#19 |
With the info you have supplied me its getting clearer and clearer...
in cabin wiring still a bit hazy . i like the idea of the OEM Light Stalk but only if i can get on the cheap lol
![]() ![]() The difference between fiction and reality? Fiction has to make sense. --Tom Clancy |
#20 | |
the other offer is open to all .
#21 |
not many members are from Puerto Rico :P
#22 |
![]() ![]() ![]() Drives: Yaris Join Date: Nov 2008
Where abouts does the relay go under the dash?
nevermind, i found it. |
#23 |
Wait. Where can I get the relay needed for the fog lights?? I'm confused.... Everything's set up for em but I just need that darn relay. I can't find it at chechers, or auto zone..
#24 |
Garm has them a long with the wireing ,
#25 |
I already got the wiring down and I have this exact same kit: http://www.yarisworld.com/forums/showthread.php?t=9473 I just need the relay... I'm so confused. @_@
#26 | |
or do a google search,sorry i can't be of any more help . |
#27 |
Metrixx3
INZYaris1...and garm can't find those placed on the web , could you post links to this placed ??. thanks.
#28 | |
or Sparks Toyota http://www.sparkstoyota.com/TRD.aspx |
#29 |
Bears eat beets.
Drives: Yaris LB Join Date: Aug 2006
I didn't see anything on your site for an 09 Hatchy... did I miss it??
Free veggie starter kit! |
#30 | |
09 faceplate's are only available at the dealer's ,for know , probably until next year. |
#31 |
![]() Drives: 08 Yaris HB Join Date: Aug 2009
Well bought a set of foglights on ebay.. now wishing I would have just bought them at micro image
The switch is not the same size as the others in the center console. I dont feel like dremeling the console just to make a funky long shaped switch fit that will bug me when I look at it and it doesnt match the others. So I was thinking that I might try the fog light Stalk as it would be more convienent anyway. TRD sparks had it for 75 bucks. Has anyone put one of these in and could give me some advice? I have been searching posts and see that it was mentioned you just remove the old and plug in the new. Does this require me to remove the steering wheel also like you need to for the varianble wiper stalk? Does Micro Image still sell the under the hood red 2 wire connector setup seperatly. I was looking on the site and didnt see it. I could make my own I suppose, just need crimpers and pins.. But was hoping for the convienence of a premade. Thanks for any help . |
#32 |
Yaris = <3
Drives: '08 Sedan - Flint Mica Join Date: Jan 2009
PM Garm (CaliYaris) for the wiring kit alone. He should be able to hook you up.
As for the switch, I have an interesting story. The switch that came with my lights off ebay was a bit faulty. When I would turn them on then off then on again fast, they wouldn't come back on the second time. I'd have to leave them off for like 3 seconds first. Then they'd work again. So from a suggestion from CTScott, I tried just bridging the connection and was able to turn them on and off fast. So I replaced the stupid fog switch with a little general-use rocker on/off switch. I dremeled one of the plastic place-holders to fit the rocker switch and got it in the same spot as I had the actual fog switch (right by the e-brake). So now I can switch it on/off repeatedly fast and they come on each time. And it actually looks A LOT nicer than the big clunky fog button.
..:'; Nick ;':.. ============================== 2008 Yaris Sedan - Flint Mica ============================== Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter ============================== |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| DIY - fog light install | kurokoma-kun | DIY / Maintenance / Service | 3 | 09-18-2012 12:52 AM |
| Rav4 and Highlander fog light parts | 1NZYaris1 | Items for Sale by private party | 5 | 02-13-2009 10:43 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
