Old 10-28-2008, 07:13 PM   #1
DanQ
DanQ's Avatar
Drives: 08 Yaris LB
DIY Variable Speed wiper stalk install
This was originally posted by Violin but was lost after the hack. Here is what I could find off of the google cache. Thanks Violin!
With the wheels straight ahead, put a piece of tape with a line drawn on it to mark the center position of the steering wheel.
DISCONNECT THE NEGATIVE BATTERY CABLE and go surf internet porn or something. I wait at least 5 minutes to be sure that the airbag is safely asleep.
Use a #30 torx wrench and remove the bolts at the back of the steering wheel. They won’t come out; just loosen them all the way.
Pull the airbag.
Unplug the horn wire, pop up the little yellow tabs on the airbag plugs and remove them.
Set the airbag aside with the Toyota emblem facing up.
Remove the center nut from the steering wheel.
Using a steering wheel puller, remove the steering wheel and set it aside.
Remove the three screws holding the cowling in place and pop it apart.
Unplug the two connectors on the wiper stalk.
Depress the clip holding the wiper stalk in place and remove it.
Install the new wiper stalk so that it clicks into place.
Plug the two connectors into the new stalk.
Reattach the cowling.
Wind this center spiral cable counterclockwise all the way until it won’t turn any more. Turn it back clockwise 2.5 turns and align the marks at the bottom.
Put the steering wheel back on and align your tape marks.
Reinstall the center nut.
Plug in the airbag and horn.
Tighten the torx screws in the back and you’re done!
The variable speed front works but the intermittent rear won’t without additional wiring.
Total elapsed time: 30 minutes including taking photos.
Thanks Violin..... I wanted to get this reposted before it disappeared from google cache...DanQ
DanQ's DIY Keyless Entry
DanQ is offline   Reply With Quote
Old 10-28-2008, 07:15 PM   #2
DanQ
DanQ's Avatar
Drives: 08 Yaris LB
wiper lever install
In the same thread "chipchip" responded:
When installing the wiper switch there is no need for removing the steering wheel. I had no trouble when I removed the plastic steering shaft shrowd halves. After removing the 3 fasteners take care when pressing in on the side seams and wiggle- pull apart. If you are not carefull you might break the clips. It would be interesting to see if someone has purchased the smaller female plug from a Matrix with the extra wiring and figure out where this extra wire goes. Maybe it's a ground? If so you would only have to run it to a fastener thru metal and attach. I will talk to an auto technician and see what he thinks. Chipchip......If anyone is tired of having their Yaris floor matt hooks come out when you slide your feet forward while getting into the drivers seat then carefully drill a small hole in the center of the plug end of the hooks. Then get a short screw that when screwed through will force the inner clips out and keep them there. Make sure the clips are through the holes before screwing the screws in.
Old 10-28-2008, 07:16 PM   #3
DanQ
DanQ's Avatar
Drives: 08 Yaris LB
Toyota Part number
Part # 84652-48180 wiper switch for Yaris upgrade.
Old 10-28-2008, 08:09 PM   #4
Klink10
Klink10's Avatar
Thank you very much.
Old 10-28-2008, 08:26 PM   #5
CB900F2
Drives: 08 Sedan
For the Sedan version, is it the 07+ Camry wiper control unit that works
CB900F2 is offline   Reply With Quote
Old 11-05-2008, 11:21 PM   #6
KoDoK NyeLeM
KoDoK NyeLeM's Avatar
Drives: "06E and "11S NCP91
Is this RHD or LHD?
KoDoK NyeLeM is offline   Reply With Quote
Old 11-06-2008, 09:29 AM   #7
IllusionX
Drives: 07 Yaris Sedan Aero
i thought RHD or LHD, both have wiper switch arm on the right? and the flasher on the left?
Old 11-06-2008, 10:23 AM   #8
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Great recovery work DanQ!
Thanks!
