Old 05-18-2009, 01:35 AM   #217
Yaris T-Sport.
Yaris T-Sport.'s Avatar
Drives: .
Originally Posted by PHXDEMON View Post
CEL was gone. Car completely died and wouldn't even idle. Start it up and it woul ddie instantly. I used the original gasket plus gasket maker, I did the coolant bypass, I did the chip swap. I did everything it just didn't work out for me
That could be pretty much the 1ZZ T/B itself being the problem, try another different 1ZZ T/B or try the 2AZ-FE 2.4L T/B.
remember! failing is the beginning of success, it wasn't easy for me either
Yaris T-Sport. is offline   Reply With Quote
Old 05-18-2009, 01:35 AM   #218
jkuchta
Drives: 2007 Yaris hatch (red)
Bummer...
Do you know what the code for the CEL you were getting was? It may provide some clues as to what caused your problem.
jkuchta is offline   Reply With Quote
Old 05-20-2009, 08:35 PM   #219
bieniman
bieniman's Avatar
Drives: vitz rs 1500 2001
Guys,
I've been following this mod for a while now,
If I'm correct the newer yaris models have electronically controlled TB. Well, I looked under my hood and see sort of like a cable running from the pedal to the TB, I can rev my engine by turning this swivel.
bieniman is offline   Reply With Quote
Old 05-20-2009, 08:38 PM   #220
bieniman
bieniman's Avatar
O yeah forgot to ask.
Can I do this mod also to my , Vitz Rs 2001?????
Old 05-20-2009, 09:00 PM   #221
enviri
enviri's Avatar
Drives: 2010 Yaris
dude! i was about to put it on! now im gonna have second thoughts or get garm's! jeez...i think there HAS to be something we're missing...a hidden variable thats affecting some of us...
Well the CEL finally disappeared and it ran great for about a mile. and then this
Fuck this throttle body. Put the stocker back on and it is running great.
Old 05-20-2009, 09:12 PM   #222
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Originally Posted by bieniman View Post
Guys,
Yes, this mod only applies to the Drive by wire system that is in the ( i believe) '05 and newer
Old 05-20-2009, 09:13 PM   #223
AlexNet0
AlexNet0's Avatar
doesnt sound like the TB unless a wire snapped somewhere.
Old 05-20-2009, 09:31 PM   #224
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Stocker works flawless though so it isn't a wiring issue.
Old 05-20-2009, 09:33 PM   #225
PHXDEMON
PHXDEMON's Avatar
Guys,
I'm not 100% positive on this but the scion xa/xb owners have done a swap with an older 1zz throttle body which is drive by cable like yours. check the forums @ scionlife.com you should be able to dig up more info.
Old 05-21-2009, 12:53 AM   #226
MGargano
Drives: 2009 Yaris Hatchback
The chip swap was working fine for me... no CEL or oscillation... until I had to disconnect the battery to swap the steering wheel. Once I reconnected, oscillation & CELs galore.
Old 05-21-2009, 03:10 AM   #227
jkuchta
What codes are showing up?
Just saying you have a CEL is kind of worthless unless we know what the code is. It could be just a case of needing to adjust the idle set screw, or a number of other things.
Old 05-21-2009, 03:13 AM   #228
MGargano
P0505- Idle Malfunction
Old 05-21-2009, 03:46 AM   #229
jkuchta
Have you adjusted the idle screw? If you've turned the screw out too far you could get this code...try turning the screw in one or two turns (with the car off). This should fix the problem.
If you haven't adjusted the idle set screw, turn it counter-clockwise 1.5 turns (with the engine off), and see what happens.
Old 05-21-2009, 09:39 AM   #230
MGargano
I haven't touched the idle screw at all. The thing was working perfectly for over a month, right up until I disconnected the battery. I'm not going through this every time I disconnect the battery... plus, even when it's working perfectly, the high idle is now quite loud with the exhaust I have. I'm 99% I'm switching back to the stocker today.
Old 05-21-2009, 09:41 AM   #231
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
any one has a DYI on how to install the TB? I am looking through tha manuall and drawing a blank. Do i need anything special?
Old 05-21-2009, 01:26 PM   #232
jkuchta
If you turn the idle set screw out about a turn and a half, all of your problems will go away.
When you leave the screw is the "corolla" position, the yaris ECU adjusts the idle fuel to get a stable idle. This takes time, as the ECU needs to make some pretty big changes. When you adjust the idle set screw to the correct position, the ECU doesn't have to work nearly as hard to get a normal idle, so the ECU doesn't freak out.
The idle rpm fluctuations are a result of the ECU hunting for the right fueling to maintain a steady 600-700 rpm idle in the face of way too much air going through an unadjusted corolla TB.
The P0505 code is the ECU saying..."WTF!!...Why can't I idle at the fuel trims I'm programmed with...something must be wrong!!"
Old 05-21-2009, 02:02 PM   #233
AlexNet0
AlexNet0's Avatar
If you search, you will find it. there have been like 3
Old 05-21-2009, 02:24 PM   #234
Yoda
Yoda's Avatar
thx it wasnt too hard so i didnt need the diy. Didnt do the chip swap gonna see what other means there are to eliminate the cel if i get any.
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
