Old 03-19-2009, 08:11 PM   #37
cdaddy626
Drives: 2009 Yaris
Originally Posted by DanQ View Post
Haven't been around the forum lately. Sure is alot of unrelated stuff on this tread now. Anyway, my DIY was set up for a hatchback. Something to try. Does the button on the door unlock all the doors? If it does, are you sure you tapped into that wire? This is where a sedan may be different than a LB.
I too have a hatchback, and yes the button on door unlocks all doors. Not sure if I am on the right wire, I tapped in in accordance with your DIY and CTScott's addition with using the green unlock wire.
cdaddy626 is offline   Reply With Quote
Old 03-19-2009, 08:28 PM   #38
It sounds like there may be something wrong with your module, since it doesn't seem to actually put out the double pulse. You can use the unlock wire from DanQ's DIY if you only use the remote to lock the car.
The wire that he indicates unlocks all doors with one pulse, but if someone manually locks a door with the button before exiting, you will have to use the key to open the door.
Old 06-26-2009, 11:13 AM   #39
PatrickJohnson
Drives: 2008 Yaris LB
I bought the valet kit and will be attempting this next week. I'll post results...
PatrickJohnson is offline   Reply With Quote
Old 06-26-2009, 08:58 PM   #40
Treyz
~ ambient one ~
Treyz's Avatar
All I know is that I'll be doing this install again ... sigh ... lol as well as the fog lights too!
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 06-26-2009, 10:45 PM   #41
hari
Drives: 2008 Red 2dr Yaris Hatchback
I bought the kit and did the install. Works great!
Thank you DanQ and CtScott :)
hari is offline   Reply With Quote
Old 06-30-2009, 11:49 PM   #42
PatrickJohnson
hell yeah! took me about an hour and the tutorial was great! thanks!
Old 08-05-2009, 07:39 PM   #43
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
You guys have me sold... I'm going to buy a Valet 712T and do it myself when it comes in...
RUFFSTUFF is offline   Reply With Quote
Old 08-05-2009, 09:52 PM   #44
RUFFSTUFF
Are any additional parts required to connect a remote trunk release with the Valet 712T?
Old 08-05-2009, 10:18 PM   #45
If the Sedan's trunk release lever is mechanical (like the fuel door release), then you would need a cable actuator to trigger it.
Old 08-06-2009, 10:09 PM   #46
RUFFSTUFF
Ok, thanks for the tip!
Old 08-10-2009, 03:23 PM   #47
RUFFSTUFF
The Valet 712T I ordered came in today... My 1st Yaris project awaits...
Old 08-10-2009, 09:45 PM   #48
RUFFSTUFF
Just installed the Valet 712T... What a sweet setup! Install was pretty easy... A super big thanks to DanQ and CTScott for their help. I have the double pulse setup to unlock all the doors on one push and have no issues with manual/remote locking or unlocking... you do have to hold the button for awhile to get the panic feature going though...
Old 10-23-2009, 04:25 PM   #49
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
Is it possible to install a factory keyless entry on our cars? I know the remotes are like $200
RacerFreakXXX is offline   Reply With Quote
Old 10-23-2009, 05:15 PM   #50
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
thanks for this, i will do this in the winter time when i have some spare times at work.
jamal1984 is offline   Reply With Quote
Old 10-23-2009, 08:54 PM   #51
Yes. There have been a couple of threads on it. You can purchase the remote receiver with two remotes. The part number is in one of the threads.
Old 10-28-2009, 03:53 PM   #52
RacerFreakXXX
JDM Fred
o0o, great... so that's all I need? I'm going to search for those threads
Old 12-14-2009, 01:31 AM   #53
mwalls
Drives: 2008 Yaris 4Dr Sd
Autopage RF-225 Installation.
I looked through the Yarisworld site when I joined and couldn't find all of the info I needed to add a keyless entry system to a Yaris with power windows and door locks, so I created my own web site.
Details to install a Valet 712T in an 08 varis LB. This should work for sedans as well. You can get the unit off the web for ~$40. Do the install yourself and save $50.
Let me know if this works for you.
Good Luck
Dan
I followed your directions and updates to the thread and was successful in installing an Autopage RF-225 Alarm/Keyless Entry into a 2008 Yaris Sd. While the wires for the Autopage are in a different configuration/color, I was able to cross-reference using your information and make it all work. I did find three wires on the D3 connector on the stearing column, but I verified and used the black wire as directed.
THANKS FOR ALL YOU DID IN PUTTING TOGETHER THE PROJECT AND GETTING THIS DIY FORUM GOING. MUCH HELP/MUCH APPRECATED!!!
Now I just need to find a truck actuator selonoid that will fit and work for the trunk release. The autopage provides an button and output for that. Any suggestions for a selonoid that will fit?
mwalls is offline   Reply With Quote
Old 03-07-2010, 01:10 PM   #54
silverbullet
I just installed "keyless" using DanQ's guide and I'm thrilled with the result - total success.
I don't know if it is widely known ( I'd hate to be redundant) but the Viper 211HV is identical to the Valet 712T; functionally, electrically, and physically. And they're both made by the same company. The only difference I can see is that the 211HV has a blue status LED. The Viper 211HV is sold on bestbuy.com for $139.99 with basic installation included. I got mine on ebay for $40.00 + $8.00 shipping.
My hat is off to DanQ for providing such an elegant DIY guide and for maintaining a website for easy access. I used CTScott's green wire mod but I agree with DanQ that it is good to get into the habit of using the remote to lock the car because it arms the optional ignition cut-off (regardless if it's installed) and causes the status LED to flash.
silverbullet is offline   Reply With Quote
keyless entry? / security? mem In Car Entertainment + Electronics (audio / video / alarm) 8 10-22-2008 01:29 AM
Keyless Entry BLKYRSSDN In Car Entertainment + Electronics (audio / video / alarm) 44 09-16-2007 10:27 PM
Aftermarket Keyless Entry - How does it affect the Warranty? aerock19 In Car Entertainment + Electronics (audio / video / alarm) 7 09-07-2007 02:11 PM
I want keyless entry!!! Lillydot General Yaris / Vitz Discussion 7 03-20-2007 10:46 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 09:57 AM
