Old 06-06-2009, 11:30 AM   #325
PhilD424
Drives: Red Yaris
http://store.summitracing.com/partde...5&autoview=sku
-Phil
PhilD424 is offline   Reply With Quote
Old 06-06-2009, 12:45 PM   #326
Originally Posted by PhilD424 View Post
The cost of that kit is exactly why we looked for a cheaper route. Looking at the installation instructions for it, it actually does the cruise control itself, as opposed to using the Yaris's built in functionality.
Old 06-06-2009, 11:24 PM   #327
lunjiaow
lunjiaow's Avatar
Drives: Yaris
Well i pulled apart my dash on the 07 Australian Delivered Yaris, to find there is no CCS blue wire from the ECM to the AD4 Plug. Unless i got it wrong but there was a blue wire on the bottom row which i doubt was the CCS wire.. Very disappointing.
lunjiaow is offline   Reply With Quote
Old 06-07-2009, 03:40 AM   #328
PatrickJohnson
Drives: 2008 Yaris LB
You can run one very easily. It took me literally 20 minutes to install this from popping the hood all the way through to drive testing. And i had to run a wire.
PatrickJohnson is offline   Reply With Quote
Old 06-07-2009, 07:55 AM   #329
lunjiaow
lunjiaow's Avatar
Drives: Yaris
Ah yes. i saw on Page 16... will give it a shot tomorrow.
Old 06-10-2009, 11:38 AM   #330
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
i have read most of this thread looks cool and cheap for cruise control . so on my early 08 lb automatic i can use the oem stock and what else do i need ? please help i put ton of miles on my car and cruise would be way nice to have for cheap
pennyracer is offline   Reply With Quote
Old 06-10-2009, 12:35 PM   #331
mrbond
mrbond's Avatar
^ you need wires going from the ECM to the little hub in the steering wheel column, a wire going from that hub to a ground point, and the stalk, and then a jumper wire for two pins in the engine bay. Everything's been outlined and explained, so you just need to read carefully. That's about it. I'm selling my stalk btw, since I just don't really want it.
- A Toyota Yaris
- A whut Yaris?
Old 06-10-2009, 07:46 PM   #332
pennyracer
boydstir
pennyracer's Avatar
cool thanks for the input
Old 06-11-2009, 11:54 AM   #333
petyanca
Drives: 09 LB, 3 door, auto
So it should work ..
I have 09 3 door liftback, and it seems all I need is a stalk. Could someone give me a link to where you got the stalk ? Thanks a lot for the investigating this !
petyanca is offline   Reply With Quote
Old 06-11-2009, 12:03 PM   #334
regal
Drives: 09 Yaris 3 Dr White LB
If you have a clutch you need the clutch switch, the part number is in this thread
regal is offline   Reply With Quote
Old 06-11-2009, 02:34 PM   #335
Either ebay ($12.99 + $17 shipping):
http://cgi.ebay.com/ebaymotors/TOYOT...lenotsupported
or TRDSparks.com ($81.99 plus shipping):
part number: 84632-34011
Old 06-18-2009, 01:46 PM   #336
menz
Drives: yairs blue 2007 automatic 1.3
i am going to try this soon as i get bk home next month i have 07 yaris i just hope ull all b here to ask for my questions
menz is offline   Reply With Quote
Old 06-18-2009, 02:15 PM   #337
I don't think it will work on your car. On European manufactured Yaris cruise control is not an OEM option, so the ECM doesn't support this mod.
Old 06-20-2009, 08:00 PM   #338
Prisonguard
Drives: 5 door hatch
Ok, after reading all these posts I am now REALLY confused so please bear with me since I am also new here. I have an '09 S 5 door liftback, auto trans. In real simple terms since I am not an electrical engineer, what do I have to do to have the factory cruise installed. The dealer wants over $500 for an aftermarket one which is ridiculous.
Prisonguard is offline   Reply With Quote
Old 06-20-2009, 09:26 PM   #339
With an 09, you can simply purchase the OEM cruise control stalk (Toyota part number: 84632-3401), pull the steering wheel and install it, and you'll have cruise control.
Or, check out this thread for adding cruise to your 09 auto for about $10:
http://www.yarisworld.com/forums/sho...ght=diy+cruise
Old 06-22-2009, 03:04 PM   #340
Henry G.
Drives: 2008 Yaris HB
Just to confirm after reading 24 pages.....this will work on an '08 MT but you need the stalk, the clutch switch and need to do some wiring to the fuse box, correct?
Henry G. is offline   Reply With Quote
Old 06-22-2009, 03:13 PM   #341
Correct. We really need to do a DIY for 07-08's...
Old 06-22-2009, 05:14 PM   #342
Henry G.
That would be AWESOME. Thanks for all the info so far guys, great job.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
