Old 07-13-2009, 04:42 AM   #1
ibizagti
Drives: Yaris 5door D4D
Help. Instability on highway
Hello from Spain.
I´ve a '08 Yaris D4D with 6x16" rims (from a Corolla TS) and 195-50-16 tyres (Toyo Proxes T1R). Stock suspension.
The problem is that in highway driving over 60millas, the car is very hard to keep straight. It affects the state of the road, wind and even the air to the advancement of other cars. It is very uncomfortable.
Do you think that putting Eibach springs with stock shocks will be better?
What alignment should be better for highway?
Thanks very much!!
PD: this is my car
ibizagti is offline   Reply With Quote
Old 07-13-2009, 05:48 AM   #2
JustAnotherAsian
now in HD
Drives: not yaris!
Send a message via AIM to JustAnotherAsian
assuming you're still on stock/oem suspension, a straight oem-spec alignment is best for the highway. make sure to get well within specs for toe especially.
a bad tire+wheel balance would contribute less to your problems, but i'd check that too.
JustAnotherAsian is offline   Reply With Quote
Old 07-13-2009, 05:53 AM   #3
ibizagti
Yes, I have oem suspension.
The weight of my 16" are the same of the oem in 15".
The car is only 25.000kms (about 15K miles)
Thanks!
Old 07-13-2009, 05:58 AM   #4
JustAnotherAsian
now in HD
Drives: not yaris!
Thanks!
yes. start with the alignment first. it's relatively inexpensive considering it affects so many variables, including tire wear.
Old 07-13-2009, 02:38 PM   #5
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
TRD rear sway bar. End of story.
Old 07-13-2009, 02:43 PM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
I don't think there is anything wrong with your Yaris that we haven't all experienced at highway speeds.
Old 07-13-2009, 03:51 PM   #7
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
Drop the car, add a bar, it helps lots
Its a Chao!!!
Old 07-13-2009, 04:05 PM   #8
Lewis
Our off road vehicle
Lewis's Avatar
Drives: 2009 Yaris 3dr
the TRD rear bar helped my car's stability very much on the highway- with everything else stock
Lewis is offline   Reply With Quote
Old 07-13-2009, 05:20 PM   #9
ibizagti
Yes, I think that TRD sway bar will help me. Tomorrow will pay a new one from ebay... :D
Thanks!!!
Old 07-13-2009, 06:07 PM   #10
extra chapter to the story: Ultra Racing sway bar for $30 less.
Old 07-13-2009, 07:15 PM   #11
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
check your tire pressures. virtually free.
also, if you DO opt for an alignment, have the tech err on the side of toe-in up front (while still maintaining factory specs) if you want the car to handle better at higher speeds.
Originally Posted by xnamerxx
you nailed it sir.
Old 07-14-2009, 03:47 AM   #12
ibizagti
I was running 38psi in front and 36 rear. (in other cars usually have this tyre pressures and all ok)
Few weeks ago, I put 29psi rear and front and the car goes a little better.
Thanks very much!
Old 07-14-2009, 03:58 AM   #13
yaris 2sz
www.yarisclub.gr
yaris 2sz's Avatar
Drives: yaris 1.3 2sz - 1.33 1nr
put 32psi and the springs.
yaris 2sz is offline   Reply With Quote
Old 07-14-2009, 11:53 AM   #14
MUSKOKA800
MUSKOKA800's Avatar
My thought exactly.
It makes a world of difference (huge stability and handling improvement).
Old 07-16-2009, 08:37 AM   #15
ibizagti
Hello guys!
Finally, I bought an Ultra Racing Rear Sway Bar (19mm) and a set of rear hub spacers (10mm)
When I install them, I told you the results :D
Thanks!!
highway speeds and noise gaf99 General Yaris / Vitz Discussion 26 04-20-2012 12:36 AM
Considering Yaris vs. Elantra businezguy New YARIS Purchase Forum 69 06-21-2009 09:39 AM
Highway driving SuperYaris123 New YARIS Purchase Forum 15 05-08-2009 02:22 AM
Take the long way home on the highway or short trip home through city? tinymilad General Yaris / Vitz Discussion 10 12-27-2008 01:23 PM
