Old 04-10-2009, 02:12 PM   #1
Slick
Slick's Avatar
Drives: '09 3-Dr
Send a message via MSN to Slick
Clear tube
Alright, I am in the process of installing a sound system in my 3Dr. I pulled off the passenger side kick plate and low and behold I found a clear tube running down the side of the interior of the car. My question is... is it rear window washer fluid or fuel line? My first thought was window fluid, however, if this were true then it might/should have a blue tint to it. However, taking into consideration that, like many lightly colored liquids, thin amounts of it would appear clear. So, my only test that I could perform is to start the car, hit the rear window washer button, and then squeeze the tube. So one of two things will happen, the squirter will quit squirting... or the motor will shut off Any help will be appreciated.
Slick is offline   Reply With Quote
Old 04-10-2009, 02:44 PM   #2
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
rear washer stuff runs under headliner so its not that.....
Old 04-10-2009, 02:50 PM   #3
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Fuel lines are not run inside the passenger compartment. They are usually steel and run under the car with black high-pressure rubber hoses to make connections at either end.
Could you be looking at an air conditioner condensate drain tube?
Photos are very helpful.
Old 04-10-2009, 03:19 PM   #4
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Secret factory bonus nitrous oxide injector?
Old 04-10-2009, 08:58 PM   #5
jkuchta
Drives: 2007 Yaris hatch (red)
My washer fluid line runs along the passenger side kick panel along the floor right under the door jam.
Hold the line while you activate the washer, and you'll be able to feel the fluid running through the line.
jkuchta is offline   Reply With Quote
Old 04-11-2009, 12:22 PM   #6
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
If it's not the washer fluid line, then it's probably a drain.
Buzzing from my tube myt In Car Entertainment + Electronics (audio / video / alarm) 7 02-03-2009 03:26 AM
Bazooka Tube bdc87 Items for Sale by private party 2 12-29-2008 10:33 PM
Clear coat chipping due to acid rain? Woody_Woodchuck Wash, Wax, Detailing, Exterior Repairs 9 12-03-2008 07:15 PM
Group buy? clear coverings YarisTom73 Cosmetic Modifications (Exterior/Interior) 0 06-21-2007 10:32 AM
Any front bumper/ hood stone chip issues? Where could I get Clear Bra kit? tifosi360 General Yaris / Vitz Discussion 9 08-07-2006 03:43 PM