Old 05-18-2009, 08:24 PM   #9
spookz
JDM yO!
Drives: '09 3dr. 5-spd
Sorry to revive an old thread, is the steering wheel puller tool, compulsory to remove the steering wheel? And just as a question, how would I access the headlight stalk to replace it, it appears to be behind the centre spiral piece? So do I have to remove the centre spiral piece too?
Thanks in advance.
Old 05-19-2009, 08:55 AM   #10
Klink10
Klink10's Avatar
Thanks in advance.
Having changed out my wheel I can answer that a wheel puller is not needed. I gently tapped with a rubber mallet and the wheel lifted right off. As I recall, I performed the wheel change in about 30 min.
I can't help with the headlight issue....sorry.
Old 05-19-2009, 09:56 AM   #11
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Thanks in advance.
I had to use the puller tool but it was cheap ($20 at Napa).
DerFlosser is offline   Reply With Quote
Old 05-23-2009, 12:43 AM   #12
AlainMikli
AlainMikli's Avatar
How much is that stalk from sparks toyota?
To do: Supercharger…
Old 05-23-2009, 01:17 AM   #13
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
you don't need too remove the steering wheel for this mod, unless you
are putting the fog light combo stalk on as well
Old 05-23-2009, 01:52 AM   #14
supmet
Drives: 2007 4 Door Yaris
I'd hope so... I'd have to keep the car for a few millennia to break even on time spent/saved doing it this way.
A DIY without removing the wheel/airbag would be great.
Old 05-23-2009, 04:30 AM   #15
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
do all the steps as above, apart from the ones that are too do
with the removal and putting on of the steering wheel.
just remove steering colum couling and unplug and un clip stalk ,
clip in new stalk plug in wires. reattach couling done , in 10min's max
Old 07-07-2009, 03:01 PM   #16
luigi
luigi's Avatar
Drives: '07 Sedan
Looking at the ToyoDIY, the 07 Camry switch looks veeeeerrrrrrry similar to the ones suggested above. Have any sedaners verified it'll work?
I'll keep an eye out for one, or convince my Camry owning friend to let me borrow his. *crosses fingers*
luigi is offline   Reply With Quote
Old 04-22-2011, 12:16 PM   #17
group2racer
Drives: 2008 yaris sedan
2008 Yaris Sedan wiper switch swap
I bought a new 2008 Camry wiper switch with variable speed intermittent settings (the whole reason for the swap) from my friendly local Toy dealer. Pulled the two plastic shells around the wheel, apart. Carefully unplugged the connectors from the factory switch, and plugged in the new. One of the smarter decisions I've made in my life! Happy Swapping!
My other car is a 65 Shelby with a couple of extra horses than my beloved Yaris Sedan!! and yes dang it, I love my Yaris. Just wish Toyota had a better design for the funky storage little nooks and crannies in the cabin. Also would like to see them put turn signals on the outside mirrors. Scion does! How about factory installed steering wheel radio and cellphone controls? Hey Toyota, you do this for cars you sell in Pakistan, why not the US bound units???!! What gives? We help keep your doors open man. You need to better equip cars you send here.
Peace out!
Amir
group2racer is offline   Reply With Quote
Old 04-22-2011, 02:44 PM   #18
CB900F2
Drives: 08 Sedan
Hi Group.. Do you mind posting the part# of the wiper switch? I am thinking of changing out mine on my sedan also
Peace out!
Amir
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Factory armrest install DIY. PetersRedYaris DIY / Maintenance / Service 16 07-27-2012 06:25 AM
Megan Coilover install DIY kapo DIY / Maintenance / Service 5 09-24-2007 08:20 PM
DIY Sedan Spoiler Install Interest? Kaotic Lazagna DIY / Maintenance / Service 28 09-12-2007 12:02 AM
Speed sensor for navigation install saue1436 In Car Entertainment + Electronics (audio / video / alarm) 5 04-12-2007 10:40 PM
