Old 05-21-2009, 03:24 PM   #217
IsLNdbOi
IsLNdbOi's Avatar
Thanks guys. I'll give this a try when I get the new trim piece.
IsLNdbOi is offline
Old 05-21-2009, 03:36 PM   #218
IsLNdbOi
IsLNdbOi's Avatar
This pic should work for now.
It may have been blind luck that I was able to achieve the exact amount of movement required for my JVC HU.
So the way you mounted it, the HU is attached to each bracket with only one screw?
IsLNdbOi is offline
Old 05-21-2009, 04:43 PM   #219
No, 2 screws in each bracket.
WeeYari is offline
Old 05-22-2009, 12:57 AM   #220
Adriaan
In between cities
Adriaan's Avatar
Drives: 2006 yaris ce
Received it two days ago but doesn't work with my two single din setup. The radio & the bottom cover pocket are 182mm. I could cut the plastic to get the radio to open but as in the picture, the bottom cover is wider so that wouldn't open. So now I may have to get rid off it, if i can't think of anything after the weekend its gone. I wanted one so badly and i can't use it now. Here a pic of my setup so if anyone else has the same the 180mm radio trim wouldn't work.
Adriaan is offline
Old 05-22-2009, 01:08 AM   #221
IsLNdbOi
IsLNdbOi's Avatar
Seems like none of the Pioner / Pioneer Premier head units fit properly in this double din trim piece. I wish Pioneer would create proper double / single din width head units.
IsLNdbOi is offline
Old 05-22-2009, 01:49 AM   #222
MGargano
Drives: 2009 Yaris Hatchback
It will fit if you trim the double DIN trim accordingly. I have the Pioneer AVH-P4000DVD which has the same weird face trim piece as yours and I made it work perfectly after a few trips back and forth to the garage to use the dremel tool.
MGargano is offline
Old 05-22-2009, 01:53 AM   #223
IsLNdbOi
IsLNdbOi's Avatar
Trimmed mine as well. A little bit at a time. Had to trim so much to get my P8000BT to fit that by the time it was trimmed enough, you could see the jagged edges I "trimmed" using my dremel. I posted a picture earlier in this thread.
IsLNdbOi is offline
Old 05-22-2009, 08:07 AM   #224
How about pushing the headunit in deeper, per WeeYari's instructions above? The HU should work that way. The question is if the door on the pocket will fit within the trim.
CTScott is offline
Old 05-22-2009, 03:52 PM   #225
By the way, I have an extra set of brackets.
If someone doesn't have to tools, or doesn't understand the grinding process to move the HU deeper, so the trim piece will fit with wider HUs, I can modify the set that I have and ship it to you in exchange for your set.
CTScott is offline
Old 05-22-2009, 09:12 PM   #226
Adriaan
In between cities
Adriaan's Avatar
Still doesn't work due to the cover it the same size as the pionner unit. Because of pionner stupid din size i had to trim the double din metra brackets so it could fit. Guess i'm stuck with the 200mm opening. Unless i change the cover pocket to an open version. But then i'll have items out in the open which i don't like.
Adriaan is offline
Old 05-23-2009, 05:13 AM   #227
IsLNdbOi
IsLNdbOi's Avatar
How do you grind the positioning stubs? Will a dremel w/ a sanding head do it?
All I have to do is grind down all of the positioning stubs on the sides of the bracket that face the head unit, right?
IsLNdbOi is offline
Old 05-23-2009, 07:48 AM   #228
I used a file to remove the stubs. Dremel will work as well. The metal is very soft and easy to remove.
Yes, all you have to do is eliminate all 6 stubs on the HU side of the bracket.
WeeYari is offline
Old 05-23-2009, 01:05 PM   #229
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
I used one of those big spinning stone griding wheel things.
Sodium Duck is offline
Old 05-26-2009, 07:05 AM   #230
IsLNdbOi
IsLNdbOi's Avatar
Finally got it in. For my Pioneer I used my dremel to grind down all six of the positioning stubs. Then I moved the brackets forward until the top front hole was over the front-most screw hole for Toyota mounting points on the Pioneer HU. The top rear hole is now over the hole where the top rear positioning stub used to be.
In this mounting position, I use one of the original mounting bracket screws for the front hole and a short, self-tapping screw for the rear hole (the one that used to be for the positioning stub):
This is the best I could get it. The front bottom edge of the HU is flush / right up against the bottom edge of the new trim piece. The front top edge of the HU is further back so there's a small gap between that top edge of the HU and the top edge of the new trim piece. I'll have to cut the top edge of the stick on bezel that the Pioneer HU came with so I can stick that to the top edge of the front of the HU. Should take care of that gap.
With this new trim piece and the way I had to mount the HU, the HU now sits further back so it's more recessed. I like how this looks.
Scott, I still need another one of these trim pieces. One of my friends has asked me to install a new HU in his Yaris and he wants me to get one of these for him. Please keep me on the list for your next possible group buy.
IsLNdbOi is offline
Old 05-26-2009, 09:30 AM   #231
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
^nice pic. find your screw lol!
808_Yaris is offline
Old 05-26-2009, 11:42 AM   #232
One is for sale here in Toronto.
http://www.yarisworld.com/forums/showthread.php?t=18204
WeeYari is offline
Old 05-26-2009, 11:49 AM   #233
I have a small gap at the top of mine which I was able to minimize to nearly un-noticable.
There is a small amount of up/down movement of the HU that can be realized via the 4 screws securing it to the dash assembly. Holding the HU in place with the 4 screws slightly loose, try sliding it up and down. You should notice that you will be able to raise the HU about 1/16".
Give it a shot.
WeeYari is offline
Old 05-26-2009, 11:12 PM   #234
IsLNdbOi
IsLNdbOi's Avatar
I tried re-positioning the HU. Loosened the four screws holding the mounting brackets in then pushed up on the bottom of the HU to raise it as much as possible. While holding it up, I tightened the screws. Helped a little bit, but the gap was still very visible. So, I took that plastic trim pieces that comes with the HU and cut it up so all I had left was the piece that goes along the top edge of front of the HU.
Looks better now:
IsLNdbOi is offline
Dash destroyed in electrical fire. purpleminx General Yaris / Vitz Discussion 79 06-12-2009 04:53 PM
[Recovered] Group Buy for Australia #1 (Badges) harveyjai Australia 9 12-13-2008 04:59 PM
