#55 |
SIPNDEW
well the negative terminal cant be taken off because of the strut bar being almost on top of it. ill have to tinker with it when i get home and dont have to be away from my desk for a long time. ill let you guys know later.
#56 |
You can try just popping the two ECM connectors.
#57 |
8380052P10 =$385.60
Instrument panel - Cluster and switches - Cluster assy - W/o abs W/s model - Hatchback 2008
Never take eyes off opponent - Bruce Lee |
#58 |
SIPNDEW
for a 2009 the hatches auto and manual share the same part #. and they all have ABS so the 1 part number i post for 2009 will fit all 09 hatches
#59 |
Here's one for auction right now! From an A/T Canadian model.
http://cgi.ebay.com/ebaymotors/TOYOT...Q5fAccessories
#60 |
╚══════════RN
That's a sedan cluster, won't fit hatchbacks.
#61 |
#62 |
SIPNDEW
IDK about swapping to a KPH cluster though. If it works then do it
#63 |
I have an auto + a scanguageII so I'm not messing with my cluster.
Thought a Canadian member might want it though.....
#64 |
SIPNDEW
here is another interesting fact about this swap...if you have had you seatbelt charm turned off by the dealer, you will have to have it turned off again. the programming for the charm is in the cluster.
#65 | |
Did you get a chance to try the ECM cold boot yet? |
#66 |
SIPNDEW
i have not. i got home from work at 1230am and had be be back in at 10am... :(
#67 |
SWEEEEEET! This question has been lingering for years.
| DIY Oil Pressure Gauge Install | LtNoogie | DIY / Maintenance / Service | 13 | 11-20-2009 04:13 PM |
| A-pillar gauge pod | Tonavi | Cosmetic Modifications (Exterior/Interior) | 26 | 02-26-2009 07:35 AM |
| Yaris safety pack - where is it located? | signs | General Yaris / Vitz Discussion | 5 | 02-22-2009 06:43 AM |
| A-Pillar gauge pods that can fit tweeters? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 9 | 11-23-2008 02:25 PM |
| Gauge Pod for Liftback? | eight_heads | General Yaris / Vitz Discussion | 2 | 06-07-2007 10:41 AM |
