#19 |
TRIM HUNTER
i just like that ghost logo......
#20 | ||
![]() ![]() ![]() Drives: ings 09 Yaris 3 Door LiftBack Join Date: Mar 2009
I dont have time this week, I'm kinda busymay be Next week~ Quote:
, however, Malaya1121 told me he tried to unplug all of them from the stock seat and plug back in, but still uesless
REAL JDM ings+1 Full Body Kit…REAL JDM C-One Spoiler…Retrofit Projector Headlight…Kiddo 6-pots BBK…CE 28N J-Time Attack…Bride Ergo II Racing Seat…Personal Steering Wheel…Work Bell Quick Release…Dealer Option Sun Roof…JDM RS LED Side Mirror…JDM RS Taillight…C-One Oil Cap…C-One Radiator Cap…TRD Iridium Racing Spark Plug…Tom's Fuel Map Controller…Blitz throttle controller…GReddy Informeter Touch…MR Suspension…TRD Rear Sway Bar…MR C-Pillar Bar…GTspec Front Strut Bar & Rear Strut Bar…AFE Intake…WR Header…Nitto Mid-Pipe…Greddy Ti-C axleback…Goodridge SS Brake Line… To do: Supercharger… |
#21 | ||
![]() ![]() ![]() ![]() I'm plaining to cover surface of the whole part with CF Sticker, of just unplug the light... But I really want to find a way to by-pass the air bags signals tho ![]() Quote:
![]() ![]() But if I can by pass the airbag signal, I can get back my steering wheel & A pillar air bag
#22 |
I still have the decal if you want them, $10 shipped to you.
#23 |
H8R
Great looking seats. Your car is coming together nicely.
As for the airbag light, you should be able to undo the clip on the back, or just cut the wires. Either way.
#24 |
Yeah, I guess I have to undo the clip and call it a day, haha.
#25 | |
If you move the sensors over, you also have to move the Occupant Classification ECU, which is located under the front of the passenger seat. There is a calibration that a Toyota Tech can do with the Techstream tool to zero-out the system. Looking at the service manual and EWDs I believe you can bypass the sensors by supplying 0.2 VDC to the SIG1, 2, 3 ,and 4 terminals (on the 4 connectors that plug into the 4 Occupant Classification Sensors). Connector U1-U4: Conn U2 - Occupant Classification Sensor (Front LH).jpg Pin 1 - SVC Pin 2 - SIG Pin 3 - SGD PassOCCSensor.jpg The normal operating range for SIG is 0.2 to 4.7 VDC. If you connect up the 4 sets of resistors, theoretically the light should stop flashing (and I believe that this will be the Passenger Airbag Off mode). If the passenger airbag is on with the resistors in place, flip the 10K and 470 ohm resistors so that the 470 is connected from SVC to SIG and the 10K is connected from SIG to SGD. The service manual doesn't indicate if 0.2 V is empty seat reading or if 4.7 V is. Last edited by CTScott; 08-05-2009 at 11:30 PM. |
#26 |
![]() Drives: 06' Scion xB Join Date: Mar 2009
Bump for a killer old thread...any solution for this? I know Micro Image used to sell a bypass but they are long gone. Thanks!
#27 | |
When you have a passenger, you turn it on and when they plug their seat belt in, lights stop flashing and everything works as intended. When you're riding alone, you flip the switch the other way to disable the occupancy sensor on the passenger side and no more airbag or seat belt light flashing. It's an absolute must have for anyone with aftermarket seats. It works for multiple Toyota vehicles since so many use the same passenger occupancy sensor., which is a nice cherry on top. |
| Clazzio Seat Cover DIY Install | PETERPOOP | DIY / Maintenance / Service | 31 | 09-10-2010 03:30 PM |
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 06:42 PM |
| Possible Group Buy.. Racing Seats, Intakes? | TinyGiant | Items for Sale by private party | 60 | 09-11-2009 02:40 PM |
| Rostra seat heater and lumbar support | sesmith | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 01-03-2009 08:51 AM |
| 12/20/08 Buddy Club USA 5th Anniversary Clearance SALE | DuckinOut | California | 3 | 12-18-2008 12:25 AM |
