Old 06-12-2009, 02:28 PM   #37
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Ok the math is back where we started...
here you go:
http://www.summitracing.com/parts/WIL-120-6818/
4 piston Wilwoods for $125ea
PD: Garm, I'm getting a discount for the idea... lol
Old 06-12-2009, 07:14 PM   #38
fuji
fuji's Avatar
Drives: Polar White Yaris HB
The Wilwoods appear to be reasonable in price - how difficult would it be to get these to work properly with our pre-existing brake system?
I hope whatexer comes about from this, it will fit in my 15" Enkei RPF1s.
fuji is offline   Reply With Quote
Old 06-12-2009, 08:14 PM   #39
pretty sure these will require larger rotors, so your 15's are going to be iffy.
Old 06-12-2009, 08:47 PM   #40
darthbauer
Not really here...
darthbauer's Avatar
+1! 15's and BBK's do not go together.
Liberate Tutemet Ex Infernis.
Old 06-13-2009, 12:08 AM   #41
fuji
fuji's Avatar
Oh well, I guess I will have to keep on looking. Perhaps some nice strong Camry calipers!
Old 06-13-2009, 11:33 AM   #42
mrbond
mrbond's Avatar
Unless it's the mini or micro bbk by Project Mu :P Then you can run 13 and 14" wheels
- A Toyota Yaris
- A whut Yaris?
Old 06-13-2009, 11:59 AM   #43
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
ok unless i didnt read thoroughly... excuse me, alright wilwood does have a 4pot brake kit for the yaris, so does endless.. unless you guys are talking about someone else?
Its a Chao!!!
Old 06-13-2009, 12:05 PM   #44
mrbond
mrbond's Avatar
^ this is true, however you're going to be paying big big bucks for something you can piece together yourself for less.
- A Toyota Yaris
- A whut Yaris?
Old 06-13-2009, 12:06 PM   #45
TheRealEnth
Beast
ah kk
Its a Chao!!!
Old 06-15-2009, 12:35 AM   #46
SEVEN
Drives: 07' HB Black
yeah thats what I read at the microimage store .... minimum 17's ... what can I do to add the most braking power with 15's????
thanks in advanced
When life passes you by ... dowshift
SEVEN is offline   Reply With Quote
Old 06-15-2009, 02:23 AM   #47
For braking power, which means to me resistance to fade and stopping distance:
pads + lines + fluid
Old 06-15-2009, 10:00 AM   #48
kngrsll
Apexing Egg!!
kngrsll's Avatar
This should be done before anyone even considers any brake job. Big brake kits have their place, but if you haven't done this set yet, how do you know you are using the full capacity of the braking system??! now cars that carry more weight (not us), race for hours on end (definately not us lol), or carry alot more speed (turbo cars, some of us!) could use more brake material.
Do you guys know the purpose of a big brake kit? no big brake kit will make you stop FASTER. The brakes are limited by the grip of the tire. What is the best brake upgrade then? TIRES!!! if you can lock up your tires while braking, the brakes are at FULL stopping capacity!! Does this make sense?
So why do people do big brake kits? well, i know i did it bc i thought it would make me stop faster, but i learned better. What a big brake kit really does is allows you to absorb more heat!! brakes are heat sinks! If you are tracking and using up all your brakes, and they cant cool quickly enough, you need to increase the air to them, or increase their heat capacity. So you can use more metal, or ducting. So big brake kits have a significant advantage in heat capacity, and that is ALL. that is their only advantage. They typically weight more (unsprung none the less), which slows you down if you are not overheating your stock brakes (doubtful.) They also cost alot. That money would be better spent at a track school and autoxes where you learn to drive what you have FASTER and then you are quicker no matter the car or equipment you own.
The list garm just posted will satisfy 99% of the braking needs for guys on this forum. I have tracked my car, autox'd it, and have had no brake issues (with stock pads and fluid with 60k miles on them!!) The car is so light, they are gentle on the brakes. This car is very easy on its brakes. In fact, i would almost worry that some of the high end temp pads that carbo tech offers through micro image could be tough to keep heat in! I may test this at the next event, do brake temps during a 20 min session and see what they peak at.
Now a rear disc upgrade, i would do that. Drums suck.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 06-15-2009, 10:15 AM   #49
+1 and well said
Old 06-15-2009, 10:19 AM   #50
vten
+2 ,
bbk for me is for the look purpose, since I'll be using 19" very very soon.
Old 06-17-2009, 12:45 AM   #51
SEVEN
I knew that brake capacity is only as good as the tires you use but this made things even clearer!! THANKS A LOT!!
Old 06-17-2009, 01:38 AM   #52
kngrsll
Apexing Egg!!
kngrsll's Avatar
good! glad to help!
Old 06-17-2009, 01:48 AM   #53
meanwhile, back to this idea. These calipers are way too thin for the Yaris rotor. I have now matched a 4-pot Wilwood caliper to the stock Yaris rotor and ordered a set. Did I mention I'm a Wilwood dealer now? heh. next is the brackets (one for stock + one for oversized rotors), then lines, and we are good to go.
Old 06-17-2009, 01:56 AM   #54
vten
Garm,
which wilwood 4 pot are you using ?
put me on the list for the oversize setup ....
Tan
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 09:24 AM
Rear disc from xD or new xB kngrsll Performance Modifications 20 04-01-2009 07:17 PM
Rear disc brake conversion installed Brian Performance Modifications 49 03-05-2009 12:45 AM
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 07:13 PM
