#37 | |
![]() I mean, what's the point of a sporty short gear stick with a momo gear knob, if there's this ugly square ribbed plastic pyramid underneath? |
#38 |
Μine is leather made, that's why.
#39 |
lucky!
#40 |
Thanks!
I also have another question.The transmission stick is covered by a black rubber material.Will it be used after installing the short shifter?
#41 | |
![]() Look at the first post in this thread, I think that's we are both talking baout, right? |
#42 |
Μmm I might have a problem there...
See, your cover is made from leather and mine is made from hard plastic.How will it fit now?
#43 | |
![]() ![]() ![]() Drives: 84 GTI, 90 GTR, 97 Si Join Date: Mar 2006
Kevin TWM Performance |
#44 | |
The first method I use involves 2 flat head screwdrivers and a hammer. I usually hammer a small, thin flat head screwdriver between the clip and the plastic assembly. Once the first screwdriver is between the plastic assembly and the clip, I use another larger flat head screwdriver to pry the clip by inserting it in to the gap created by the first screwdriver. You can work your way around the clip prying with the large screwdriver to work it off. I usually try to break the clip, since once it is cracked it comes off very easily. If you break the clip, don't worry since we provide replacement clips with the shifter kit. The second method I use, if you have access to a Dremel or any rotary cutting tool, is easier. Using the rotary cutting tool and a cutting disc, slice the clip. Once it is sliced it can be pried off easily with a flat head screwdriver. If you run in to problems give us a call at 1-877-655-0540. Kevin TWM Performance |
#45 |
Τhanks for answering!
#46 |
Lean Wit It. Rock Wit It.
Drives: 2007 Yaris Sedan - 5 Speed Join Date: Aug 2006
TWM, indeed I do have a dremel.
awaiting delivery..days do not move fast enough hehe
YARIS... enough said!
#47 |
This is what happens when you are awaiting something good!
#48 |
yup...scheduled delivery for 2morow!!
and the weather reports say its supposed to be a beautiful day in new york!
#49 | |
#50 |
yup...recieved item..just havnt had a chance to install it.. busy lately..install date is set for monday.. pics..and a diy will come..
#51 |
Ιs that true?
#52 |
Installed TWM short shift
I installed my TWM short shifter today. It is awesome.
Very happy with it. I wasnt able to take pics today, but I will tomorrow. I also installed a shift knob that is almost an exact match to the integrated audio center dash.(the beige-silver metallic color) It feels awesome. I definately need to get a different shift boot though. As I'm sure anyone else who got one of these knows, the shift boot is way too huge for the short shifter. Anyways, the install took me about an hour and a half, but only because it took so damn long to get off this one piece. Of course my dremel wasnt working so I had to pry for like 45 minutes at this little washer-like piece. Once that was off it was 1-2-3. Overall - very happy.
#53 |
Νice.
I will post some pics of my transmission cause I am not sure that it will fit.
#54 | |
| TWM Performance Short Shifter | Idjiit | Performance Modifications | 16 | 12-16-2006 06:10 PM |
| TWM Yaris Short Shifter Sale! | TWM Performance | Sponsors Classifieds Area | 9 | 08-28-2006 04:37 PM |
| Custom short shifter | ChinoCharles | Performance Modifications | 13 | 08-20-2006 04:52 PM |
| First to install twm shortshifter!!! I think... | SamDaYarisMan | Performance Modifications | 7 | 08-11-2006 10:33 PM |
| TWM Short Shifter/Shift Knob Sale! | TWM Performance | Performance Modifications | 0 | 07-17-2006 06:08 PM |
