Old 05-10-2009, 03:27 PM   #19
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by skigil View Post
I noticed that since my sub is in where the spare tire used to be (and is facing up), most of the bass stays within the car. The bass can be nice and loud inside the car, but you can barely here it outside the car. It's either the positioning, or the fact that my enclosure needs to be redone in MDF (I did it out of some old 3/4" plywood I had laying around).
Does anyone have thoughts on this?
WOW.... i really can't believe you are complaining.... You've got bass to yourself... and minimal leakage out to the rest of the world... thats near perfect. You're not pissing people off... you're not giving car stereo too bad of a name.... and you want it more outside...
Roll down your windows, fold down your seat, or pop the trunk/hatch. Tho if you did that around me... i'd prolly cut you off and drive 5mph in front of you.
If you want to seriously increase your volume there are basically only two ways to do it that are cost effective. Buying a bigger amp is not cost effective unless you are talking about a 500+rms sub and only have 100w on it.
1: remove any obstacles that are physically inbetween you and the sub (rear seats, Trunk cover if in a spare tire well). Allow that sub to breath!
2: Make a custom box for it that is designed to put higher levels of pressure on the cone. Higher the levels of pressure on the cone the higher the output will be. Ported boxes are awesome... Not all subs play nicely with ported boxes however... And not all ported boxes are designed to be nice to subs... the one found in stores usually are poorly designed.
if you go from sealed to a properly ported design.... you will hear sound outside your car... you will have more rattles... and your sound could be anywhere from 2-10dB louder depending on how you tune it... So go throw on some dynamat/fatmat/raammat cause you will start to annoy the world otherwise.
Old 05-11-2009, 07:09 PM   #20
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
So wait, you want sound outside of your car Just roll your windows down.
Old 05-11-2009, 07:18 PM   #21
PHXDEMON
PHXDEMON's Avatar
Just wanted to point out from experience that a ported box with a fosgate HE2 will go relly low and bump really hard, however it won't hit very "tight" If you listen to nothing but rap,dub-step, and bass tester CDs then it will be great but for just about any other type of music you will sacrifice a lot of accuracy with a ported enclosure.
Old 05-17-2009, 06:24 PM   #22
skigil
skigil's Avatar
Drives: 2008 Yaris Hatchback
Guys, I'm good with bass inside my own car, and I'm fine with out how loud it gets. I was just making sure my setup was correct. And it sounds like it is. I'm going to redo my enclosure in some proper MDF in a couple of weekends. I'm sure that will help my sub sound even cleaner.
I listen to a huge variety of music, so I think I'll stick with a sealed enclosure, rather than a ported one.
skigil is offline   Reply With Quote
Old 05-18-2009, 05:29 PM   #23
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
not true.. the accuracy you speak of is dictated by basically 2 variables. 1) the Le (inductance of the coil) 2) the box size and port tuning. Most applications of ported boxes suck because the box isn't tuned low enough, and the transient response in the 40-60hz range is horrible. Add to that most car subs, especially the more expensive ones that claim higher power handling usually suck at the Le part as well.
Regardless, even a horrible sub can sound fairly accurate if port in a properly designed ported box... and vice versa.
Old 05-18-2009, 08:48 PM   #24
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
in a town close to mine if a cop can hear bass 10ft from the car its a 100 fine the first time $1000 the second time and 3rd time they take the car. for noise pollution.
wicked strict.
my intention is to FEEL the bass in the car i couldnt care less if others can hear it.
Old 05-18-2009, 08:49 PM   #25
IsLNdbOi
IsLNdbOi's Avatar
wicked strict.
I hope those cops get you one day.
Old 05-18-2009, 08:53 PM   #26
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
you've probably seen my setup here on YW .
i used MDF. and made it to specs for the subwoofer i used. sounds great . hits hard for my metal stuff. it can be quite loud when i put some c"Rap" on lol but its all about it feeling the kick drum not synth bass.
you should take the time to tune in to a couple different types of music. i usually will tune the woofer in using something like dave matthews or something that is usually recorded well and has a good range of bass and clear kicks. then i adjust if i have to listening to my metal :) jazz is a great music form to start out with .. nice smooth bass lines and tight kick drums
Old 05-18-2009, 08:53 PM   #27
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
lol
usually they target the kids listening to rap that have like 15" woofers that rumble the neighborhood
Old 05-27-2009, 11:11 PM   #28
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
lol
LMAO thats true it suxs not that i have 15"Subs but i like Rap nothing wrong with that
Originally Posted by sw07gt
Old 10-30-2009, 04:03 PM   #29
sort_o_sane
Yaris GSR LOL
sort_o_sane's Avatar
Drives: 07 Yaris Hatch
My favorite is the guys near me with their old Chevy vans. I got to watch one of these geniuses put a dual kicker comp ported box in the back of his (POS) Chevy van that just barely ran.
I see no sense in having a nice system in a piece of crap car...unless you are trying to drown out the clanks, rattles, shaking and other death cries the car might be making.
07 Yaris hatchback purchased in Dec '06. April 2015 and 103k miles, brakes finally needed changing, original battery finally died. I love this car.
sort_o_sane is offline   Reply With Quote
The First Annual Kevin Duckworth Scholarship Car Show kingpincaraudio Northwest 5 06-24-2009 02:32 PM
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 10:03 AM
Custom Lftback - Photo-Scavenger Hunt custom Lftback Photo-Video-Media Gallery 2 03-02-2009 12:12 AM
Darb - Photo Scavenger Hunt Darb Photo-Video-Media Gallery 3 03-01-2009 10:02 PM
TRD, DC Sports, Nitto, Greddy Ti-c Inside car Video Clip Jerkratt Performance Modifications 7 12-24-2008 05:19 PM
