Old 05-02-2009, 10:33 PM   #19
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
You are doing all of this without knowing how to get a stuck wheel off? Give it one really good smack with your foot right at the top dead center of the tire with it slightly elevated from the ground. It will come off, just dont hit the wheel
Old 05-02-2009, 10:34 PM   #20
you need penetrating lube....chances are the wheel is rusted to the hub.....
slap a whack of penetrating lube on it and let it sit overnight...i had the same problem w/ my car last spring when taking off my winters...you run w/o hubaps all winter?
Old 05-02-2009, 10:53 PM   #21
Riced-yaris
Drives: 1998 EL, 2000 Civic, 2008 Yari
Thats what my mechanic has told me. So far, I have kicked it. Used 3 different pry bars. HAMMERED it and swore at it lol. Oh and ya, i didnt use Hubcaps, since my g/f Barely drove it this winter. We used my civic mostly.
Riced-yaris is offline   Reply With Quote
Old 05-02-2009, 11:16 PM   #22
ya, i wailed on mine w/ a rubber mallet and got nothing.....penetrating lube for a few hours....boom, headshot
Old 05-02-2009, 11:59 PM   #23
Riced-yaris
Thx for the tip buddy. I sprayed a lot of WD40 onto the lugs and hug. I hope this works, or else its a X-large coffee to the mechanic.
Old 05-03-2009, 12:02 AM   #24
youll want proper penetrating lube....but wd40 may do the trick
Old 05-04-2009, 01:08 PM   #25
MUSKOKA800
MUSKOKA800's Avatar
I put the TRD strut/shocks in with the TRD springs so never experience the springs alone.
Because;
1) Stock dampers aren't designed for higher rate springs. I laugh out loud at the ricers going down the highway bouncing like a pogo stick. Slammed down on stock dampers.
2) There is too much time & skinned knuckles required to swap out the suspension in my driveway. I'd regret doing it all twice because I was 'too cheap' to invest in competent hi-po shocks/struts from the beginning.
Of course, if you have a thick wallet and pay someone else to do the dirty work you may want to give it a try. Your choice.
Old 05-04-2009, 10:04 PM   #26
Riced-yaris
Because;
I agree and know what you mean. But I am not gonna spend this type of cash on the Yaris. I have a proper setup on my Acura EL, but the Yaris, is on lease, so if anythin happens, I'll just swap the stockers back in. The car is finally fully done and rides just like stock
Old 05-04-2009, 10:46 PM   #27
trd's and prokits are mild enough that running stock shocks wont kill them
i had prokits on my matrix for many a kilometer w/o incident
Old 05-05-2009, 12:37 AM   #28
SEVEN
Drives: 07' HB Black
I have had TRD springs for about 1 year prolly 18 to 20K miles on them, my rear shocks are starting to make a creaking noise sou yeah ... saving up for coilovers, I ride hard on them all the time so if I blow a shock before I can affor the coilovers its new shocks for me
When life passes you by ... dowshift
SEVEN is offline   Reply With Quote
Old 05-05-2009, 01:49 AM   #29
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Stock Shocks and Spings with TRD sway bar
Old 05-05-2009, 02:11 PM   #30
kosko
ALF
Drives: 07 Yaris Hatchback 5spd manual
I just hit 58K and am doing fine (which includes about 5 huge speed bumps 4 times a day to and from my house)!
kosko is offline   Reply With Quote
Old 05-05-2009, 02:37 PM   #31
mastaofdisasta
mastaofdisasta's Avatar
Drives: yaris
what can yall tell me bout df210s on stock shocks, as far as handling on a course goes?
ballin on a budget.
mastaofdisasta is offline   Reply With Quote
Old 05-05-2009, 03:08 PM   #32
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
Well I can't say what they are like on a course, but after I put DFs on my stock shocks, the lower center of gravity made curves a lot less dramatic. I also suspect they are the reason it feels a lot less floaty at higher speeds. With the DFs and my rear sway bar, this car handles amazingly well on stock tires.
Stock Shocks and Springs 1k miles regal Items for Sale by private party 2 04-29-2009 04:25 AM
TRD Springs Shocks and Sway Bars IN STOCK Sparks Toyota-TRD Sparks Toyota 0 03-12-2009 10:54 AM
WTB: Stock shocks Walter Willing to Buy by private party 14 01-14-2009 05:29 AM
KYB shocks and Steel stock wheels White Yaris Items for Sale by private party 15 11-18-2008 10:26 PM
Free for Local Pickup: Stock Springs, Shocks & Struts Violin Items for Sale by private party 4 11-14-2008 10:36 PM
