Old 06-07-2009, 12:23 PM   #127
Originally Posted by daftcain View Post
I'm probably going to do this mod soon and I'm about to gather what parts I need. I'll probably go with the mounted two button method, and since I have an 07 3-door HB auto, I'll need to run a wire through the firewall. This seems like it will be the same installation as Patrick Johnson (http://www.yarisworld.com/forums/sho...&postcount=101). I'll get the resistors/switches from digikey, where should I get the wiring and what gauges? Also how hard is it to feed a wire through the rubber hose and have it come out the other side?
The wire gauge isn't critical, as there is no current involved (we're just switching a signal input). I would go with between 22 and 18 gauge. You could purchase a small spool at Radio shack or Home Depot.
Feeding through the passenger side rubber boot is fairly easy. Poke a small hole, shove through a semi-rigid piece of wire, and then pull through your wire.
Old 06-11-2009, 12:35 PM   #128
bronsin
bronsin's Avatar
Old 06-22-2009, 11:59 PM   #129
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
Awesome install Patrick Johnson and bronsin! Looks just like mine. I'm glad this is working out for everyone :)
My Car Rules!
nickhjort is offline   Reply With Quote
Old 06-23-2009, 09:28 AM   #130
bronsin
bronsin's Avatar
How many have done the install? Many who see mine comment on the coolness. But an equal number say "You did WHAT?!"
PS I still have a set of four switches and the resistors to do this mod. $5 gets it mailed to your door.
Old 06-28-2009, 09:39 AM   #131
Bravejus
Drives: 08 Yaris 3 door 5MT
I just did this mod also, however i mounted my two button setup in the empty pop out panel next to the dimmer roller switch.
Bravejus is offline   Reply With Quote
Old 07-06-2009, 03:27 PM   #132
luigi
luigi's Avatar
Drives: '07 Sedan
Bravejus, i was thinking of mounting in the same place. Got any pics?
luigi is offline   Reply With Quote
Old 07-06-2009, 03:51 PM   #133
trialsdork
Drives: '09 liftback, '91 pickup
It worked! I mounted the buttons inside the coin tray as a trial, they're completely hidden. I also installed a mini-deans connector so that I can take the whole mess out in the event of a warranty problem. I think I'll relocate them to the empty removable panel next to the dash light dial soon, for user friendliness. THanks!!!!
trialsdork is offline   Reply With Quote
Old 07-12-2009, 06:01 AM   #134
solarVitz
solarVitz's Avatar
Drives: 08 Yaris S Liftback
wow, these really works guys? ive got to try these on my car now. i wonder if my 08 liftback S got the cruise control lights in the instrument cluster? will soon find out.
Old 07-12-2009, 11:09 AM   #135
PatrickJohnson
Drives: 2008 Yaris LB
it doesn't, the 07 and 08 don't have it, only the 09
PatrickJohnson is offline   Reply With Quote
Old 07-13-2009, 04:39 PM   #136
Blue_dragon_192
Drives: 2009 Yaris 4dr Sedan
Can I assume that this will work for the 09 Sedan also?
What dangers/issues do I need to be worried about doing this mod?
I have wires running all over from the LED mods so I am not worried about the work, just warranty issues.
Blue
Blue_dragon_192 is offline   Reply With Quote
Old 07-13-2009, 05:11 PM   #137
bronsin
bronsin's Avatar
As I understand it yes, the mod works for the 09 Sedan. Its just a matter of tapping into the two wires under the steering wheel and hooking them up to the four (or two if you prefer) switches with the resistors. With an 09 you dont need to be concerned with the ECM.
Old 07-13-2009, 05:27 PM   #138
PatrickJohnson
Blue
Just an FYI, the burden of proof is on the warranty provider to prove that any modification resulted in a failure of the component or part being warrantied. They can't deny a warrantly claim unless they can prove your modification caused whatever is broken.
Old 07-13-2009, 08:19 PM   #139
Blue_dragon_192
Well, my base model sedan is different
I guess I am screwed on this fantastic inexpensive mod.
Here are the pics I just took of my steering column.
As you can see, the brown and blue cables are missing.....so I think anyway.
Can someone confirm?
Circled the connector where I think the two additional cables should be:
Picture from the bottom of the steering column...
Blue
Old 07-13-2009, 08:31 PM   #140
That is correct. Looks like the 09 sedan doesn't have the wiring in place from the steering column to the ECM. Does it have the cruise indicators on the combination meter?
You're not totally dead in the water for this mod. You just have to do the 07-08 method, which involves running a single wire from the switches to the ECM. Take a look at the tail end of this thread:
http://www.yarisworld.com/forums/sho...cruise+control
Old 07-13-2009, 08:43 PM   #141
Blue_dragon_192
Yes it does have the cruise indicators, but they are way at the top of the gauge cluster.
I will look at the 07-08 section. Thanks for the input.
<-goes and mopes and grumbles about not having cruise control.
Old 07-13-2009, 09:13 PM   #142
Blue_dragon_192
ctscott,
one last question (for the next 30 seconds )
With the 07=08 mod, all we are doing to shorting pin 40 on the ECU to ground to turn on the CS and then short it to ground with a load (~600 ohms) to set the CS..
Or did I miss something?
Blue
Old 07-13-2009, 09:25 PM   #143
ctscott,
Blue
That's all that's to it. See if your sedan has a wire already in pin 40. If so, you can tap it way up under the dash (per the discussion buried in that thread), or at least tap it somewhere along the line.
Old 07-13-2009, 09:35 PM   #144
Blue_dragon_192
Ok. The next dumb question. Where is the ECM??????
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
