#199 | |
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
typed in toyota single din and found this what u reckon? http://cgi.ebay.co.uk/Toyota-Verso-t...3%3A1|294%3A50 or even this one http://cgi.ebay.com/ebaymotors/METRA...fAudioQ5fVideo |
#200 |
#201 | |
"Please not if you are installing a stereo into a Japanese vehicle you will need the dearer din pocket kit as the standard width of a Japanese aperture is smaller than din size and the pocket has to fit from behind." So, I think you need one which attaches to the brackets with screws, rather than a snap-in one. |
#202 | ||
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=350203320551 |
#203 |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
This is the Toyota one with the door:
http://cgi.ebay.co.uk/DIN-Pocket-Tra...3%3A1|294%3A50 found it after 5 seconds of searching. |
#204 | |
This would work: http://cgi.ebay.co.uk/Autoleads-FP-0...3%3A1|294%3A50 |
#205 | |
#206 | |
ima go into my local dealer and see how much i can get the three parts for and hopefully they will have it!! i let you know how it goes. maybe pm you becus i used like a whole page in this thread
#207 |
"Well the prices are similar, in order to actually supply you with something I will adjust the postage a bit laugh.gif
Total price inc delivery 107.42" managed to get the three parts for little bit cheaper after asking around was orginally £118. also ordered http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=260363938539hopefully will be here for friday!!!!! i let you know how it goes!!! once again Thanks! cant wait!!!! i think i might need adapter so it can fit the alpine system right?
#208 | |
Yes, you need a wiring harness adapter: http://cgi.ebay.co.uk/TOYOTA-YARIS-R...3286.m63.l1177 |
#209 | |
#210 | |
If possible, can you post pictures of your modified mounting brackets? Which of the positioning dimples did you grind off on each bracket? So the new trim piece doesn't rest on the face frame of your head unit? If not, don't you see a gap / empty space around the face frame of your head unit (between the face frame and the trim piece)? |
#211 | |
If possible, can you take and post up a picture of the side of your HU, as well as one of the mounting bracket. I will then use those to show you what I did. The trim piece does rest on the HU. When the trim reaches the point where it snaps into place, the back side of the opening just meets up with the 'flange' on the face frame.
#212 | |
Here's a picture of the left bracket. You can see the six alignment bumps. Radio Bracket.jpg |
#213 |
Scott,
Can you give me two pictures of the bracket standing on its end as if it was in its mounted position. I would like one of both the inside, and outside of the bracket. It would be my intent to combine bracket photos, with one of the side of the HU so that I may draw arrows between the two to indicate re-alignment positioning. Thanks.
#214 | |
Stock Radio Mounting Brackets.jpg Both brackets viewed from front: Both Brackets.jpg Left Bracket: Left Bracket.jpg Right Bracket: Right Bracket.jpg |
#215 |
Yarisomniac
Drives: 2009 5spd LB Join Date: Nov 2008
I had to do this too, in my case I took a ball peen hammer and bashed down the alignment bumps, and then I slotted out the holes so that I could slide my HU further back so that it is almost flush with the new trim - slightly proud. It looks much better this way. It did take some back and forth to get it exactly how I wanted it, but damn it looks sweet.
#216 |
This pic should work for now.
It may have been blind luck that I was able to achieve the exact amount of movement required for my JVC HU.
| Dash destroyed in electrical fire. | purpleminx | General Yaris / Vitz Discussion | 79 | 06-12-2009 04:53 PM |
| [Recovered] Group Buy for Australia #1 (Badges) | harveyjai | Australia | 9 | 12-13-2008 04:59 PM |
