Old 04-25-2009, 08:15 PM   #1
charles nelson
Drives: red Liftback
Trouble with rear lights....
On my 2008 Liftback:
My right rear turn signal light and right rear brake lights do not
come on. The right rear tail does work.
When I turn on the right turn signal...the right flasher light comes
on and off very quickly. The left turn lights work okay and
the flasher clicks at a normal slower rate.
What may be causing the right rear light problem?
charles nelson is offline   Reply With Quote
Old 04-25-2009, 09:36 PM   #2
YAR1S
YAR1S's Avatar
are they aftermarket ones?
I had that problem with my turning signals not coming on because the wires didnt have a good enough connection and the indicator noise was fast almost like it was short circuiting..
ttry taking out the light... and having a look.
It isnt too hard.
-Jen <3
Old 04-26-2009, 09:29 AM   #3
OK Yaris
Drives: 2007 Liftback
A bad light bulb.
OK Yaris is offline   Reply With Quote
Old 04-26-2009, 05:26 PM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
If the turn signal light flashes on and off quickly check two things.
1) Light bulb burnt out? Replace bulb
2) Check fuse.
- Fuse Bad? Replace fuse
- Fuse Good? Turn signal relay needs to be replaced.
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
LED rear lights question Danish Yaris Cosmetic Modifications (Exterior/Interior) 24 04-16-2009 02:26 PM
someone got this? (rear lights) deadcrow Cosmetic Modifications (Exterior/Interior) 7 01-18-2009 01:02 PM
rear fog light and tuned rear lights lefti696 Cosmetic Modifications (Exterior/Interior) 0 11-09-2006 03:06 PM
