Old 09-27-2006, 10:50 AM   #19
riceboy
Drives: icebox
Anyone know if this applies in Canada too?
riceboy is offline   Reply With Quote
Old 09-27-2006, 02:16 PM   #20
ChinoCharles
Drives: LB
Called the dealership today... the service tech said he wasn't aware of any such TSB, at which point I gave him the code at the top right and he pulled it up. He was able to order the part right away and as long as the part can be sourced at their warehouse in Cincinatti I will be getting the new pipe installed next week. This is a replacement piece extending from the exhaust manifold to the axle-back exhaust, as the catalytic converter is welded directly to the pipe.
All you liftback owners, go get your replacement cat! I only smelled this after a short period of somewhat hard accelleration, but it doesn't mean the defect won't have negative effects for all cars over a period of time. Better safe than sorry, right?
Oh, and admins, you should probably sticky this.
Old 09-28-2006, 03:13 PM   #21
nick1983
nick1983's Avatar
Drives: 2007 Toyota Yaris sedan
Originally Posted by YamilR
FIRST POST
Iknow where to find this one. But where do you find the data base on them.
nick1983 is offline   Reply With Quote
Old 09-28-2006, 03:21 PM   #22
tomjasz
tomjasz's Avatar
Drives: 07 Black Yaris LB, 05 Camry LE
Ah....you read my post again or use a service that provides TSB's!!
tomjasz is offline   Reply With Quote
Old 09-28-2006, 08:24 PM   #23
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
The only strange smell i get is when working with my AirCondition specially when i lower the fan intensity
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 09-29-2006, 02:35 AM   #24
Terrorize
Toyota Newb!!
Drives: Yaris S Sedan w/ Aero Package!
Originally Posted by tomjasz
READ THE TSB!! IT READS HATCHBACKS ONLY!!!
Yeah i know its for hatchbacks only...but wondering if they will release one for sedans too heh heh...maybe same parts...well its gone now..my problem that is..i think it was just bad gas.
Terrorize is offline   Reply With Quote
Old 09-29-2006, 07:42 AM   #25
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
When I went in to get mine swapped yesterday, they put it up on the lift and then couldn't find the part. They have to reorder it. At least I got a free tire rotation while it was up in the air.
Old 09-29-2006, 10:49 AM   #26
riceboy
Drives: icebox
Canada???
Old 09-29-2006, 11:14 AM   #27
jeff_o
Drives: 07 Yaris
Send a message via ICQ to jeff_o Send a message via MSN to jeff_o Send a message via Yahoo to jeff_o
violin...by the way... which toyota dealer did you went to?
jeff_o is offline   Reply With Quote
Old 09-29-2006, 12:11 PM   #28
Violin
Violin's Avatar
I got it done this morning at Dayton Toyota (not where I purchased). Took about 30 minutes.
Old 09-29-2006, 01:12 PM   #29
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
isn't the US liftback tank about 11 gallons???? If so then I'm averageing about 300 miles a full tank. However I fill up right when the last bar starts to blink. How long can you drive with that bar blinking?
If 300 is all I get then I'mm averaging around 28 mpg. And I drive mainly freeway, and keep it below 70. wtf!!!! And I baby the thing.
should I be concerned and take it to the dealer?
Yaris Mods:
20% Tints
Ground wires
2007 Toyota Yaris Liftback - Current
2004 Honda S2000 - Sold
1986 Toyota Corolla SR5 - Sold
DIY: Groundwire Kit
ItsMyDaily is offline   Reply With Quote
Old 09-29-2006, 03:56 PM   #30
jeff_o
Drives: 07 Yaris
violin: i see... sorry if this may sound to be a dumb question because i dunno how warranties work here in the US.
1. if you bought a used toyota from a private seller, can you claim warranty from any toyota dealer? Or better question is...are the warranties transferrable from previous owner to you? (assuming the mileage is below what toyota advertised for the tranny, body, etc etc).
2. if you bought a used toyota from a dealer, can you claim warranty from any toyota dealer not from where you bought it from?
Old 09-29-2006, 04:22 PM   #31
Violin
Violin's Avatar
Yes. The warranty is from Toyota - not an individual dealer. It doesn't matter how many times it is sold within the warrant period, assuming maintenance records are good.
Old 09-29-2006, 04:41 PM   #32
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
I have a 2k5 Yaris and it had a strange smell but it only happened when it was new and i was using the clutch too much, when i had it on 1st gear and i was trying to drive slow @ high rpms...
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 09-30-2006, 02:31 AM   #33
ChinoCharles
Drives: LB
Thats just burning clutch haha.
Old 10-03-2006, 06:15 PM   #34
bigsky2
Cousin Vitz
bigsky2's Avatar
Just called a few service departments in my area (Lower Mainland, BC - Canada), and they are not aware of any TSB for the Yaris Hatchback 2007+ related to the catalytic converter/sulfur smell.
I think it will take some pressuring on the service department before they look into it closely. The TSB does state that it will only warrant the replacement if there is a specific complaint about the sulfur smell, so it's not like a recall.
Thought I'd try :)
No sulfur smell yet.
Old 10-03-2006, 10:09 PM   #35
Violin
Violin's Avatar
It made no difference in my mpg.
Oh well - just a shot.
Old 10-03-2006, 11:24 PM   #36
YamilR
YamilR's Avatar
Thought I'd try :)
Just tell them that it stinks, at least on my case they didn't do a test drive, and raise HELL if they call you a liar
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 04:12 PM
