Rear left indicator light not working
Heya,
I was removing the rear TYC Clear tail lights and going back to the oem ones... After putting the stock ones back, i found out that the rear left indicator light wasnt working.... When I switch to the left indicator lights, the console shows the light blinking really fast... I removed the bulb and saw that the filament in the bulb wasnt broken... So, is my rear lights fuse gone off, or do I need to change the bulb???? ![]() ![]()
#2 | |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
The fast flashing does normally indicate an open circuit. That would usually be caused by a burnt out bulb, but it could also mean a broken wire or disconnected plug in the indicator light circuit. If the bulb is OK when you apply battery power to it, start checking the wiring. |
Ok... ill check that
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
check the ground wire...
if you want to see my plans for this car, check out here... http://www.cardomain.com/ride/3154316 i like this smiley...
| Ultra Racing 23mm Rear Stabilizer Bar | Loren | Performance Modifications | 62 | 05-18-2009 07:20 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
