![]() ![]() ![]() Drives: Polar White Yaris HB Join Date: Dec 2008
1ZZ Throttle+Bomz intake=Power!
I installed the throttle body I got from Garm. Instead of the stock intake, I used a Bomz intake - I just could note get the stock rubber intake tube over the new throttle body. The Bomz silcone intake adapter was a breeze. Install was not very hard at all - just a pain in the ass to get to the wheel well to get the filter on. While I was down there, I decided to pop out the black plastic insert where the fog light goes just to see if a bit more cold air will make a difference.
Wow! Power/torque in the whole PM range with the most prominent gain in the mid and upper ranges. I had only a bit of mild oscillation on the initial start up and no problems since. For the price, this is a MUST mod. Interestingly my exhaust sounds louder. It is not coming from the front as I expected. Just make sure you follow all the instructions on the website, gasket sealer is a good idea, disconnect the battery for a while(only did mine for 30 min and left the light switch on) I will modify the L foglight plastic insert into something more cosmetically pleasing. I will also change the silicon to black and paint the intake tube flat black. ![]() ![]() ![]() :burnrubbe r:
![]() ![]() ![]() ![]() Drives: 07 Blazing Blue LB Join Date: Jun 2007
hey brian, I actually got an idea for that foglight cover. Remember I told you I was trying to work on something for it? well I think I got it figured out. After I actually do the process I'll let you see it maybe at the meet or something.
Most Satisfying Crew Serious Business... MunkyWurks Garage - 8088488794 |
Where is Oahu?
looking good
アキバ製
Drives: 09' White LB, Celica GTS Join Date: Apr 2009
very nice thinking about doing this after I pick up your springs and exhaust. ;)
I dont know what the hell my issue was, but with this EXACT combination of TB (chip swap) and intake, I could NOT get it to idle at all, and throttle response was non-existant.
Im thinking about starting again with the throttle body from garm, as I dont know if mine was damaged or what. |
^ it wasnt damaged. well at least for 2 days i didnt feel anything besides the retarded oscillation.
^ what I got wasnt the 2-3k rpm oscillation that others got, I got 4-5k oscillation and the chip swap made no difference, however I do not believe I had a good seal on the Tb and intake mani
The other thing I have noticed is much quicker throttle response. I am glad I never got a Blitz Throttle controller!
![]() ![]() Drives: 06 Toyota Vitz RS Join Date: Apr 2009
I have been think about the two mods trying to decide on which to do, but on your note it will be the tb swap. thanks
| Installed the 1zz throttle body - | AlexNet0 | DIY / Maintenance / Service | 135 | 08-01-2014 07:57 AM |
| Possible Group Buy.. Racing Seats, Intakes? | TinyGiant | Items for Sale by private party | 60 | 09-11-2009 02:40 PM |
| 1ZZ throttle - Not Optimized Yet! | fuji | Performance Modifications | 30 | 06-04-2009 12:40 AM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
