Old 05-18-2009, 04:40 PM   #19
Tamago
Tamago's Avatar
Drives: ZZW30
Originally Posted by gwasabi View Post
lol you dont have to comment on everything i say though. maybe like once in a while ignore me? lol
Thsat turbine tech one looks like its going up? i dunno lol
i ignored your original comment, didn't i?
Old 05-18-2009, 04:54 PM   #20
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Back on topic....
You can get the bends and turbo flangers here:
http://www.jgstools.com/turbo/index2.html
You would only need take out the OE exhaust manifold and take it to a shop to have the engine flanger done and welded to the rest...
You can duplicate the manifold design from Turbotoyotas (Cali's manifold) simple and functional.
Sure an EL mani is cool... but hard to fit on a Yaris and not really needed for the low boost levels this engine will ever see...
... And regarding the Cast vs welded tubular design.
Cast manifolds will always beat the tubulars on reliability and longevity that's why must of the OE turbo cars use as cast manifold. nothing wrong with them.
Tubular welded manifolds will usually flow better and provided more power... plus they look nicer.
But then again, all this is irrelevant at the boost levels this engine will see...
Old 05-18-2009, 07:05 PM   #21
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
why intercool it?
might as well make things easier and not intercool.
it'd be a lot cheaper too.
Russelt3hPirate is offline   Reply With Quote
Old 05-18-2009, 08:08 PM   #22
Tamago
Tamago's Avatar
Drives: ZZW30
Originally Posted by Russelt3hPirate View Post
why intercool it?
a car isn't turbo unless it has an intercooler. and it's not making real power unless it's a front mount.
didn't you know?
Old 05-18-2009, 08:21 PM   #23
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
loloolol, we don't know if you'll get det though from not running and intercooler... holdeners kit blew the engine when he was close to done tuning it with no intercooler...
Next im sure well get someone in here saying 6psi on a GT20 is the same as 6psi on a GT30 :D
Old 05-18-2009, 08:50 PM   #24
cdydjded
Drives: Yaris LB Turbo
why intercool it?
Safer, makes more power, less likely for detination, easier is not better, what is cheap now will cost you more later
cdydjded is offline   Reply With Quote
Old 05-18-2009, 08:57 PM   #25
Tamago
Tamago's Avatar
Drives: ZZW30
6psi, intercooler is a waste.
run meth injection instead.
Old 05-18-2009, 08:58 PM   #26
Tamago
Tamago's Avatar
Drives: ZZW30
not from me you won't
Old 05-18-2009, 09:28 PM   #27
Nexus1155
Drives: Audi
hahaha i really lol'ed when i read that tamago....... but he's got a point, meth injection would be a feasable option to stabilize the balance, it would be about the same amount of money it would cost for an intercooler and piping, if not less. AND it would be less charge travel through pipes so not much efficiency loss... I say he's got a damn good point...
Old 05-18-2009, 09:38 PM   #28
Tamago
Tamago's Avatar
Drives: ZZW30
=what is cheap now will cost you more later
you mean something along the lines of running half an FIC and unplugging the stock o2 sensor?
Old 05-18-2009, 09:39 PM   #29
cdydjded
A front mount does not need to be refilled, I think the waste would be refilling that little bottle every other day. Your comment makes no sense , why would a cooler, denser air charge be a a waste? Please think before you answer, I do not generalities........
Old 05-18-2009, 09:41 PM   #30
Tamago
Tamago's Avatar
Drives: ZZW30
let's see..
small engine
small turbo
15 feet of intercooler piping
1 psi drop thru cooler..
just to be able to say you have a front mount?
i'm not anti-intercooler, i just think front mounts are retarded in low boost applications. even the supra TT came with simple side mount intercoolers FROM THE FACTORY.
and since when does one burn through 2 gallons of water/meth every other day? you don't know anything about meth injection do you?
oh and i find it funny you say you RAN a speed shop in miami. what happened? RAN? why not RUNNING?
Old 05-18-2009, 09:44 PM   #31
cdydjded
Listen, based on your smart ass remark I can tell you never used a FIC & have a reading comprehension problem. The FIC has 4 programable maps. Fuel, Ignition, O2 & MAF. AEM recomends to use the least amount of maps. Right now I have control of Fuel & Timing. Im not running a turbo yet so there is no need to clamp the MAF or manipulate the O20 signal. So basically its installed & works. Also I did not unplug the stock O2 sensor, I unplug the connection from the FIC to the O2.
Old 05-18-2009, 09:46 PM   #32
cdydjded
I dont run a speed shop anymore cuase I moved up in the world. If you want details I RUN the inventory department at Wheels Next. I also RUN my own wholesale business on the side.
Old 05-18-2009, 09:52 PM   #33
Tamago
Tamago's Avatar
Drives: ZZW30
1. i have an FIC mounted and wired by me in my car.
2. iirc you already burned up your stock o2 sensor..
bad wiring?
Old 05-18-2009, 10:00 PM   #34
cdydjded
bad wiring?
Congratulation on havin a FIC, based on what facts do you claim I burned my O2?
Old 05-18-2009, 10:04 PM   #35
Tamago
Tamago's Avatar
Drives: ZZW30
I disconnected the connection to the O2 & still have a CEL, I might have screwed up the O2
and what happened to you being SO SURE that i know nothing about the FIC?
Old 05-18-2009, 11:07 PM   #36
cdydjded
Is that the best you can do, answer a question with a question? Wow you owna FIC, so does that make you the King of the FIC, all hail Tamago the king of the FIC! Or can I call you "sweet egg omlet" since thats is what Tamago translates to in Japanese?
Chino's Turbo Thread ChinoCharles Forced Induction Forum 299 03-17-2017 09:01 AM
GI: Turbo Manifold ChinoCharles Forced Induction Forum 4 04-13-2009 02:42 AM
xa/xb Turbo manifold for Custom set up CASTREX Forced Induction Forum 1 01-21-2009 03:43 PM
Why industries turbo manifold? anonymous user Forced Induction Forum 33 12-07-2008 02:11 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 03:26 PM
