Old 04-19-2009, 04:52 PM   #19
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
Originally Posted by custom Lftback View Post
Tried that, still didn't work. so that's why we just put in a switch. it's no biggie tho.
Oh, well congratulations on a nice install! Any more upgrades to your sound system?
808_Yaris is offline   Reply With Quote
Old 04-19-2009, 04:59 PM   #20
IsLNdbOi
IsLNdbOi's Avatar
If the unit has a RCA or 3.5mm auxiliary inputs, you can still use the Yaris's stock aux jack. There's a thread about it somewhere here.
Old 04-19-2009, 08:46 PM   #21
leugimlegna16
leugimlegna16's Avatar
Drives: 2008 Yaris Hatchback
IsLNdbOi you are right, the unit has RCA inputs
http://www.pioneerelectronics.com/PU...P3100DVD.Popup
I think it works with the source aux 2.
leugimlegna16 is offline   Reply With Quote
Old 04-20-2009, 02:46 AM   #22
IsLNdbOi
IsLNdbOi's Avatar
Here are the threads w/ DIYs on using the stock aux jack w/ aftermarket HUs.
'09LB:
http://www.yarisworld.com/forums/showthread.php?t=11849
'07/'08LBs:
http://www.yarisworld.com/forums/sho...d.php?p=199347
Old 04-20-2009, 04:21 PM   #23
custom Lftback
custom Lftback's Avatar
not yet, this is the first part of the sound system. Taxes killed me this month, so the rest will have to wait a couple of months, but I'm in no hurry!
I am going to be getting a single Alpine Type R 12" subwoofer, and still looking for a fairly inexpensive amp to power it.
But I might tint my windows first before I do that, because it is starting to get hot!!!
As far as using the stock AUX input, I might have to play with it, because this ipod control wire that works with the HU doesn't allow my iPhone to play through the speakers of the car, it just takes over the iPod portion. So I could possible rig the stock input so I can have a sort of "handsfree" system lol.
I am currently watching Iron Man on the head unit, and the picture is awesome!!
Old 04-23-2009, 04:19 AM   #24
Pitt Yaris
Drives: Flint Mica Sedan
I just ordered this kit through Amazon. Might need to ask questions later, hah. Now I gotta get an alarm system.
Where can I get the spacers/harnesses that are also needed for install?
Another question.....if I have a flash drive with only songs loaded on it, would I be able to play them through the usb port on the unit?
Old 04-23-2009, 01:31 PM   #25
BailOut
Steals terrorist's lunch
BailOut's Avatar
Have you had a chance to try playing any video media through it yet? It says it plays DIVX so that should mean that it can play most AVI files. Most music videos you can download come as AVIs.
- Brian
Share the Road
Old 04-23-2009, 07:03 PM   #26
custom Lftback
for the spacers AND harness needed, I got em here: http://cgi.ebay.com/2007-Toyota-Yari...3286.m20.l1116
Fast shipping and great price.
yes the songs from your flash drive will play on the unit.
Old 04-23-2009, 07:04 PM   #27
custom Lftback
yeah, I can play all my music videos that are loaded on my ipod on the unit.
Old 04-23-2009, 08:56 PM   #28
Pitt Yaris
That's awesome. Thanks for the link. Guess I won't need an ipod after all. I'll just load up my flash drive with songs and videos and play on the head unit.
It says 2007 yaris. Yours is a hatch, but I don't see much of a difference so I'm guessing this will fit my 2008 sedan?
Old 04-23-2009, 09:19 PM   #29
custom Lftback
no prob! yeah it'll fit fine
Old 07-09-2009, 11:09 PM   #30
BailOut
BailOut's Avatar
Well, my OEM deck finally crapped out. It's been on the fritz for a few months now, often refusing to read CDR media. Cleaning it helped for a while but not for long.
On the recommendation from other users here on YW I decided on the unit discussed in this thread, the Pioneer AVH-P3100DVD, just as the OP did. However, I did not like the idea of hitting a switch every time I key start (as a hypermiler I can key start several times during in-town trips), and I plan on playing everything as music videos rather than MP3s, so I wanted a relay-based solution.
I first tried a method involving a solid-state relay from Radio Shack but it simply did not work. Instead of acting as a double throw it would only act a single. That won't fool the "safety", aka NUISANCE, crap that Pioneer put into this unit.
I then tried another method that worked well for me:
http://www.hawkee.com/shop/review/179441/
I used Niehoff part number RL36621 but any 12V SPDT 5-pin automotive relay should work. I also picked up some 1/4" insulated quick disconnect (spade) connectors so that I didn't have to worry about insulating anyththing.
It works like a charm but I still have to hit that stupid OK prompt each time I restart in DIVX mode, and there's a bug in that while a DIVX (AVI) movie will pick up where it left off it only it plays the video with no audio until the track/file is changed. I plan to call Pioneer tomorrow to see if there's a fix or workaround for that. I'll also ask them about a way to randomize/shuffle files on disc (that feature is grayed out).
It is also worth noting that the Metra harness given in the sticky in this forum does not match up perfectly with this radio. Go orange/white to orange/white despite the naming difference (one side is labeled Illumination while the other is Dimmer - ignore the Illumination label on the Metra side) and cap off the orange/black wire on the rear speaker connector on the Metra side as it does nothing.
- Brian
Share the Road
Old 07-12-2009, 05:26 PM   #31
Soner
Send a message via Yahoo to Soner
Seeing those pictures made me think that if you can paint the silver plastic peaces to the exact same black color, your set up would look even better. Needless to say it looks MUCH better now than the stock set up.
Also, I know there is a price difference between the head units with navigation and without it however it could have been great if you had navigation on it.
Soner is offline   Reply With Quote
Old 07-13-2009, 11:38 PM   #32
koala
Do you have to buy Pioneer's overpriced USB cable for iPod support or can you use the cable the iPod/iPhone comes with?
2006 BMW M Coupe | Interlagos Blue. (Mine)
2008 Yaris Hatch | Absolute Red (Hers)
koala is offline   Reply With Quote
Old 07-14-2009, 12:57 AM   #33
BailOut
BailOut's Avatar
If you only want to play audio from an i* then the cable you already have will do fine. It will also charge from the stereo's port.
If you want to play video from your i* then you will need Pioneer's overpriced cable.
- Brian
Share the Road
Old 07-14-2009, 01:07 AM   #34
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
i have two of those overpriced cables :) need one?
Old 07-14-2009, 01:33 AM   #35
koala
Awesome, thanks for the quick answer.
So... twin DIN install. (NOT Double DIN) Is it possible? WolfWings In Car Entertainment + Electronics (audio / video / alarm) 15 04-01-2009 09:49 AM
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 03:04 AM
Sony XAVW1 double din head unit Julz In Car Entertainment + Electronics (audio / video / alarm) 4 09-09-2007 10:27 PM
