run an undersized tire. If you ran a proper tire size you’d probably be rubbing all over the place.
tonyg is offline   Reply With Quote
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
