Old 11-13-2008, 10:40 PM   #55
hey look who it is -- the builder himself!! welcome to YarisWorld man!
Old 11-13-2008, 11:11 PM   #56
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
Thank you! im just poking around seeing whats the talk of the today is
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 11-13-2008, 11:12 PM   #57
Treyz
~ ambient one ~
Treyz's Avatar
Garm, let me know whn you're gonna ship it out to me.
Coming out great!
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 11-13-2008, 11:30 PM   #58
dallas
Drives: Yaris Hatch /Landrover D2
That's some pretty impressive engine machining and port work. What machine shop did the work and specifically the sleeving to allow for the oversize pistons? Could this be the work of Cosworth! Have you increased the valve size at all ? I better let you go so you can go knife edge the crankshaft LOL Keep us posted on this great project!
dallas is offline   Reply With Quote
Old 11-14-2008, 05:46 AM   #59
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
i want details garm. who did the block/headwork? where did you get the pistons? We all want details on how to build a 300 WHP Yaris.
Old 11-14-2008, 06:19 AM   #60
gboezio
gboezio's Avatar
Drives: Yaris 4dr 2008
Don't forget the high volume fuel pump and bigger lines, clutch and axles.
Damn thick sleeves, are these Aluminium/Nikasil or ductile iron, by the color I'd say iron ?
One thing for sure is that engine and management is built to see up to 30 psi of boost, I don't have much details on the construction of the Yaris engine and drivetrain, I just hope it's strong enough to live behind a monster like this.
Thumbs up for the build and keep the pics coming :D
gboezio is offline   Reply With Quote
Old 11-21-2008, 09:58 AM   #61
Abodame99
Drives: Silver 07 LB
hey cali, what do you plan on doing after you put the built motor in? i say you put slicks on it and try to get 10 sec
Abodame99 is offline   Reply With Quote
Old 11-21-2008, 10:22 AM   #62
Exedy Stage I clutch (very stiff)
Fortified axles from Drive Shaft Shop
fuel system will be upgraded as needed. in-tank pump would be preferable.
I have drag wheels and slicks for it, but I doubt it's a 10 second car. Getting into the 11's would be thrilling, never done it.
Old 06-07-2009, 02:14 PM   #63
Brad D
Drives: 07 Yaris RS 3dr
Do you guys have good luck with the twin fire? mine died in my S14 in just a few hours.. then I swapped in a DIS4 wire for wire they plug in the same.. But I like the Twin fire better for its smaller has less BS on it that the AEM takes care of any way.. and it can be triggered falling edge or rising edge.
Brad D is offline   Reply With Quote
Old 06-07-2009, 04:09 PM   #64
have had mixed results with the coils. They were arcing, which we fixed with heatshrink (but shouldn't have to do that IMO). One has popped off so far, might need a bracket to really hold them down there solidly. Overall, ok, not fantastic, but the car is running real nice at 9.5 psi right now. Built motor swap is the next step, after I drive it a little bit.
Old 06-07-2009, 04:38 PM   #65
Brad D
if you get the CBR coils (can be had for 50# a set on ebay) the plugs you need to use must have a screw off top, and the coil grabs on that thread.. but its hard to find good plugs that are like that, I run IK24's in my car.
Also if you cant fix the spark issues why not try the factory coils? they are a smart coil no? if so the AEM can run them direct with no ignitior or spark box (twin fire ect)
cool setup the car should fly... what do the 3drs weigh in at?
Old 06-07-2009, 05:41 PM   #66
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
I didn't think a stripped block could look sooooooo beautiful!
Old 06-07-2009, 09:30 PM   #67
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
Awesome job so far garm, can't wait to see the finished product, you gunna be selling custom built engines now on micro image ;-) ?
id3379 is offline   Reply With Quote
Old 07-06-2009, 11:14 PM   #68
areithan1980
areithan1980's Avatar
Drives: 2007 Yaris Hatchback
he should:) then i'll have another thing to save up for :P great car btw! garm
areithan1980 is offline   Reply With Quote
Old 07-15-2009, 10:07 AM   #69
Derek3CE
Vitz!
Derek3CE's Avatar
Drives: 2005 Echo 3dr HB
Cali,
Do you know how much the cylinder bore was increased by? I know the stock is 75mm; I'm just wondering how much it can be opened up by before risking thin walls on the stock iron sleeves.
2005 Toyota Echo CE Hatch
-- GTSpec strut tower brace & front chassis under brace, Tanabe rear under brace, Progress 22mm rear anti-sway bar, Energy Suspension front poly anti-sway bar bushings, 16x7 MB Boost wheels, 205/40R16 Toyo Proxes 4, JDM power mirrors, Tein SuperStreet coilovers w/pillowball mounts, TRD Quickshifter (using stock weighted shift knob) --
Derek3CE is offline   Reply With Quote
Old 07-15-2009, 11:53 AM   #70
I do not know if specs like that are made available to everyone, but I will ask. It's a small motor, there's not a lot of thickness there to play with as you said.
I think it's about a 1.6L now.
Old 07-19-2009, 04:40 AM   #71
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
so beautiful... So you are taking this thing cross country for a grand tour when it's done so us poor mid-westerners can witness this beast in person, right? I'm not sure if the wife will let me drive cross country to come see it. Seriously, you inspire all of us. I cannot wait until it's done... Are you still thinking about using the paint job I suggested?
Old 07-19-2009, 08:58 AM   #72
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
Garm , i love your boost controller !!
all this turbo goodies got me thinking of turbo'ing my 1.3 2nzfe with the greddy turbo kit. anyone got in experience or info regarding issues with a bolt on kit like that ?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Yaris from New Zealand model - some differences to Canadian RS Yaris model Super_BQ General Yaris / Vitz Discussion 0 07-23-2007 03:54 AM
