Old 05-20-2009, 05:56 PM   #1
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
KSport springs too soft, need stiffer
I have Ksport coilovers on my car right now and the spring rates are way too soft for my drop and as such I rub all over the place. Off the shelf spring rates are:(in kg/lbs)
Front: 4/224
Rear: 2.2/123
Ksport rep on the phone said he can sell me front springs at 6 or 7 kg but is unsure of the rear new springs are $40 a piece. I'm mostly concerned about the front. Anyone know where I can get stiffer front and/or rear springs from? Loren I remember you swapped your rears out but I don't remember you saying from where.
Here's a reference shot of my car
Almost flush with the top of the tire in the front and a one finger gap in the rear. Please don't suggest raising the car, because I'm not.
- The Spectacle
The Spectacle is offline   Reply With Quote
Old 05-20-2009, 06:18 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I swapped my rears for some Tein springs I had on the shelf, not a perfect fit, but it works well enough for me.
Looking at the photo, your front tires are going to rub no matter what. I won't bother suggesting that you raise the front an inch... but that's what you need to do.
You have less than 1/2" of clearance before the tire rubs. To prevent that with spring rate, you'd need enough rate to keep the added weight of at least .9 G on that corner from blowing through your 1/2". The car weighs about 2500 lbs with you in it, 60% of that is in the front, divide by two... that's 750 lbs on each front corner. 90% of that (.9 G) is 675 lbs. 675 lbs/half inch = 1350 lbs/in or about 24kg/mm. Good luck with that.
You could go full stiff on the front shocks, that will greatly limit their movement under most circumstances. It won't be comfortable... but neither would 24kg springs.
You might try a little more negative camber in front to get the tire more inside the front fender. You'll probably still rub the fender liner, but it will wear through in short order.
Old 05-20-2009, 07:19 PM   #3
The Spectacle
Drives: 08 BSP LB
I don't have much fender liner left and at this point lol. As for the rubbing, now that I have such little liner left its actually not aall that bad and I've pretty much gotten used to the rubbing that occurs on certain turns. But, the car still sways too much for my taste so I'm hoping a little more spring rate + turning the shocks a turn or two will get me where I want to be.
What car did you Teins come off of?
Old 05-20-2009, 08:20 PM   #4
Loren
What?
Loren's Avatar
Get a bigger rear swaybar and run the shocks as stiff as necessary to eliminate the body roll. They will do it.
The Teins springs on the rear of my car are from a Miata Tein Flex kit. The rates were what I wanted, but the springs are physically not at all "correct" for the rear of the Yaris. They make all kinds of noise back there scraping against the adjustable perch and banging and clanging, but they get the job done.
Old 06-06-2009, 08:21 PM   #5
The Spectacle
Drives: 08 BSP LB
Between my original post and last week, I made a few twists toward stiff on the coilovers both front and back...made a significant difference. I was definitely underdamped. The car is a lot more stable in turns and takes bumps in the road with a lot better composure. I'd still like to update the springs though, here's what I got from Ksport:
sorry for the late delay, i have been out of the office. but here are your options for spring rate changes, let me know what you thinkg
Front: 11.5-205, 7.5kg or 11.5-180, 8.7kg
Rear: 12.5-65-73.5-180, 4.5kg
Thanks,
Nick J.
Ksport Suspension Company
info@ksportusa.com
The rear spring rates are a little confusing. Can anyone make sense of them for me and make a recommendation?
Old 06-06-2009, 11:40 PM   #6
order some coilover springs from eibach...
onlineconversion.com is pretty good for imperial-metric #'s
Old 06-06-2009, 11:45 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
k sport offers different spring rates.
but the best solution is eibach race springs.
Old 06-07-2009, 03:23 AM   #8
ddongbap
http://swiftsprings.com/
Truly legit springs.
Old 06-17-2009, 12:21 AM   #9
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
What size are your wheels ?
id3379 is offline   Reply With Quote
Old 06-17-2009, 01:19 AM   #10
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
looks stupid, raise it.
Old 06-17-2009, 02:39 AM   #11
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Drives: 2008 Yaris LB
_________________________________________________
Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers
Jeemee is offline   Reply With Quote
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 09:37 AM
Rim Weights bosbik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 11-14-2009 07:42 PM
What springs should I get? Help! CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 01-26-2009 07:32 PM
Is it practical to install stiffer shocks without also installing lowering springs? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-18-2007 02:23 PM
