Old 07-08-2009, 05:42 PM   #19
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Does TRD makes dogbones for the Yaris? I know they had the other mounts.
Pictures please!!
Old 07-08-2009, 06:22 PM   #20
ChinoCharles
Drives: LB
First time to the track I missed second 4 times out of 12 or so runs. My theory is that the engine was bucking around too much and throwing the linkage out of alignment. After installing the damper I got from Garm I only missed second once in 12 runs. Not bad on a stock clutch.
So yeah, the torque damper does help, both with getting power to the ground and keeping your cables where they ought to be.
Old 07-08-2009, 06:40 PM   #21
@Castrex:
TRD Rollstopper:
TRD motor mounts:
I have various other TRD bushings I also received for the Yaris.
Old 07-08-2009, 07:02 PM   #22
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
that's a gorgeous part Garm. i find it sad that "TRD" went to all the effort but didn't do urethane inserts though :(
Originally Posted by xnamerxx
you nailed it sir.
Old 07-08-2009, 07:11 PM   #23
YarisSedan
Drives: 08 Yaris Sedan
hmmmm i want these ic ant stand how much engine movement our cars have. I thought i had a broken motor mount and had another tech in my shop check while i pushed on the gas witht he foot on the brake. but no our engines just have that much excessive movement because of the crappy mounts.
Old 07-08-2009, 07:21 PM   #24
Tamago
Tamago's Avatar
Drives: ZZW30
it's the dogbone mount that's the problem. an "engine dampener" is a band-aid IMO
you nailed it sir.
Old 07-08-2009, 07:26 PM   #25
t0m4s
1NZ-FE
t0m4s's Avatar
Drives: Yaris Seddan 08
Originally Posted by ammophobia View Post
does the 09 grill have the exact same size that it fits with no problem? I'd like to get one also :)
yes it fits perfectly without problems
what are you talking about! the 09 grill adds like 50 horsepower
LOL the grill part is just an extra bro
DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
t0m4s is offline   Reply With Quote
Old 07-09-2009, 01:24 PM   #26
YarisSedan
yeah but a quick and easy bandaid that looks cool under the hood. Priced about the same as replacing the dogbone mount.
I would consider changing the dogbone but one that is not too sollid. Kinda a middle ground.
Old 07-09-2009, 06:53 PM   #27
Tamago
Tamago's Avatar
Drives: ZZW30
ahhh
yes. the reason it's purchased most of the time any. car show points lol.
you nailed it sir.
Old 07-09-2009, 07:18 PM   #28
CASTREX
CASTREX's Avatar
I just picked up a TRD dogbone from Garm!!
Is cheaper than the urethane beatrush one and I hope it will provide a mild improvement over the stock bone...
I've read reviews about the full urethane one and accoridng to a couple of people it was a bit to hardcore for every day use.
Old 07-09-2009, 07:38 PM   #29
I'm putting one in my car too. More ordered and on the way -- I intend to stock a bunch of TRD mounts and bushings.
Old 07-09-2009, 10:37 PM   #30
YarisSedan
please post reviews of the trd mounts once they are installed i may have to put this on my list of mods to get
Old 07-09-2009, 10:59 PM   #31
Yarold n Kumar
Yarold n Kumar's Avatar
Drives: 2009 3dr lb
I see you're smoking a tiburon in the photo. Did you actually beat it down the track?
Yarold n Kumar is offline   Reply With Quote
Old 07-10-2009, 11:37 AM   #32
t0m4s
1NZ-FE
t0m4s's Avatar
yep it was a stock V6 tiburon
Old 07-10-2009, 11:58 AM   #33
Tamago
Tamago's Avatar
Drives: ZZW30
guy must not be able to drive then.
you nailed it sir.
Old 07-10-2009, 12:40 PM   #34
severous01
Originally Posted by dallas View Post
So what are you running in the quarter, with the current mods?
The new "no horsepower" mods won't help make it faster only smoother but Im still interested what you end up running.
Your shifting is only as fast as your clutch engagement, the short shifter won't speed you up! trust me
i gained .4 seconds by adding tires, control arms, and a lightweight driveshaft to my camaro...so dont tell me that a 'no HP mod' wont take time off your quarter.
Old 07-10-2009, 12:40 PM   #35
arcticvitz
arcticvitz's Avatar
Drives: Base 09 White Yaris 3DR 5MT
Send a message via AIM to arcticvitz
Kind words once again form Tamago!
Proud to purchase parts through
arcticvitz is offline   Reply With Quote
Old 07-10-2009, 01:19 PM   #36
Tamago
Tamago's Avatar
Drives: ZZW30
never said anything unkind about the OP did i? ;)
you nailed it sir.
Dash Kit - No Mods barryware In Car Entertainment + Electronics (audio / video / alarm) 8 09-14-2014 04:59 PM
Suggestions for $300-$400 worth of mods please! CtrlAltDefeat Performance Modifications 51 01-05-2011 10:15 AM
Mods on an automatic sedan? naix Performance Modifications 19 12-10-2009 11:30 AM
Mods Please Read! Regarding Paint Topic... silaypalmer13 General Yaris / Vitz Discussion 30 05-10-2009 06:31 PM
Performance mods that won't affect/will hardly affect gas mileage?? Mr.Yaris Performance Modifications 15 07-30-2007 01:32 AM
