Drives: 2009 Yaris Black LB, Auto Join Date: May 2009
New Owner - Lights on Gear Shift
I'm happy to see there is a forum for Yaris owners. I'm looking forward to learning more about my new car.
That said...I have a complaint. I've only been driving it for a couple of days. I did a search on lights on the gear shift in the forum here and found several threads about there being no lights on the gear shift positions. I park in a underground garage and can't see what gear I'm in when pulling in or out of my spot. I understand I can turn on my lights, but I'm just astounded that Toyota wouldn't put lights on the gear shift. I haven't been driving it long enough to know what gear is where and I don't find stumbling around in the dark for the right gear to be a safe or acceptable solution. Does anyone know if there is an aftermarket fix for this? Thank you. |
What?
No fix is required. Give yourself a little time to learn the car, you'll instinctively know where the gears are instantly without needing to look or even think about it.
Seriously, it will be as natural as scratching your nose. You don't need a light on to do that, right?
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Congrats on your new Yaris and welcome to YW!
![]() I agree with Loren. It takes a little while to get used to the Yaris. It took me almost a month before I stopped getting weirded-out by the gauges in the center. See if you can find the cupholders lol. By the way, what part of Pasadena you from?
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
Taking care of Bubbles
Drives: 2009 Yaris LB "Bubbles" Join Date: Apr 2009
My car which is a 2009 auto LB, shows me what gear I'm in on the dash above the odometer.
2009 Absolutely Red LB. "Bubbles" |
resident senior
Addendum to what Loren said , the 1st , 2nd , 5th and reverse gears are spring loaded when coming from the nuetral position . Go ahead , try it ( With car not running , clutch pedal depressed , and emergency brake engaged , just to be safe ) . From the nuetral position , move your shifter to the right as if you want to go to reverse ( don't pull the shifter down into reverse ) . Now let go of shifter . See how it returns to nuetral . If you pull your shifter straight down from nuetral , you will be in 4th gear . If you move your shifter straight up from nuetral you will be in 3rd gear . As Loren said , it will become second nature very quickly .
^^ She drives an auto.
Welcome javagirl! |
resident senior
details , details
Metsu
Drives: NCP91 ; E36 Join Date: Oct 2008
I wish it did that for the manuals as well. That part of the dash is so empty. Sometimes I need to be reminded that I'm already in 5th gear or I'm still rollin in 4th haha.
#9 | |
I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
Most of the time now I'm used to it and can tell by feel what gear it's in (even with the short shift kit) Rather then the lights, I would prefer a tach!
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
| October sale on TWM Performance shift knobs! | TWM Performance | TWM Performance | 1 | 10-31-2008 05:01 PM |
| Fog lights and shift knobs | flip_yaris | Cosmetic Modifications (Exterior/Interior) | 3 | 10-20-2008 05:36 AM |
| 2nd to 3rd gear shift (manual tranny) | tekmoe | General Yaris / Vitz Discussion | 13 | 12-11-2006 06:27 PM |
| Shift knobs with lights? | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 0 | 09-20-2006 04:09 PM |
| Shift gear knob | Jfoofoo | Cosmetic Modifications (Exterior/Interior) | 9 | 09-11-2006 12:20 PM |
