#37 | |
#38 |
Pretty green Yaris Verso
Drives: Toyota Yaris Verso Join Date: Mar 2009
Between 60 and 90 on first bar, and between 190 and 260 for the fifth bar to disappear.
Agree that the later bars go quicker, especially the second-to-last, and I reckon that's been somewhat cynically designed in by Toyota to inflate the apparent fuel economy. |
#39 |
Half a Bubble Off Plumb
I think that's simply a matter of a float hanging on a simple pivot. The geometry means the angle is going to change faster as it goes down, if the float arm is nearly level at the top.
#40 | |
#41 |
Not hard, but they probably never thought it important to do so. If lots of folks complain to the company, I'll bet they'll change it. I just learned how mine works and adapted.
#42 |
I usually get around 60-65 miles per bar, not calculating anything, just glancing at it with the trip meter set.
#43 |
I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
I hope the 1.1 gal. at fast blink is correct... When it hits and I'm too far from a station i think " well with the gas mileage I have at least 30 miles left" and I don't worry about it... I suppose what I should do is get a gas can full and test the miles from fast flash to stall, but I hate to think of the sludge in the bottom of the tank getting sucked into the fuel filter...
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
#44 |
I filled my new sedan within 5 miles of switching to the last bar a couple of days ago. I fill it fast, then when the pump clicks off I "top" it slowly till it clicks off once more, not really topped, for consistency. It held 10.05 gallons. IF it's true that there's 11.1 usable gallons in the tank, I figure there's a gallon left when the blinking last bar appears on mine. I'm not going to push my luck.
#45 |
![]() ![]() ![]() Drives: Toyota Yaris 1.3 vvti cvt Join Date: May 2007
I've done a personal record last time to ''get rid off'' my first bar: 112 miles.
#46 |
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2008
I had one of those gas pumps that took 20 minutes + to fill the tank, but the bonus was that the tank gets wayyy topped off. I mean, you could see the gas inside the filler, that's how full it was.
It paid off, too, as I saw my record MPB. I got 112 off of the first bar (no joke), and was at 166 when it went down again. |
#47 |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
I don't understand why they chose 8 bars instead of 11? or atleast 10.. that way it could make a bit more sense to calculate what you have left. i think they made the first bar out of whack, even the first half, to help sell the car :D
"wow, 220 miles and still a half tank!?" anyways, I hope the gas gauge isn't a cheap lever and bobber, it'd make more sense to use a pressure sensor.. no? |
#48 |
![]() ![]() ![]() Drives: 2008 Yaris Liftback Join Date: Oct 2008
That first bar seems to vary depending on how much you fill up the filler pipe. You can pump an additional gallon or more. That's why some of us get 112 + - on the first bar. It's all been said on these past 48 posts. The gauges just can't be that precise. It's mostly up to the individual to control the variables.
#49 |
#50 | |
Every car I ever had seemed to hang forever at ther first "line" on the gas gauge and then, go down progressivly faster after that. Gas gauges have always been just a rough estimate for how much gas you have. |
#51 |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris sedan Join Date: Jun 2007
Not every car I've owned had inaccurate gauges. I had a Morris Minor that was easy to get used to: Filler pipe full, gauge stayed still on full. Down a gallon, gauge bouncing around at full. Near empty, and you could see the float bouncing on the bottom as the fuel swished back and forth. When that gauge stopped moving, you were out of gas. Stupid me, I always thought that is how a fuel gauge was supposed to work!
#52 | |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
*** On a side note I just remembered a funny story from my childhood. I was riding with my Dad in his pickup truck and he said "We'd better get some gas-the gas guage is almost down to 'P'". "P?", I asked. "What does that mean?" "Pedestrian!" he replied. *** |
#53 |
![]() Drives: 09 Yaris Sedan AT Join Date: Jul 2009
I got 82 on my first bar today! This is the first tank that I have filled. I consider a tank to be from full (pump click +to the next dollar) until the last bar starts to blink.
#54 | |
| 2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. | trini_per4mance | General Yaris / Vitz Discussion | 100 | 06-08-2022 09:54 PM |
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 06:52 PM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-05-2008 11:37 PM |
| Synthetic Oil | Kaotic Lazagna | DIY / Maintenance / Service | 122 | 09-20-2007 03:40 PM |
| c one motorsport performance bars | badhabitz | Performance Modifications | 17 | 08-23-2006 10:31 PM |
