Old 04-20-2009, 11:23 AM   #91
IllusionX
Drives: 07 Yaris Sedan Aero
the chances someone drumming on this steering wheel, the air bag deploying while someone is filming is VERY slim...
Old 04-20-2009, 12:04 PM   #92
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
the tags for the video as well as the other videos recommended lead me to believe it's from a car insurance company....
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 04-20-2009, 12:46 PM   #93
guys , easy wait for CTScott to confirm if this is doable. From what i saw in the wiring it seems it will work , but i don't want you guys to spend money if you need an extra control module for it to work
Sorry for the delay in looking into this, but I was away on vacation. I looked this morning and agree that it should work with simply adding the switch.
Here is a quote from the 09 service manual:
"The microcomputer which controls the cruise control system is built into the ECM, and uses the throttle position sensor and motor as the actuator."
The stalk basically just has 4 switches and 3 resistors. The quick and dirty test (without removing the airbag) would be to short the ECM CCS pin to ground. If the cruise light illuminates on the combination meter, you are good to go.
Old 04-20-2009, 01:40 PM   #94
i think we need to be rolling above 25mph for the cruise to enable , its one of the failsafe conditions.
25mph is the minimum limit for "set", but the manual doesn't list a speed limit for the on/off function.
Old 04-20-2009, 03:24 PM   #95
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
I just checked - my car ('08 5-door) doesn't have the wiring from the spiral cable to the ECM - nothing coming from that plug except the thin black horn wire. If the wiring for cruise were present, there would be two more wires.
So, installing cruise is probably still possible, but unfortunately it's not just a matter of adding a switch.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 04-20-2009, 03:28 PM   #96
ka0sx
ka0sx's Avatar
Drives: bone f*ing stock
guys, those of you who are saying few minutes, be careful, some car systems can take over an hour to discharge the sustaining capacitors, also ground yourself to prevent static discharge.
ka0sx is offline   Reply With Quote
Old 04-20-2009, 04:00 PM   #97
My '09 has a blue wire in pin 1 and a brown in pin 3.
When I look at the models that the stalk part number is applicable to I see 06-09 sedans, but only 09 liftbacks.
Old 04-20-2009, 04:39 PM   #98
thats not where you connect the stalk to and the wire for css is already there,
wire 1 and 3 from the stalk is connected to 3 and 4 on the spiral cable
The stalk connects to the spiral cable on the steering wheel hub end, but the connector he pictured is the output of the spiral cable, heading towards the ECM. In his picture, the CCS wire (blue on my 09) is missing.
Old 04-20-2009, 05:37 PM   #99
Sir A.Y. Atoyot
Drives: '08 5-door
do you have that wire? the way i was looking at the ewd it seemed like these are used only as test points. either way it shouldn't be hard to just use the jumeper to connect the D3 with A21 i need to pop my cover to see better
I've done some research with the documentation that members have provided, and I can assure you that you need two wires coming out of that plug, in addition to the horn wire. One of them is blue and goes to the ECU. The other is a yellow ground wire.
Old 04-20-2009, 06:38 PM   #100
Sir A.Y. Atoyot
Drives: '08 5-door
....Anyways we shall see....
You said it.
Old 04-20-2009, 08:11 PM   #101
Here's a comparison of SodiumDuck's 08 (left) and my 09 (right) (from when we installed our remote starters). Mine has the blue and brown, and his just has the black horn wire.
On the EWD, the spiral cable is just the block between 3B and 1A, as well as the block between 1C and 8A on the horn diagram on page 145. The spiral cable simply brings the signals off of the movable steering wheel. (If we had the European steering wheel controls, they would most likely connect through the last unused pin).
Old 04-20-2009, 08:39 PM   #102
enobmort42
First time DIYer
enobmort42's Avatar
Drives: '07 LB Polar White
Send a message via AIM to enobmort42
i'm beginning to get lost in all the technical talk. i should probably take a look at mine up in there.. unless someone can tell me if i have what it takes to do this by telling them that i have an '07 lb hatch?
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs
enobmort42 is offline   Reply With Quote
Old 04-20-2009, 09:16 PM   #103
I was thinking that I was having deja-vu on this topic and found this topic from a while back:
http://www.yarisworld.com/forums/sho...=cruise&page=3
Out of curiosity, have you checked to see if your combination meter has the two cruise lights.
Old 04-21-2009, 12:09 AM   #104
Sir A.Y. Atoyot
Drives: '08 5-door
No cruise light on my dash panel. It has a fog light icon, though (no actual fog lights in the car).
Canadian 2008 5-door hatch.
Old 04-21-2009, 12:25 AM   #105
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
ah so since the cruise connects to the inside of the oem steerig wheel looks like i cant add it since i have an aftermarket wheel :(
Old 04-21-2009, 05:54 PM   #106
Sir A.Y. Atoyot
Drives: '08 5-door
You could install one of the aftermarket Rostra brand units, which doesn't attach to the steering wheel. Be prepared to pay lots, though.
Old 04-21-2009, 06:26 PM   #107
Or you could add four momentary switches (On/Off, Set, Up, Down) to the dash like I am going to do to save on buying the stalk and on having to pull the airbag.
Old 04-21-2009, 06:43 PM   #108
Sir A.Y. Atoyot
Drives: '08 5-door
Good luck with that - those functions on the stock switch work through resistors and involve the extremely expensive central engine computer (ECM). The resistors are the squiggly lines in the diagram. It's important to know the exact values to make it work right. A familiarity with Ohm's Law would help, too.
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
