#19 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
#20 | |
i sell the washers. but it's not really worth it to ship you a set. it's a stainless washer, 1/2" inside diameter, and "thin".. most are .058-.064" thick. if you bought a set from me i'd grind them to clear the yaris hub and match pairs to not cause any undue toe in-out issues. $8 shipped for enough washers to yield -3 degrees rear camber (which i do not suggest)
#21 |
Sounds good. Let me ask, what's the advantage to going with a 20 offset over a 40?
#22 | |
wait, what wheel do you think it looks like?
#23 | |
and IMO will look a lot better, bring those wheels out to the fenders, no more sunken battleship status
#24 |
Ah, sounds good then. Let me find a pic of the wheel I'm referencing.
#25 |
Different, but it's what came in my head when I saw it.
#26 |
the RAYS wheel is closer to the scion wheel than the team dynamics is..
5 spokes vs 7 spokes vs 12 spokes wait.. scion + ggames = team dynamics!
#27 |
Yeah I know, it's just what popped in my head when I saw it.
Those wheels are an awesome price for what they are, I just love the Rewind styling. I'll get the +20 offset though now, thanks a ton. I still want a 195/50/15 though.
#28 | |
if you have access to a bench grinder, you can modify a set of washers rather easily. just make sure to buy stainless. if you end up going +40 rewinds, remember, hub spacers are available! ;)
#29 |
Do you need camber bolts for the front and back?
And I'll just buy a set of washers from you, isn't that what you were suggesting? ($8 shipped for enough to add -3) |
#30 | |
you'll want to install both at your local alignment shop. i suggest not mentioning what you're doing to the service writer, and wandering over to the alignment tech, slip him $10 and ask him to install them
#31 |
Do you know of any DIY's or pictures of the process? I'd want to do it myself to learn what I'm doing.
#32 |
Who said Yaris was slow?
IF the reason you are changing wheels is because of your Long comute you should also consider that the 195/50 tires will change a bit the OE gearing ratio. You will be cruising at higher revs than you normally do and fuel economy might got hurt.
That is IF Fuel economy over your comute is a concern... If not you might actually enjoy the shorter ratio.... |
#33 |
![]() ![]() ![]() Drives: yaris Join Date: Oct 2008
get some minilights in 15x9 XD i dunno if they have 4x100. Thatd be interesting tho...
http://www.minilitewheels.com/products.htm
ballin on a budget. |
#34 |
he's already not going to spend $109 each lol
#35 |
it will be identical to the hub spacer diy.
#36 | |
| Tire rotation: Does TPMS recognize tire position? | jcdrotos | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-17-2011 03:00 PM |
| Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? | St_G | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 03-16-2011 07:29 AM |
| Higher Tire Pressure | captainm27 | General Yaris / Vitz Discussion | 46 | 01-27-2009 11:17 AM |
| Tire diameter list | grampi | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 06-04-2007 05:03 AM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 08:09 PM |
