Old 05-24-2009, 12:32 AM   #271
MGargano
Drives: 2009 Yaris Hatchback
Thanks... will try that on my next day off.
MGargano is offline   Reply With Quote
Old 05-24-2009, 12:36 AM   #272
MGargano
Now that the head is totally shot, should I replace the original screw with something else?
Old 05-24-2009, 01:03 AM   #273
jkuchta
Drives: 2007 Yaris hatch (red)
Yes...take it to ACE and get a standard metric allen socket head cap screw (I think it's an M3 diameter with .5mm thread pitch...but I'm not 100% sure). I think you'll want something about 40-50mm long.
jkuchta is offline   Reply With Quote
Old 05-24-2009, 11:24 AM   #274
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
remind people thats gonna do this to play around with that screw before to put it on!!
Old 05-26-2009, 10:58 AM   #275
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Originally Posted by jkuchta View Post
And eii, if you want to go for a ride in a yaris with the 1zz tb install that was done correctly, PM me.
Oh I was just kidding, hehe . I based my install on the guide post you made earlier in this thread (thanks btw) so I'm sure I did it correct. I just get that < 1 minute 2.5k-ish cold idle start. Other than that it works great, I was just wondering what happened to demon. I just did the coolant bypass this morning, its more responsive and I definitely feel some more power. Cool stuff
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 05-26-2009, 01:10 PM   #276
jkuchta
Right on!
Old 06-04-2009, 10:20 AM   #277
MGargano
I finally adjusted the idle screw and haven't got thrown a CEL yet and the start-up oscillation appears to be gone, but now the engine does a weird thing at idle. The RPMs drop very low (around 400) and the car starts to shudder like it's gonna stall out, then the engine revs itself up to about 1,500 RPM for a second. It keeps doing this over and over until I finally turn the car off for fear it's gonna stall. It's even worse when I'm idling with the A/C on. Also getting some jerkiness in the pedal when it enters DFCO.
Old 06-05-2009, 11:00 AM   #278
jkuchta
turn the screw clockwise a half turn with the engine off. That should make it better. Also, if a half turn isnt enough, keep turning in half turn increments (with the engine off).
Old 06-06-2009, 01:23 AM   #279
MGargano
I gave up on the 1ZZ for the 2nd time. No matter how many turns I gave the idle screw, after a while the engine would settle back down to around 500 RPM, shake/shudder, rev up to 1,000 RPM, and then repeat the process until I either started moving or turned the car off in frustration. I hate all the problems I'm having since the performance of the the 1ZZ really is noticeably better than OEM, but I can't take the way it idles. I was also getting the heavy jerking whenever I took my foot off the gas.
Old 06-06-2009, 12:54 PM   #280
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
you might have gotten a bad throttle body. maybe you should order the one through cali yaris.
Old 06-06-2009, 01:39 PM   #281
MGargano
I don't think it's that, since the TB was working perfectly until I disconnected the battery. I wasn't getting any oscillation, jerking, weird idling, or CEL... then I pulled the battery cable and all these problems came out of the woodwork. I might try the swap again down the road sometime. Where can I get the Micro Image one? I don't see it listed on his website. Is it new or used/refurbished?
Old 06-07-2009, 01:17 PM   #282
jkuchta
It's a 1zz TB, with the Yaris chip module already swapped on...also, we remove all of the epoxy on the idle set screw and make a preliminary adjustment to get you in the ballpark.
Old 07-05-2009, 01:37 PM   #283
PETERPOOP
PETERPOOP's Avatar
finally installed my 1zz tb after months of it sitting in my room. no CELS. warm idle at 2500rpms, then within seconds drops to 2k rpms, and then idles smoothly at a warm idle of 585 rpms. Didn't adjust the idle screw, and I didn't switch the chips; I think i've lucked out....
Drove the car after and ran it hard and conservatively, no problems! niceee
edit: Still running good. I don't really notice an increase in power? I remember looking at Yoda's dyno sheet that he did after he added the 1zz TB, and he got a gain of 3 whp. Unless I got less of a gain, I can't really feel 3 whp added to the existing. However, if the car keeps running with no problems for a couple of weeks, I plan on taking it to get dyno'd. Now that I have my 1zz injectors, I will be able to successfully do three pulls and hopefully hit 140whp now with the 1zz TB! :)
Old 07-17-2009, 09:16 PM   #284
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Originally Posted by echo_hrs View Post
I got my TB yesterday & cleaned and polished it...I need to go get a coupler for the intake to TB, is it a 2.25" - 2.5" I need?
Anything else I need for the swap?
I'm thinking I'll just do the straight swap like PETERPOOP and see what I get before swapping chips...
Cheers
I just did this swap today and Its feels a lot stronger. I was able to make my aem coupler strech over the corolla tb .
you'll also need either 6 rivets and a rivet gun or 6 x small bolt and nuts for the "chip swap "
Old 07-19-2009, 05:25 PM   #285
jkuchta
I used 6-32 allen head cap screws and jet nuts on mine. Makes for a realy clean job and the jet nuts are self-locking, so no worries about the screws coming loose.
Old 07-20-2009, 08:56 PM   #286
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
where the hell did the diy go?
Old 07-20-2009, 09:26 PM   #287
PETERPOOP
PETERPOOP's Avatar
t-sport is at it again; deleting everything he posts. i wouldn't think he'd delete this!
Old 07-20-2009, 09:27 PM   #288
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
why did he do that?
mikenacarato is offline   Reply With Quote
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
