Old 04-24-2009, 09:20 PM   #55
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
Originally Posted by whooppee777 View Post
turn head yes. cool/feasable not really
i want to twin charge my yaris
turns head yes, cool/feasable, NOT REALLY
Originally Posted by xnamerxx
you nailed it sir.
Old 04-25-2009, 03:27 AM   #56
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
is there a button on here i can click that prevents the pessimists from posting on the forums?
Old 04-25-2009, 03:39 AM   #57
Tamago
Tamago's Avatar
Drives: ZZW30
yes, here it is
http://www.yarisworld.com/forums/log...124c8e83b90456
you nailed it sir.
Old 04-25-2009, 02:09 PM   #58
whooppee777
your about as funny as kathy griffin.
i understand that lower compression pistons would be required but how will that affect the power output during low boost when only the supercharger is creating the boost? wouldnt there be a loss in power?
Old 04-25-2009, 03:26 PM   #59
whooppee777
Very interesting thread on scionlife
http://www.scionlife.com/forums/view...r=asc&&start=0
Old 04-25-2009, 03:36 PM   #60
Tamago
Tamago's Avatar
Drives: ZZW30
yes there would. but that's why you have the supercharger, right? make boost before the turbo can?
you nailed it sir.
Old 04-25-2009, 03:38 PM   #61
Tamago
Tamago's Avatar
Drives: ZZW30
yes, very interesting:
Alex, read the previous page. This twincharge project is DEAD for me. I've already sold the supercharger. I'm not concentrating on an all-turbo build.
HMMMMMM i wonder why he gave up?
because he realized it's not worth the time/money/weight ?
you nailed it sir.
Old 04-25-2009, 03:48 PM   #62
whooppee777
Tamago is officially an
Did you not graduate from Grade School, because you don't read very well.
vettereddie's last post
"Yeah, the intake temp is what I saw was the biggest issue and why the twincharge varient is NOT happening. If a new manifold was done after the supercharger that had a air-to-water intercooler built in, then it could probably work. Alternately, I could have used meth injection, but on a daily driver that would be a pain to keep filled. "
and on page 3 he elaborates on his reason for not twin charging
"Simply put, the incoming pre-pressurized air would be at elevated temperature. The compressor rotor lobes are metal and do undergo thermal expansion. If the intake temp is too high, they will expand out of tolerance and hit instead of mesh, locking the compressor. Also, methanol can not be injected pre-s/c to cool the rotors because it could displace the oil in the sealed bearings and dry them out, damaging the compressor shaft. Elevated temperature could also de-laminate the anti-friction coating on the lobes, creating a FOD issue in the compressor, or worse, get pulled into the cylinder. "
it had nothing to do with whether it was "worth the time/money/weight"
congrats Tamago, you officially made an ass of yourself.
Old 04-25-2009, 03:52 PM   #63
Tamago
Tamago's Avatar
Drives: ZZW30
wait wait, so i just read what his reasoning was...
sounds like twin charging was a bad idea.
hmm maybe in your head this:
translates into it being a good idea?
you nailed it sir.
Old 04-25-2009, 03:53 PM   #64
Tamago
Tamago's Avatar
Drives: ZZW30
LOL @ your twincharge idea.
you nailed it sir.
Old 04-25-2009, 04:33 PM   #65
whooppee777
that appears to be a bad idea.
i never thought running the boost from the turbo into the s/c compressor was a good idea in the first place. i was considering a manifold that would allow the boost from the turbo to bypass the compressor altogether.
whatever they did is a good idea, if it wasnt a good idea they wouldnt sell it.
Old 04-26-2009, 10:50 PM   #66
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
Just want to share the emails exchanged between me and Brashboy.
----- Original Message -----
To: "Chang Chew Soon" <email masked>
Sent: Friday, April 10, 2009 1:53 PM
Subject: Re: CONTACT US
> Piston set 150,000JPY
> Connecting rods 160,000JPY
> Valve and Valve springe 140,000JPY
> E-manage Blue is good!!
> boost 1.2 is no problem for complete engine.
> And you need big injector, big fuel pump.
> --- Chang Chew Soon <email masked> wrote:
>> Hello,
>> Thank you! Yes I agree it is better to have complete
>> set. Can you please
>> quote me the price for the complete set for the
>> piston, rods, valve and
>> valve spring.
>> I am currently using Trust E-Manage Blue, if I want
>> to boost 1.2 bar is it
>> sufficient?
>> Thank you!
>> Chew Soon
>> From: "千葉 忠成" <brashboy_chiba@yahoo.co.jp>
>> Sent: Friday, April 10, 2009 12:13 PM
>> > Hello.
>> > I have following forged parts for 1NZ-FE.
>> > Had better to install,
>> > Piston (8.5:1)
>> > Connecting Rods
>> > Valve
>> > Valve spring
>> > Our forged 1NZ-FE have over 230ps (Yaris).
>> > Brash Boy JDM Trading, CHIBA
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 04-26-2009, 11:10 PM   #67
whooppee777
thank u. excellent post
Old 04-28-2009, 07:49 PM   #68
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
this is assuming they didn't do exactly what you were thinking of not doing, and it could be why they aren't selling it as a kit. :(
plus they are on the old Vitz platform, wonder how much the ECU setup has changed since?
Russelt3hPirate is offline   Reply With Quote
Old 04-28-2009, 08:02 PM   #69
whooppee777
reading that gave me a head ache
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
So... twin DIN install. (NOT Double DIN) Is it possible? WolfWings In Car Entertainment + Electronics (audio / video / alarm) 15 04-01-2009 09:49 AM
Twin engine Yaris. ddongbap Off-topic / Other Cars / Everything else Discussions 18 12-15-2008 11:54 PM
Twin Charge!!! (the best of both worlds) DollaZo Forced Induction Forum 51 11-15-2008 02:07 PM
JDM STABILIZER CHARGING SYSTEM ketel0ne Performance Modifications 15 09-13-2006 09:56 PM
