Old 05-04-2009, 12:28 AM   #1
Pitt Yaris
Drives: Flint Mica Sedan
Progressive vs Linear Springs
I searched the forum, then googled this and read about them on numerous forums, but would like feedback from yaris drivers - Advantages/Disadvantages. Most posters on other forums said linear are better for track days/hard driving, and progressive are better for simple street driving. I know tanabe springs are linear, but what other brands of springs are linear and which are progressive? I'm assuming progress springs are progressive due to name/brand, lol.....?
Old 05-04-2009, 02:18 AM   #2
YarisSedan
Drives: 08 Yaris Sedan
I think progressive their spring rate progresses as they are further compressed which is typical of road dips taken at high speeds. So it gives you a near factory ride during round town driving and freeway speeds and hard corners gives you the benifits of a higher spring rate.
Linear spring rate never changes which is good for track but local town driving it will be a little unconfortable.
Old 05-04-2009, 05:02 AM   #3
eibach and canuck motorsports are progressive
i had eibach prokits on my matrix...pretty comfy for a DD and nice how they firm up when you push it...
Old 05-04-2009, 02:26 PM   #4
Pitt Yaris
What about progress springs that garm sells?
Old 05-04-2009, 02:41 PM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
the progress springs are also progressive.
Old 05-04-2009, 07:09 PM   #6
i say check their website and/or email them...
Old 05-04-2009, 07:59 PM   #7
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
leaving the differences between one and the other on the side....
ALL the available bolt on springs for the Yaris are progressive.
If you want linear springs you will need coilovers or do some custom modifications to the suspension in order to be able to fit universal linear springs.
Old 05-10-2009, 10:49 PM   #8
Pitt Yaris
I googled, but can someone with more knowledge break down which springs are linear and which progressive? I know that the tanabe springs are linear and tein s.tech are progressive, but what about other brands such as progress, megan, etc?
Old 05-10-2009, 11:24 PM   #9
Pitt Yaris
It seems most all are linear.
Old 05-10-2009, 11:54 PM   #10
I think so, but I've notice that more companies are popping up with progressive springs.
Old 05-11-2009, 12:27 AM   #11
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
Most coilover setups use Linear. Most lowereing springs are progressive.
You can usually tell by the way they are shaped.
Sponsors and Organizations:
Toyota Rally Canada
Yokohama Tire Canada
Western Canada Rally Association
Ecurie (Team) Snoopy Canada, racing since 1966
mojoyaris is offline   Reply With Quote
Old 05-11-2009, 01:37 PM   #12
Pitt Yaris
What shape determines what? Wouldn't most lowering springs *non coilovers* be linear since they post their rates, etc?
Old 05-11-2009, 02:35 PM   #13
H&R are progressive springs. They don't publish spring rates.
Old 05-11-2009, 04:35 PM   #14
CASTREX
CASTREX's Avatar
.... as I already mentioned a few post above...
ALL, meaning ALL available replacement springs currently available for the Yaris are progressive.
The spring rates that the companies such as tanabe / tein publish are aproximates or average (not sure what method they use)
The lowering springs (Tanabe / Megan / Tein / H&R) are sporty springs... not really race springs. Threfore these need to maintain a decent level of confort. Hence these companies use a progressive design.
Coilovers on the other side use (must of them) linear springs as they have more agressive shocks.
My Tein Basic Coilovers uses a combined set up. Linear springs on the front and progresive on the front...
But then again, these are not race coilovers...
Old 05-11-2009, 09:09 PM   #15
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Drives: 2008 Yaris LB
You can tell by the spacing and width of the spring. If the spacing and width are the same between every coil then it's most likely linear. If the spacing and width vary between coils then it's most likely progressive. Some coilovers have two linear springs of various spring rates. The soft spring rate spring is often a short spring, just a few centimeters tall usually.
_________________________________________________
Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers
Jeemee is offline   Reply With Quote
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
TRD Springs Vs Tanabe DF210...The Title Bout detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 47 05-23-2009 10:02 PM
What springs should I get? Help! CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 01-26-2009 06:32 PM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
