Old 06-21-2009, 11:29 PM   #1
detroiter
detroiter's Avatar
What causes wheel gaps to be uneven?
I was checking my wheel gaps today to see how things are since the lowering springs and shocks have been installed for a while now. It seems like two of the gaps were much shorter in distance as compared to the others being a bit bigger in gap size. I can't imagine any reason why it would be that way since they've had time to settle and the air pressure is even in all tires. I did hit a monster sized puthole the other day but as far as I can tell it didn't throw the alignment off at all so I have no idea what could be the reason it's uneven. My only guess is maybe just the pavement has to be completely smooth and flat to get an "even" look all the way around?
Old 06-21-2009, 11:56 PM   #2
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Which sides are you comparing? Front to back, or left to right?
If front to back, then the rear gap usually is smaller in all cars because it doesn't arch as high as the front (from what I've always seen).
Old 06-22-2009, 12:13 AM   #3
detroiter
detroiter's Avatar
I'm comparing left to right. I noticed that the one side that is lower, the opposite side in the rear is also lower at the same time. That's what's leading me to believe it's just the pavement not being even or whatnot. The car itself looks perfectly flat and level, not funky leaning or angles.
Old 06-22-2009, 02:37 AM   #4
YarisSedan
Drives: 08 Yaris Sedan
More weight of the vehicl eis on that side such as battery.
Old 06-23-2009, 02:35 AM   #5
As mentioned, the battery and intake are on the left side, as well as the driver and steering parts. My sub is also on the left side, so I wouldn't be surprise if my left side is a bit lower.
Old 06-23-2009, 03:22 AM   #6
SilverBack
Joey
SilverBack's Avatar
That and driving without passengers adds more weight to the left. I would take right turns much more slowly if I were you lol
Official YARIS Wheel & Tire Guide Black Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 403 08-10-2025 12:20 AM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 02:41 PM
Steering Wheel Issue. Twistoffate0817 General Yaris / Vitz Discussion 8 01-31-2009 08:38 PM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
Yaris wheel rate ratio (06+) ? dsc_pat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 07-05-2007 06:43 PM
