Old 06-27-2009, 10:04 PM   #1
tambasher
tambasher's Avatar
Drives: 2009 Yaris Liftback
Just installed K&N CAI
I spent the extra cash and installed the K&N Typhoon CAI the day before on my 09 Yaris and today the check engine light came on. Does anyone know why this happened since K&N claims that it shouldn't? BTW I thought the car got loud with the TRD Sport Exhaust, but now when you stomp the gas it gets really loud and throaty. Really cool!!
tambasher is offline   Reply With Quote
Old 06-27-2009, 10:31 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Check all the hose clamp's and connections for air leak's.
Old 06-27-2009, 10:52 PM   #3
tambasher
tambasher's Avatar
did that, all is tight
Old 06-27-2009, 11:32 PM   #4
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
check the maf sensor you probably got a little dirt on it.
Old 06-28-2009, 08:56 PM   #5
tambasher
tambasher's Avatar
Checked K&N website for support and it suggested that the difference in air density caused the check engine light to trip and to clear the light and wait and see if it comes back on. So, I cleared the light and so far it has not come back on after a day of running errands.
Old 06-29-2009, 10:33 AM   #6
JapRulezz
JapRulezz's Avatar
Drives: yaris sedan 2NZ-FE
just to be sure , does the heat shield ' s hole have a bigger diameter then the pipe
or is it just mine ??
JapRulezz is offline   Reply With Quote
Old 06-29-2009, 03:09 PM   #7
tambasher
tambasher's Avatar
Yeah, the hole is bigger. It needs to be since the engine/tube moves and the shield is stationary. Otherwise someting would break during acceleration, but I am no expert.
Old 06-29-2009, 10:08 PM   #8
tambasher
tambasher's Avatar
Light came back on today, on the way home from work. Thinking I wasted my money. I need to check with K&N tech support.
Old 06-29-2009, 10:39 PM   #9
06silveryaris
Drives: 2006 yaris
that really blows, i bought a chepo ebay for $50 had no issues. Is the diameter the right size? just seems like quite a few people with these overpriced intakes have had some cel issues. I am sure it happens to the chepo ones to but I guess you don't expect from the quality brand parts.
06silveryaris is offline   Reply With Quote
Old 06-30-2009, 11:25 AM   #10
tambasher
tambasher's Avatar
Which diameter, the filter itself? What cel issues? I should have researched this a little better.
Old 06-30-2009, 12:19 PM   #11
06silveryaris
Drives: 2006 yaris
the diameter of the pipe itself
Old 07-01-2009, 12:51 PM   #12
JapRulezz
JapRulezz's Avatar
this may sound stupid but isnt the K&N SRi designed for sedans only ?
Old 07-02-2009, 07:15 PM   #13
tambasher
tambasher's Avatar
I have the CA no SR version. The kit came with a reducer so that the pipe would fit on the carb. K&N website states that the CA fits all.
Old 07-02-2009, 07:22 PM   #14
tambasher
tambasher's Avatar
I talked to a K&N tech and he said that it could take about 100 miles before the ECU will adjust for the increased air flow. He also said that because this model, Typhoon, is new that the state has yet to test it so it will pass smog. It can take up to 2 years before all the paper work gets done and then they will send me the sticker which allows it to pass the smog test. This is a visual fail only at this time, not a emissions fail.
Old 07-02-2009, 10:25 PM   #15
06silveryaris
Drives: 2006 yaris
Sounds like a lot of BS from kn I mean its just a air intake.
Old 07-03-2009, 02:43 AM   #16
Creeper
Creeper's Avatar
Drives: Silver 2DLB Yaris
Send a message via AIM to Creeper
did you disconnect the battery after installing it? my dragon throws cel when swichting from stock to sri without resetting the computer. after i disconnect the battery for about 15 mins its fine.
Creeper is offline   Reply With Quote
Old 07-03-2009, 08:16 AM   #17
MUSKOKA800
MUSKOKA800's Avatar
Does K&N state that system is compliant with the 2009 Yaris?
Last summer K&N told me that the Typhoon was only certified up to the 2007 models and that if installed on my 2008 the warranty wouldn't be honored as they had not yet verified/tested it on the 2008 models. Honestly, I'd be surprised if they have tested on 2009's already. And yes, the 2007 LB and sedan applications were identical.
Old 07-03-2009, 09:12 AM   #18
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
'nother reason why I am glad that I went with the AFE, plus it is cheaper. Best of luck.
installed the K&N SRI on my 1.3 sedan :) JapRulezz Performance Modifications 2 06-27-2009 11:27 AM
Divorce sale: Fujita CAI $125, bixenons $140, NST crank/WP pullies $85, 17" wheels Carvin'07 Items for Sale by private party 32 05-11-2009 10:42 PM
just installed cai....but... SweetRS Performance Modifications 6 05-05-2009 07:09 PM
TRD CAI & TRD Qiuck Shift Polar Items for Sale by private party 7 08-02-2007 06:03 PM
Installed K&N Drop in. Motorhead6T5 Performance Modifications 3 06-18-2007 08:11 AM
