Old 05-14-2009, 12:06 PM   #1
Gazdaman
Drives: Corsa 1.2 8v
Help - OBDII error code "system running lean"
Hi,
my girlfriend's had a 99 Yaris for a few years now. The engine light's been on for a while, and it's been a pain picking up off idle, worse when cold.
It runs fine, other than this flat spot very low in the rev range. And returns good mpg.
Anyway, I bought an OBDII error reader which read code p0171 which is "system running lean".
So I'm guessing it's a sensor, but I don't know where. I replaced the spark plugs recently which didn't help. A clogged air filter would make it run rich. So I'm thinking dirty injectors? Dodgy fuel management? Lambda sensor?
Anyone got any input?
Ga
Gazdaman is offline   Reply With Quote
Old 05-14-2009, 12:09 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
could be a bad oxygen sensor
could be clogged injectors.
i'd start with the o2 sensor first.
Originally Posted by xnamerxx
you nailed it sir.
Old 05-14-2009, 12:10 PM   #3
Gazdaman
Just checked eBay WOW they're expensive! Might try a breakers.
Gaz
Old 05-14-2009, 12:30 PM   #4
Tamago
Tamago's Avatar
Drives: ZZW30
Gaz
in the US they're around $100..
http://www.google.co.uk/products?q=o...sor+1999+yaris
you nailed it sir.
Old 05-14-2009, 12:34 PM   #5
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Try using a good fuel injector cleaner in your gas. If it shows improvement, run it again.
Tags
lean, odbii, yaris
