Old 05-20-2009, 11:53 AM   #1
regal
Drives: 09 Yaris 3 Dr White LB
Anyone else have trouble running off the road?
My other cars you could take your hand off the wheel a good 5 seconds, not the Yaris. I calaculate 0.5 seconds before hiting the ditch and it was just perfectly aligned, not sure I like the electronic steering.
regal is offline   Reply With Quote
Old 05-20-2009, 11:57 AM   #2
Astroman
Modded Moderator
Astroman's Avatar
Mine does fine. More likely road conditions NOT the elec. power steering.
Old 05-20-2009, 12:00 PM   #3
voodoo22
Drives: Yaris Sedan (auto)
...or you need an alignment.
voodoo22 is offline   Reply With Quote
Old 05-20-2009, 12:09 PM   #4
Astroman
Modded Moderator
Astroman's Avatar
...or put down that six pack
Old 05-20-2009, 12:38 PM   #5
regal
the alighnment is perfect. The roads are rough, I don't drink .
Old 05-20-2009, 12:42 PM   #6
33OH
Drives: '08 Yaris
I know what you mean Regal. Mine is aligned and does the same thing. I think it's the poor roads + the wind.
Old 05-20-2009, 12:48 PM   #7
regal
With the TRD suspension the car is such a go-cart it is a thrill to drive, but you got to stay on it. No searching for cigs, or candy stashes while driving.
Old 05-20-2009, 12:56 PM   #8
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
could be due to electric steering..
Old 05-20-2009, 01:22 PM   #9
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
see post #2
Old 05-20-2009, 01:24 PM   #10
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
what are your alignment specs, wheel and tire specs please...
Originally Posted by xnamerxx
you nailed it sir.
Old 05-20-2009, 01:25 PM   #11
marcus
toyota
marcus's Avatar
let me go back in time...**chaching*..
Old 05-20-2009, 01:48 PM   #12
SailDesign
Drives: .
Sounds like you're white-lining. Lower the tyre pressure a bit and see if that helps.
Old 05-20-2009, 01:54 PM   #13
ham
ham's Avatar
Drives: 2007 Yaris Hatch 5-Speed
Uhhhh, if you are not going to have at least one hand on the wheel, stay off of my roads.
ham is offline   Reply With Quote
Old 05-20-2009, 01:56 PM   #14
33OH
Drives: '08 Yaris
I'm saying when I open a drink, etc. It's hard to let go of the wheel without having to grab it quick in a second.
Old 05-20-2009, 02:08 PM   #15
regal
alignment specs 5-18-09
lf
camber -.1
caster5.1
toe .09
rf
-.8
4.3
-.06
lr
camber -.5
toe .26
rr
-1.3
toe-0.05
front total toe 0.15
steer ahead 0.01
rear totaltoe .21
thriust angle 0.16
Scion 15x6 7 Spoke Wheels with brand new Champiro 328 195-55-15, TRD Springs, Tokico Blues, TRD rear Sway Bar
Down the highway hands off the wheel runs straight. Its when speeding up from a stop or turn that you really got to watch it.
Old 05-20-2009, 02:21 PM   #16
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I wouldnt worry about it as long as it tracks well in a straight line,
Off the line or coming out of a corner will not be the best circumstance to rely on your alignment to keep the car tracking straight as torque steer and inertia may be a factor.
Old 05-20-2009, 02:26 PM   #17
Tamago
Tamago's Avatar
Drives: ZZW30
lf
camber -.1
caster5.1
toe .09
rf
-.8
4.3
-.06
lr
camber -.5
toe .26
rr
-1.3
toe-0.05
steer ahead 0.01
rear totaltoe .21
thriust angle 0.16
the reasons you have the problem have been highlighted.
your car is on VERY hard tires, and is going down the road sideways. pay an alignment guy to 0 those numbers out for you.
also, pick up some camber bolts 15mm (can be found on jegs.com for a resonable price) and have the guy get you some decent -1.5deg camber up front. you'll love the handling.
you can adjust the rear toe with very thin shims of brass, to get rid of that toe issue, or maybe loosen the rear axle and hit it with a hammer lol.. gotta love crap rear suspension (i hate mine)
you nailed it sir.
Old 05-20-2009, 04:21 PM   #18
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I agree with Tomago. You might think your alignment is good, perhaps because some tech told you it was "within spec"... but it's not good at all.
Your front toe is probably okay, the wheel just wasn't centered when they took that reading (that, or you're driving around with a cocked wheel). Your front camber sucks. When I do driveway alignments, I try to at least get within 1/4 degree from left to right. When I PAY somebody to do it on an alignment rack, it better be within .1! And, like Tamago said, you want some negative camber for best handling.
Your rear alignment is completely screwed. There are no adjustments back there, which means you've bent something. (or your alignment tech set the rack up poorly, or the rack is out of calibration) Rear camber should be .9 and rear toe very near zero or less than .1 toe in from the factory. With the beam axle suspension, that doesn't change due to ride height.
That last spec, the "thrust angle" of .16... that's the angle that your car is pointed at when you're going straight. Like Tamago said, you're going down the road sideways.
HELP! I changed a speaker while the car was running and now I hear nothing! dccurrent In Car Entertainment + Electronics (audio / video / alarm) 12 04-08-2009 07:44 PM
CFRC *Central Florida's new Road Race Track* Sabretooth Southeast 1 01-19-2009 07:17 PM
Road Trips ubetiam General Yaris / Vitz Discussion 5 05-08-2006 10:37 PM
