Old 06-22-2009, 02:09 PM   #37
Tamago
Tamago's Avatar
Drives: UZJ100
yup, you're in the clear! :)
Old 06-22-2009, 02:16 PM   #38
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
ill pick it up this weekend..
Old 06-22-2009, 05:22 PM   #39
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
OK. I'm throroughly confused. Where does what go where?
Referencing firebob's picture (red square, green square):
RED SQUARE --> hose --> FILTER --> hose goes to where?
GREEN SQUARE --> hose goes to where?
Old 06-22-2009, 05:40 PM   #40
marcus
toyota
marcus's Avatar
red
Old 06-22-2009, 06:00 PM   #41
firebob
Drives: 09 yaris
LOL we have a new run at this fad.
I will say there was one point that I was close to installing on at one point but decided that pulling the hose off the fitting every oil change I could feel for my self without having to modify stuff.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 06-22-2009, 06:56 PM   #42
marcus
toyota
marcus's Avatar
huh? dont you just need to empty the plastic case anytime you want ofcourse b4 it gets full..
Old 06-22-2009, 10:43 PM   #43
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
what?
Old 06-23-2009, 12:40 AM   #44
saplaymate
saplaymate's Avatar
Drives: 08' HB
http://www.autoshop101.com/forms/h63.pdf
0 - 60 in 3 shifts
saplaymate is offline   Reply With Quote
Old 06-23-2009, 01:30 AM   #45
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Thanks for the link... Do we have a PCV valve on our car?
So the filter goes between the crank case and hose that connects to the intake pipe that's between the throttle body and air cleaner?
Old 06-23-2009, 08:27 AM   #46
firebob
Drives: 09 yaris
If you look in the RED box off the pic I posted you can see the threads of the PCV valve.
If you look at the link that saplaymate posted the Yaris is set up like the second pic of the motor.
Old 06-23-2009, 09:28 AM   #47
another related mod that I have not yet seen anyone do, you can replace the atmospheric pressure hose (the one on the front) with a little breather filter. Absolutely no advantage over the stock setup (and you'd have to plug the hole in the intake tube), but it looks pretty cool
Old 06-23-2009, 10:00 AM   #48
Tamago
Tamago's Avatar
Drives: UZJ100
http://www.jackstoolshed.com/index/p...parator+Filter
would work nicely IMO. allows you to catch and release any oil that passes thru
Old 08-24-2011, 01:36 AM   #49
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
sorry for the thread resurrection....but has anyone used this crankcase breather filter? any advantages or disadvantages?
goliath1812 is offline   Reply With Quote
Old 08-24-2011, 06:47 AM   #50
CB900F2
Drives: 08 Sedan
Hi Morgan.. Can you post a recent photo of the filter?.. Wondering how much oil has been captured by the filter since new.
Thanks
Originally Posted by Morgan View Post
After disassembling my supercharger the last few days I didn't notice any oil in the charge pipes or in the manifold assembly, but to make myself feel better I got a $2.99 see through fuel filter and installed it in the PCV line. When/If it fills up its cheap to change and saves valuable space in the tiny engine bay. Here's a picture:
CB900F2 is offline   Reply With Quote
Old 09-02-2011, 06:49 AM   #51
CB900F2
Drives: 08 Sedan
Anyone have any before and after photos of their catch can???
Old 09-05-2011, 10:48 PM   #52
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
my catch can...... (right side)264875_10150707523060637_581315636_19617224_7928335_n.jpg
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 03-11-2012, 08:49 AM   #53
CB900F2
Drives: 08 Sedan
Bump for Morgan
Thanks
$30 Oil Catch Can, DIY Ogredude DIY / Maintenance / Service 79 05-13-2011 11:05 AM
perrin oil catch can staypuft Performance Modifications 3 11-16-2008 12:20 AM
OIL CATCH TANK increase performance? 33lam Performance Modifications 29 11-11-2008 01:08 PM
