#19 |
it's been a while
i didn't cut the bump stops when i installed my trd springs and haven't had any problems
#20 |
I have TRD springs and stock struts, dealer installed, and my suspension never bottomed out, and i live in Quebec city! I don't understand why stiffer springs (TRD) would be more likely to hit the bump stops compared to stock; even more if stock struts are longer?!
Enlighten me, please |
#21 |
Consider that the springs control the ride height. Therefore, with a shorter spring, the stock-sized strut will face a larger natural compression, even while parked. Less space between the wheel and the strut tower (which is the objective when lowering the car) means that the stock strut has to compress just to fit where it is supposed to. Shorter (and usually stiffer) struts do not have this problem because they were designed for lowered applications. There is no doubt that lowering springs place a higher burden on the stock struts. The stock struts WILL wear out faster because of this. Cutting the bumpstop is supposed to reduce the load placed on the stock strut by increasing the amount of room the strut has between the wheel and the bottom of the strut tower.
Make sense? |
#22 | |
EVERYBODY EVENTUALLY COMES BACK TO YARISWORLD...... |
#23 |
JDM yO!
Drives: '09 3dr. 5-spd Join Date: Oct 2008
Someone had stock struts for sale the other day and said they were by KYB (had it stamped on the strut).
#24 | |
![]() About strut wear, i'll wait and see ;) |
#25 |
Drives: Vios Join Date: Apr 2009
Hi guys,
I'm running on Sustec lowering spring on stock strut and recently there are sound coming from the front when going down parking or during the compression of spring. Inspected the spring and found no sign of spring banging itself. So got a pro mechanic to check and he found out that my car actually sitting on the bump stop! When the car rested on ground, we can't even more the bump stop up or down. Now I know why my car higher than the rear, the car was sitting on the bump stop all these while! Will get it cut tomorrow and see what's the outcome. And good thread here strenghtening our doubt. |
| TRD Springs Shocks and Sway Bars IN STOCK | Sparks Toyota-TRD | Sparks Toyota | 0 | 03-12-2009 09:54 AM |
| Yaris is low enough stock....trd springs bad??? | Yawesh | General Yaris / Vitz Discussion | 13 | 12-26-2008 12:17 AM |
| Free for Local Pickup: Stock Springs, Shocks & Struts | Violin | Items for Sale by private party | 4 | 11-14-2008 09:36 PM |
| using the tops from stock struts with new trd struts? | tekmoe | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 01-13-2007 11:58 AM |
| ordered my trd springs and trd struts earlier today | tekmoe | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 01-10-2007 06:36 AM |
