Old 03-24-2009, 12:42 AM   #19
The blitz fuel controller does that and only that -- it does not adjust timing.
Old 03-24-2009, 12:45 AM   #20
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
So did you come to the conclusion that you have retard timing and even though these numbers mean you are running lean, you really aren't?
Is not like that... the problem is not running lean.
As largeorangefont explained, there are 2 things that could kill your engine...
Temperature and Knock...
Running lean will USUALLy lead to higher EGT (exhaust gas temp)...
This can be sorted by either adding more fuel to the mixure (making it richer) or by taking away ignition timing.
That's why it was said that even with those AFR readings... if the ECU or the black box were taking timing away... then you were probably OK
Talking about EGT... why you guys haven't picked a pyrometer? Those are not that expensive and would definetely help you sleep better at night...
Old 03-24-2009, 12:50 AM   #21
CASTREX
CASTREX's Avatar
Has anyone tried to disconnect the black box and see what happens? Ideally would hve to be some one with a wideband installed.
That would answer the question if the black box is actually doing anything at all...
Old 03-24-2009, 01:00 AM   #22
CASTREX
CASTREX's Avatar
Originally Posted by Yaris T-Sport View Post
maybe I'm wrong but, maybe your full custom exhaust loses too much back pressure, therefore you lose more horsepower than Noogie, try go back to stock exhaust to see if you gain more horsepower back.
I don't really think that is the problem...
When we have forced induction usually the largest the exhaust the better (within a range of course)
You need to remeber that no car is the same as no Dyno is the same...
Weather condition and other factors could have affected your final output.
Anyways.... isn't 20whp withing the range of the tipical gains offered by the blitz unit?
I mean... in you car that is a 23% increase in HP...
The tq still looks a little weak... but still within range...
I can see these kits putting 10-15whp more with a tune... if there would only be an easy way to tune it...
Old 03-24-2009, 01:09 AM   #23
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
it..
Yah true. When I did the dyno run, it had to have been atleast 85 degrees (HOT!). I don't think my 2.25" headerback exhaust would have me lose HP, definately torque, but NOT as bad as it is showing.
Noogie! Do it!
Haha, it wouldn't be that easy or cheap to go back to my stock exhaust setup. But I know what you're implying.
Originally Posted by Crandall View Post
Did they try to advance or retard the timing at all before he refused to run the car anymore?
We aren't capable of doing that unless we have a standalone ecu, correct?
Old 03-24-2009, 01:40 AM   #24
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
bigger problem
i undid my pvc valve to make hooking up my boost gauge easier and there is a ridiculous amount of oil coming out of my engine and into the manifold. something has to be very wrong
Old 03-24-2009, 01:41 AM   #25
PETERPOOP
PETERPOOP's Avatar
lol. well make a new thread. :P
Old 03-24-2009, 01:43 AM   #26
whooppee777
i figured everyone was already looking in this thread
Old 03-24-2009, 01:44 AM   #27
PETERPOOP
PETERPOOP's Avatar
true. good luck
Old 03-24-2009, 02:11 AM   #28
staypuft
aka SDMF
staypuft's Avatar
Drives: 07 LB Met Met
thus i installed an oil catch can
staypuft is offline   Reply With Quote
Old 03-24-2009, 02:19 AM   #29
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Why is everyone having problems with this kit now :( :( :(
Old 03-24-2009, 02:23 AM   #30
PETERPOOP
PETERPOOP's Avatar
Because nothing can be easy! Especially FI! doh
Old 03-24-2009, 02:32 AM   #31
whooppee777
its aftermarket shit, its never easy. but thats y we do it
i know its normal to have a little bit of oil coming through, but i have a shit ton WAY more than normal
Old 03-24-2009, 02:34 AM   #32
whooppee777
and by the way my afr go to the 12 range at WOT but tend to stay in the 14 at 1 to 5 pounds of boost
Old 03-24-2009, 02:36 AM   #33
PETERPOOP
PETERPOOP's Avatar
Well you're definately not running as lean as noogie and I. I ordered a scangauge II from garm tonight. Hopefully I'll get it soon and have more accurate readings.
Old 03-24-2009, 02:41 AM   #34
PETERPOOP
PETERPOOP's Avatar
yes, because you are boosted. An oil catch can on a boosted engine is a good idea, I have one as well.
I am curious of your A/F readings since you are using the 1.8 tb.
Old 03-24-2009, 02:51 AM   #35
whooppee777
urrently planning a group dyno day with some other tuners in the area within the next month u'll get ur readings as well as graphs
Old 03-24-2009, 03:23 AM   #36
Nexus1155
Drives: Audi
it seems like proper tuning would net this supercharger alot more power. people who arent running as lean as other nets 10 more hp?! imagine if you were actually running well...
AFR running extra rich at WOT? eTiMaGo Performance Modifications 15 03-10-2007 12:10 PM
