1NZ-FE
i need to clean a little bit the engine bay
but here are a few new mods (thanks Garm)Engine Damper ![]() ![]() NST Short Shifter in cabin (not yet installed) ![]() NST Shifter Cage and Cable Bushing Kit (not yet installed cuz there is one ring missing (already bought it)) ![]() ![]() today i will take better pics... pics not posted engine bay ssk, new front grille (09 one) painted and installed, and the eyelids (need to paint and install them)
. ![]() DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
1NZ-FE
Engine Bay NST Short Shifter
![]() new smile for my car =) seddan 09 grill installed![]() ![]()
![]() ![]() ![]() Drives: Yaris Hatch /Landrover D2 Join Date: Jun 2007
So what are you running in the quarter mile?
1NZ-FE
XBL: Jeemee Ghost
_________________________________________________ Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
wait..... none of those mods are really going to help you in the 1/4 mile. You didn't add any power
#7 | |
1NZ-FE
i know i will not get such an animal in the track but it has to be better than my 16.39s i did last time (considering that the track here doesnt have grid)
#8 | |
So what are you running in the quarter, with the current mods?
The new "no horsepower" mods won't help make it faster only smoother but Im still interested what you end up running. Your shifting is only as fast as your clutch engagement, the short shifter won't speed you up! trust me ![]() Quote:
#9 | |
1NZ-FE
![]() Drives: 2007 Vios (Yaris Sedan) Join Date: Oct 2008
does the 09 grill have the exact same size that it fits with no problem? I'd like to get one also :)
I dont get it.
All the torque damper does is cause more engine vibration to get to the chassis, and all it does is allow you to feel the engine kick into each gear, and what will that do? Annoy most people, and it will NOT make your car faster as the torque is never changed! Ugh what a gimmick I swear. I mean if you do a lot of shifting, then I guess having the torque get to the ground 0.3? seconds faster is worth it? |
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
if you have ever owned a five speed car and dumped the clutch the hop you experienced is supposed to be diminished with the torque damper. DON"T KNOW CAUSE I DON"T OWN ONE! the shifter piece does infact shorten throws but as to its effect on actual shifting of gears is debated.I OWN ONE AND RECOMMEND IT TO ANYONE FOR ANY EASILY INSTALLED MOD......
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
#14 | |
Who said Yaris was slow?
Unless you have dropped your clutch on first gear at 4,500rpm then you probably haven't. A torque damper should help control the wheel hop. From the OP's signature banner you can tell our friend actually takes his car to a drag strip. (wheter the Yaris is fast or not is not the point here) Anyone who has ever been on a Drag race would be able to tell you what 0.3 seconds mean. At 80+ MPH it means around 2 car lenghts. |
#15 |
^ +1.
engine torque dampers are not a gimmick. Sorry Lafiro you're incorrect on this one. Do you also think stiffer motor mounts are a gimmick? http://www.ingallseng.com/stiffy-benefits.html
#16 |
so, to be faster in the 1/4 it would be recommended to learn how to operate the clutch and gears over spending money?
#17 |
the cure to wheel hop in the yaris would come mostly from a semi-solid lower dogbone, not a shock absorber bolted to your strut tower ;)
curious, what keeps the torque damper from just bending the metal of the strut tower inward, since the "chassis" mount does not triangulate? unless i'm missing something in the picture? edit, finally saw what they're doing in the second pic.. my bad.. get a semisolid dogbone mount next!
#18 |
I just got some TRD hard rubber rollstoppers in from Japan. don't have pricing yet, but this will pretty much eliminate engine movement.
| Dash Kit - No Mods | barryware | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 09-14-2014 03:59 PM |
| Suggestions for $300-$400 worth of mods please! | CtrlAltDefeat | Performance Modifications | 51 | 01-05-2011 09:15 AM |
| Mods on an automatic sedan? | naix | Performance Modifications | 19 | 12-10-2009 10:30 AM |
| Mods Please Read! Regarding Paint Topic... | silaypalmer13 | General Yaris / Vitz Discussion | 30 | 05-10-2009 05:31 PM |
| Performance mods that won't affect/will hardly affect gas mileage?? | Mr.Yaris | Performance Modifications | 15 | 07-30-2007 12:32 AM |
