Old 10-30-2008, 07:51 AM   #91
ToTo
ToTo's Avatar
Drives: Toyota Yaris T SPORT
Does anyone know how low can you go on coilovers without rubbing on 195/50/15?
ToTo is offline   Reply With Quote
Old 10-30-2008, 03:06 PM   #92
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Pretty darn low. I'm nearly at full UP in the rear, and the fronts could go down a lot more if you're going for a show car look. It'd be miserable to drive that low, though.
Old 11-06-2008, 05:35 AM   #93
ToTo
ToTo's Avatar
Thanks for the info! It would be a miserable ride even with coilovers?
Old 11-08-2008, 05:20 PM   #94
Thirty-Nine
The Megans are pretty stiff, even at soft settings. If you're looking for a nice, soft ride with coilovers, check out the Tein Basics.
Old 11-08-2008, 08:20 PM   #95
seth_man
seth_man's Avatar
Drives: 08 Liftback
pretty low, ive got 205/45/16 tires 16x7 +40 wheels and i dont rub. i cant fit a finger between the fenders and the tires. lots of preload though.
seth_man is offline   Reply With Quote
Old 04-04-2009, 06:03 PM   #96
having the same problem with mine...gotta take the fronts apart tomorrow....
damn megans and their no instructions...
Old 04-06-2009, 02:47 PM   #97
Thirty-Nine
Did you get your problem solved?
Old 04-06-2009, 08:23 PM   #98
sorta..might have been using the wrong bolt at the top of the bearing
also lowered the height in the front another 1/2". still sits a bit too high above the strut top, but ill live with it, i guess
Old 11-01-2009, 09:59 PM   #99
weedtank
I need more stars
weedtank's Avatar
Drives: Liftback
Silly question but how do you adjust the height for the rear? Is it the spring or the damper?
weedtank is offline   Reply With Quote
Old 11-01-2009, 11:00 PM   #100
perch for the spring for height
Old 01-28-2010, 12:46 AM   #101
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
I'm resurrecting this thread in hopes that 39 might post that DIY/pics he promised?? :)
If nothing else, how did you go about pressing-out the strut bearings? There is a lot of great info about these coilovers in this thread, it just takes a while to find it.
Any chance you can post some dimensions/settings for your current setup? Like, how much rear shock thread is showing? How much preload did you end-up going with? How low did you drop it without lots of rubbing?
Thanks! the thread alone has been mucho helpful.
Old 01-28-2010, 11:07 AM   #102
Old 01-28-2010, 01:24 PM   #103
ozmdd
ozmdd's Avatar
Thanks. A picture really is worth a thousand words!
Old 03-01-2010, 07:50 AM   #104
ToTo
ToTo's Avatar
Hey guys! Im really trying to understand this install, but can someone give me some info on the rear shock to begin with? I dont quite understand the purpose of the threads on the bottom of the rear shock? What is it used for and how do I adjust it?
Thanks!
Megan Springs? churp Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 06-06-2007 04:11 PM
Megan or Tein suspension elmercurrie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 43 05-31-2007 10:41 PM
Comp S Coilovers for a discount and installed BulletProofAuto California 1 05-12-2007 02:04 AM
cusco coilovers installed badhabitz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 02-03-2007 05:43 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 08:45 AM
