#19 | |
SIPNDEW
i thought you said you were done in your previous post......its not nice to go back on your word. i wish people would cut down on their whining here. for the record, i am reading this to try and gain something from it but the arguing and bickering is rediculous and making this thread hard to follow. |
#20 |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Have you looked into the Hang Time technique which is stickied at the top of this forum? It is much less labor intensive than P&G, and it lets you maintain a narrower speed band.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#21 | |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
And then I'd like to know if the 10 dollars(by my numbers) or the 40 dollars(by bailouts numbers) a year is worth the risk of increased injury and damage to the car getting rear ended turned off vs in gear and on. Not to mention, if you still had the car on, you could have pulled out of the way instead of getting rear ended. |
#22 |
SIPNDEW
i think of it as....well the yaris gets better mileage than my last car...thats good enough for me. why can you all be happy getting high 30s?
#23 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
Because happiness is relative.
#24 |
SIPNDEW
well im coming from a 13 mpg lincoln. instead of me squeezing every last drop of fuel from my yaris...i would rather have some fun with it and still get great mileage...and for the record..i get 42 mpg from mine.
#25 |
╚══════════RN
Yup yup, I've read all your posts a lot. But don't you say you need a ScanGauge to do this technique?
#26 |
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
What I think trips up the logic on the Neutral coasting versus DFCO in gear, is that in Neutral the engine will rev just a little bit higher and you will actually use more gas on that down slope and worse yet, the fuel from that extra revs isn't putting any useful energy into the wheels.
This is hard to see without a ScanGuage or at least a Tach. It does take effort and practice to give it just enough gas coming out of the down slope to minimize your loss of momentum and speed. There is a strong pull to step on it a little too much if the car slows down more than 5 Mph, which tends to undo some of the savings you just made coming down the hill. Again look at your route, maybe you can find a way to coast from Mt. Wachusett most of the way home ;-) By the way, 3 trips this week at 45 Mpg in my 08 manual LB, and its not even May yet. You can do this! |
#27 |
I mention in that thread that you don't have to have a ScanGauge for the Hang Time technique but that it's easier to dial it in with one.
#28 |
rarer than JDM -1 of 1!
I, like Sodium, barely crack 40 MPG on a tank. I think i've done it twice.
Anyway, my question is that since i only usually drive my car during the workweek, i usually only drive it monday-friday, and sometimes only 4 times a week. So on weekends it sits on the curb. How much does this sitting for 2-3 days a week affect my mileage? I may run a test to see how it works. |
#29 |
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
Sitting around has no effect other than the usual cold-start penalty. My car quite often sits undriven for 3-5 days at a time, I work from home. I can immediately get in it and turn a 45+ mpg trip average anytime I want to. Traffic usually makes it difficult to get more than 38-42 mpg, though.
#30 |
╚══════════RN
Bah! Just filled up, 39.80MPG!
Something drastic must be done!
#31 |
What?
There's a technique called DWB - Drive Without Brakes. Essentially, it's just a way to make more use of coasting and DFCO. Sort of a mental exercise, really. Just drive as if you don't have brakes. If you didn't have brakes, you'd be looking WAY further ahead and anticipating stops, downshifting and much more carefully managing your speed. That's what you need to be doing for max fuel economy. Anytime you touch the brake pedal, you're wasting energy, turning it into heat.
Think that will help you? |
#32 |
╚══════════RN
Well, I do that to an extent now, but I will take it to the next level -- I think that will give me my .2MPG. On the way back from the gas station tonight, I was practically using just my pinky toe on it, coasting way far away into lights and using DFCO a lot. *fingers crossed*
I think that will help!
#33 |
I recently picked up a used Scangauge. I usually get about 35 MPG max, and now I see why - I never thought that I had a heavy foot, but I often see 5 MPG for a few seconds when accelerating from a stop. With the Scangauge I am learning to accelerate more gently and am expecting that at my next fill-up I'll notice a significant difference.
#34 |
╚══════════RN
Hmm, when you accelerate from a stop how high do your rev's go? Is that the only major fuel burning thing you've noticed yourself doing with the Scangauge?
#35 | |
The other place I've noticed a significant reduction in instantaneous mileage is going up hills. I find with a couple of hills around me that I sit at 15-20 MPG most of the way up the hill. |
#36 | |
What?
You'll use more fuel with a heavy foot shifting at 2000 than you will with a light foot shifting at 2500 |
| Someone tried to break into my car....again. Pics | SIPNGAS | Off-topic / Other Cars / Everything else Discussions | 62 | 04-15-2009 01:12 PM |
| SCCA Hawaii- 2 races till 3 month break | anonymous user | Tracking, Racing, Auto-X Forum | 0 | 03-21-2009 02:43 PM |
| WHat is Yaris Break In period and how? | marcus | General Yaris / Vitz Discussion | 3 | 01-19-2007 03:24 PM |
| speaker break in... | twixt | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-16-2006 07:42 AM |
| Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 09:01 PM |
