アキバ製
Drives: 09' White LB, Celica GTS Join Date: Apr 2009
Power lock questions
Well after searching and reading many threads about this topic I still could not find a true answer. So here I go!
Well I, like many others bought the base model. And like many others want to install power windows/locks. So for windows pretty much going with the "Colibri Star Power window Kit" off the A1 site. Now for power locks I was going to go with the "Keyless Entry & Cable Lock Kit" again off the A1 site. But my question is, Does the base model have pre-existing harnesses for power locks? Where if I buy all the parts from toyota I can just plug and play? Also I know many have done both power windows and locks using the kits from A1 but has anyone made a "How to" yet? |
i suggest you do not buy the kit from toyota.
This was done on a toyota echo hatchback... i had queried for a priced on all the parts that i needed and the price of each... door lock control module = 580$ -i had a 3 doors at the time, so 2 door lock motors door lock motors = 174$ each -i said forget the hatch door, but the lock motor was 100$ centre console lock/unlock switch = 80$ all wiring came from factory, all i had to do was plug in the module, run wires from the inside of the doors to the kick panel (where the lock motor plugs into), plug the switch in the centre console, and then swap the lock assembly with new motor. not exactly the route you want to go, but it is possible... |
#3 | |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
There was a "how to" on this site before the hack of last fall. Not for sure if it is still on here. Search for a guy by the name of DanQ. I think he was the one that posted it. |
アキバ製
Awww I only could find his keyless entry how to...
But the reason I asked was because I get discount on toyota parts and thought maybe I should go that way. Hows about power mirrors? If I have the power mirrors and I buy the switch is there harnesses already in there to just plug into? I read somewhere that there are but cant find the thread were I saw it. |
First time DIYer
hey, i found this: link. also, when i followed this, i noticed there was a harness/connector up toward the front of the door.. not sure what it went to; am trying to find out now
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs |
First time DIYer
(the picture in the second post shows the harness that i'm talking about - up near the mirror)
アキバ製
Nice thanks, hmmm yes I wonder what that harness does also.
![]() ![]() ![]() Drives: Flint Mica Sedan Join Date: Oct 2008
アキバ製
I was thinking about getting this
http://www.a1electric.com/Merchant2/...Category_Code= But was wondering if I needed to buy the button sepreate http://www.a1electric.com/Merchant2/...Category_Code= |
Edit for being wrong, lol.
#11 | |
#12 | |
First time DIYer
#13 | |
#14 |
アキバ製
Darn let me try again
http://www.a1electric.com/Merchant2/...Category_Code= and this switch http://www.a1electric.com/Merchant2/...Category_Code= does it work now? |
#15 |
Yea, that's right. Don't need the switch. If you lock the driver's side door or unlock it from the inside, they all lock or unlock. The switch will just be more work and more problems in the long run. Plus it will look a lot cleaner without a switch.
#16 |
アキバ製
how do you unlock it from the inside without a switch? or does the kit come with one already.
#17 |
You unlock the driver's side door and it unlocks all the doors. It's "central locking". You don't even need keyless, but get it if you don't want to use the key to unlock the driver's door/all doors. If you got the standard power lock kit, you would just unlock the door with the key and it would unlock all the doors.
#18 |
アキバ製
Ohh so wait. a little confused. so the kit already come with a lock/unlock switch? I dont quite understand how to unlock the driver's side door from the inside with out a switch.
| Questions and advice required about power upgrading(windows & locks) | W.A.S.P | DIY / Maintenance / Service | 10 | 07-22-2009 02:59 AM |
| Power Lock button?? | cyberfrogg | DIY / Maintenance / Service | 25 | 03-26-2009 10:16 PM |
| Power hatch lock? | paultyler_82 | DIY / Maintenance / Service | 5 | 09-08-2006 01:15 AM |
| using regular power lock kits with cable style | twixt | DIY / Maintenance / Service | 4 | 08-12-2006 01:18 PM |
