Old 03-23-2009, 02:13 AM   #19
dallas
Drives: Yaris Hatch /Landrover D2
Well I found the MAF safe cleaner from CRC and I cleaned the throttle body there was a build up of dust etc at the butterfly, it seems to run a bit smoother with better response. I still have the harmonic vibration at 2000 rpm, I ran out of time to pull the muffler but that will be next, if that fails I will look at the h20 pump and belt tensioners etc, Thanks for the belt tension tip.
dallas is offline   Reply With Quote
Old 03-23-2009, 02:21 PM   #20
Lafiro
Drives: 06 Yaris Sedan
I take my comment back. I do still ahve this vibration.
Open your door, hold it with one hand, and start revving your engine slowly, and you will feel the whole car shake around 1700-2000rpm.
I dont know, more like the car vibrates with the vibration of the car, no way around that? Maybe just cheap engine mounts?
Old 03-24-2009, 12:08 AM   #21
dallas
Yah your right mine comes in a bit later around 2000-2600 rpm I bet if more people tried it they may be suprized to find how much harmonic vibration it is.
Old 03-24-2009, 12:57 AM   #22
ka0sx
ka0sx's Avatar
Drives: bone f*ing stock
I havn't felt anything of the sort. *shrug*
ka0sx is offline   Reply With Quote
Old 03-24-2009, 01:29 AM   #23
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
IIRC there are two total mounts...one tranny side and one motor side?
ergo there will be more vibration than you can bargain for, from say a lexus...
get a torque damper/ motor mount stiffy...
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 03-24-2009, 09:34 AM   #24
SailDesign
Drives: .
As I have said before, all of this begs the question of WHY you would worry about this vibration that only happens when the engine is unloaded. I have never, ever felt this when driving, which is the only time my engine ever gets to that rev range. So I don't (and won't) worry about it.
Old 03-25-2009, 12:36 AM   #25
dallas
When I'm at the Autocross at 6500 rpm I really don't want it to blow up, thats why I want to get rid of any harmonic vibrations especially ones big enough to feel in the seat of the car, under no load. I still have not had time to remove the aftermarket muffler to see if thats all it is, now go sail away
Old 03-25-2009, 08:49 AM   #26
SailDesign
Drives: .
Yubbut - y'see - it's the "no load" thing that bugs me, since the engine will behave very differently at load to how it behaves without load. It is entirely possible that there is NO vibration induced under load. By repeatedly running the engine to high no-load rpms, you may in fact be damaging the little beast.
That's my point...
So I'll go sail away - blow it up if you want.
Old 03-25-2009, 08:50 AM   #27
SailDesign
Drives: .
bump
Old 03-27-2009, 03:52 AM   #28
dallas
LOL, if there is harmonic vibration under no load, there can be more damage done under load without knowing it because it's under laod, for example if there is harmonic vibration is due to a unbalaced crank pulley under load the main bearings could wear uneavenly. Maybe I'm picky, but I really want to isolate where the problem is, if not I'll maybe I can blow it up for you
Old 03-28-2009, 12:11 AM   #29
jkuchta
Drives: 2007 Yaris hatch (red)
Don't fotget this is an inline 4, which is inherantly unbalanced. A compromise is made as far as the harmonics are concerned to make the engine as smooth as possible at cruise rpm, while transiant harmonics are mitigated as much as possible through component weights (i.e. a heavy crank will have resonant frequencies than a lighter one).
Also, the stock crank pully is heavy for a reason. When I installed the 10% underdrive pulley I noticed an overall increase in vibrations, but everything smooth's out above 2K rpms.
jkuchta is offline   Reply With Quote
Old 03-28-2009, 01:12 AM   #30
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
You might be able isolate it better:
http://www.yarisworld.com/forums/showthread.php?t=11905
Old 03-28-2009, 01:35 AM   #31
dallas
Good info !
Old 03-28-2009, 01:37 AM   #32
dallas
I did this on my last car made hard launches much smoother and fast shifting better, but a lot more vibration entered the cabin.
Old 03-29-2009, 12:42 AM   #33
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
i'm the first to admit that my exhaust is horrible :) it's fun to poke fun at someone who can't take it well though :D
Is that your personal exhaust, or your Scion's?
Old 04-05-2017, 07:02 PM   #34
Cartel
Cartel's Avatar
Drives: 2007 Yaris Hatch is sold
what a bunch of off-topic nonsense in this thread.
my car has this vibration at 2000rpm too.
feels like someone pulls a plug wire (exaggerating) at 2000....
googling brought me here
mines a bit shaky at idle too
Cartel is offline   Reply With Quote
Old 05-16-2018, 06:54 PM   #35
invalid username
Drives: 2015 Yaris
My Yaris with 1NZ-FE also has the vibration at 2000 RPM (if revved with no load). Since there are other people in here whose cars have the same vibration at the same RPM, then I guess it is just a characteristic of this engine. So, I'm not going to worry about it.
invalid username is offline   Reply With Quote
Old 09-01-2025, 10:18 AM   #36
removebeforeflight1994
Drives: Yaris 1.0 life - 2012
Hello
i have 2012 Yaris 1KR-FE 3 cylinder and i have the same problem around 1400-1500rpm. 1400 + below and 1600 + above are totally pure..
4 cylinders modal is vibrating in 2000RPM and 3 cylinders (mine) is in 1500.. seems it is the same issue
Does anyone help or already solved what can cause it ?
removebeforeflight1994 is offline   Reply With Quote
FS: 2000 Toyota MR2 Wheels Snake Items for Sale by private party 10 12-29-2008 05:01 PM
Vibration or shake at highway speed? evan DIY / Maintenance / Service 10 11-10-2008 10:23 AM
Need help on vibration. Red Horse DIY / Maintenance / Service 4 11-01-2008 04:48 PM
Post-rotation vibration kurokoma-kun Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 09-15-2007 06:02 PM
2000 Yaris / Vits Owner's Manual bobdigi General Yaris / Vitz Discussion 1 05-30-2007 08:45 AM
