Old 04-28-2009, 05:10 AM   #1
xtremesniper
Drives: 2009 Yaris HB RS
Question Weird issue during braking
I'm not sure if this is really an issue, but I thought I'd try to explain it on here to see if I'm the only one with it or not.
Basically, there are times when I approach a stop light or a speed hump where I'll either gently press on the brakes to slow down from lets say 40 to 20km/h, or just to a full stop (in the case of a stop light), or I'll let the car glide to a slower speed (and sometimes the Yaris does its own "engine braking"). During this slow down, sometimes it kind of feels like a certain part of the brake pad is tighter than the other. That's the best way to explain it I think, because you'll feel like there's a slight/subtle tapping of the brake that I'm not actually doing every half second (possibly every revolution of the wheel). It seems to only happen when slowing down from an already fairly slow speed, which is why I only feel it sometimes because I'm usually driving on roads with a higher speed limit.
Anyone know what I'm talking about? Should I go in to get this checked out?
xtremesniper is offline   Reply With Quote
Old 05-11-2009, 01:00 AM   #2
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
It could be your brakes pads are unevenly worn or your rotors need resurfacing???
Sponsors and Organizations:
Toyota Rally Canada
Yokohama Tire Canada
Western Canada Rally Association
Ecurie (Team) Snoopy Canada, racing since 1966
mojoyaris is offline   Reply With Quote
Old 05-11-2009, 02:22 AM   #3
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Automatic transmission, right?
Old 05-11-2009, 04:26 AM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Don't the RS Yaris over there have ABS, with Brake assist ,
In New Zealand they do , that would be your answer
Old 05-11-2009, 04:31 AM   #5
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
for US cars. when braking going down the hill, the brake does to brake on it's own too. it may be the ABS kicking in. i don't think it should be a problem for you.
808_Yaris is offline   Reply With Quote
Old 05-11-2009, 09:18 AM   #6
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
there's no way that the ABS is actuating automatically while going down a hill lol..
Originally Posted by xnamerxx
you nailed it sir.
Old 05-11-2009, 12:21 PM   #7
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Maybe higher rpms when rolling down the hill slows down the car while breaking ?
Old 05-11-2009, 12:53 PM   #8
xtremesniper
That's what I was thinking...
Yes.
I don't think ABS would kick in while going downhill. I do know that the Yaris simulates engine braking, but ABS should only kick in when slamming down the brakes, not when gliding to a slower speed. Besides, my issue happens even on flat roads just letting off the accelerator and gliding to a slower speed.
Yeah..
So I'm still thinking about if I should take it to the dealer to have it checked out. I'm just worried about how long it might take to investigate and fix if necessary.
Old 05-11-2009, 02:20 PM   #9
supmet
Drives: 2007 4 Door Yaris
If they'll check for free(even though they didn't for me when I was still under warranty) then go ahead, but I'd take it to Midas for brakes before the dealer. The dealer I took it to said it was normal for me to have to replace pads and rotors every 10,000 miles because I live in a hilly area. They charged me 50 bucks and I'm pretty sure they didn't even get the tires off. Only time I took my car to the dealership, and will definitely be the last.
I bought the R1 concepts rotors and carbotech pads from garm, and haven't had any brake problems since.
Old 05-11-2009, 02:39 PM   #10
Loren
What?
Loren's Avatar
My bet is that you're simply feeling the transmission downshift as you decelerate.
Old 05-11-2009, 03:49 PM   #11
xtremesniper
Yeah it would be for free, I'm sure.. I've only owned it for a few weeks now.
I was thinking about this, but I don't think that's it. Transmission downshift wouldn't feel like tapping the brake repeatedly, would it? When I drove the Echo it would speed up just a tad right as it downshifted, which I got used to. What's throwing me off is that it isn't happening all the time. From faster (normal) speeds to stopping, I don't feel it at all. The Yaris stops very smoothly and as I'd expect.
This particular feeling only comes about when I'm going slow, and I let go of the gas (for example, in anticipation of a red light or a speed bump) and then I realize the car is acting as if I'm tapping the brake over and over again, and the car slows down much faster than I expect, causing me to have to press the gas again even when in the Echo I wouldn't have had to.
Old 05-11-2009, 04:14 PM   #12
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
How old is the car? Have you had tire work done? Have your wheels been taken off and put back on recently? If so, check your lug nut torque. 76ft/lbs is correct torque for Yaris lug nuts.
Myine was doing the exact same think. Kind of a pulsing feel like warped rotors. Turns out the guy that put my tires on over-torqued my lug nuts. Just getting them to correct torque fixed mine 95%. Now it's just a slight feeling when braking and it's getting better the more I drive it.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 05-11-2009, 04:16 PM   #13
xtremesniper
Actually the car is very new. Only a few weeks old and had just under 50km on it when I picked it up.
Old 05-11-2009, 04:18 PM   #14
nsmitchell
nsmitchell's Avatar
I would still check the torque on them. Some mechanic may have over-torqued them unknowingly.
Get YarAss in gear!
RIP - Casey Tatum
Old 05-11-2009, 04:22 PM   #15
xtremesniper
I'm not quite sure of how to check that, but I know someone who owns a body shop. I guess I'll ask him when I get the chance. Thanks for the suggestion.
Old 05-11-2009, 04:25 PM   #16
nsmitchell
nsmitchell's Avatar
You just need a torque-wrench and a 17mm or 19mm socket. You can borrow tools from Advance or Napa. You can check it in the parking lot. I'll bet they would do it for you if they're not busy.
Get YarAss in gear!
RIP - Casey Tatum
Old 05-11-2009, 04:30 PM   #17
YarisSedan
Drives: 08 Yaris Sedan
Yeah as your engine downshifts it will feel like the car is going to lug slightly or in your case it will feel like the brakes had just became slightly more efficient. Since vehicl eis using transmission to slow down the speed of the car.
Old 05-11-2009, 04:37 PM   #18
nsmitchell
nsmitchell's Avatar
Toyota will definitely check your torque for you.
Get YarAss in gear!
RIP - Casey Tatum
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 09:04 PM
"Tok" Sound when braking at low speeds (less than 10kmph) buchieboy General Yaris / Vitz Discussion 30 02-16-2009 07:50 PM
CONSUMER REPORTS : MARCH issue reviews '09 YARIS . gid General Yaris / Vitz Discussion 93 01-06-2009 05:10 AM
Weird rattle coming from teh egg. Impresive-G DIY / Maintenance / Service 14 11-10-2008 04:22 AM
A/C smelling weird? Yaris_PR General Yaris / Vitz Discussion 11 08-04-2006 09:26 AM
