#379 | |
By the way, I believe that you are the first Canadian trying this. For a ground, The bolt that you posted the picture of is a great ground point. You can strip about an inch of insulation off of the wire, wrap the wire around the bolt (under the washer) and crank the bolt back down. |
#380 |
![]() Drives: 2007 2DR Yaris Join Date: May 2009
Alright thanks for clarifying this point ! By the way in the meantime I tried to ground it on the battery with a wire going out the window without success... I verified if there was an internal resistance in my switches but there's none... I've been working on it (mostly making trials again and again) for more than 6 hours and I'm actually wondering if something is different on the canadian version !!??
#381 |
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Dec 2008
just to be clear, you know you have to have the resistors in place, correct? A simple grounding of the pin 40 wire will not trigger the cruise, you need those resistors wired to the switches...
#382 |
Yeah I know ! they're under the yellow tape on the 1st picture a few posts above... And I doubled checked for the value of the resistors with the color codes... I just cant find what I'm missing.
#383 |
okay, just checking :) Anyhow, I would suggest 2 things:
1) Double, triple, etc. check those resistor values. Do you have a multimeter? 2) Check the continuity on your switches (also with a multimeter). |
#384 |
What he said, plus make sure the switches are N.O., not N.C.
#385 |
I do have a multimeter, and get a 630 ohm reading when I check the resistance at both ends of the resistors with both switches pressed.
The switches must be N.O. because if I dont press on both I dont get any reading. It's the 1st time I'm using a multimeter how can I verify the continuity of my switches??? thanks again |
#386 | |
#387 |
My friend, you might have found my problem !
- When on/off is pressed i get a 530 ohms reading - When set is pressed, i get 624 ohms I have no idea why I get this 530 ohms reading... I might make another set of switches since I have 2 other swithes a lot of resistors... Last edited by Vince87; 07-20-2009 at 10:49 PM. Reason: wrong values |
#388 | |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
get 0 Ohms? Just checking to see that the meter is calibrated, which could throw off your readings. |
#389 |
Yes I did, my multimeter is brand new so its probably well calibrated...
#390 |
Did you get a chance to swap that switch out? If not, before you do, check the extra switches with the meter to make sure that they're OK.
#391 |
![]() Drives: 2007 Yaris Liftback Join Date: Mar 2009
All,
Thanks to all who have put so much effort into testing this mod. I performed the two switch mod to my wife's 07 Yaris HB with automatic trans. I used a single 670 Ohm resistor, ran the ECM wire on the passenger side through the fire wall where the rear window wash tube goes through and used the ground on the driver's side kick panel. I set up the switches for the two switch mode and before I drilled any holes, I soft wired everything in place and took a test drive. I could not keep myself from laughing as Dr. Frankenstein must have done... "It's alive! It's alive! I have Cruise Control for less than $10!!! Halleluhah!!!" Thanks to all for their testing and effort. The entire install took a couple hours but I was very careful about dealing with the ECM connector and the wire routing. Best of luck to all who give this a shot. It is well worth the effort. Nothing like an economy car with some of the whistles and bells of the high dollar land yachts. Best Regards, Wyo |
#392 |
To CTScott :
I did check the extra switch with the meter before doing the swap and they were ok (0 resistance when unpressed, high value (1) when pressed)... I did the whole setup again without anymore luck... I just dont get it... If I take the reading at the red and black wire heres what I get when the whole setup is plugged and car is on : - 0 ohms when nothing pressed (in an earlier post, you said I should get a high value, does that mean that my ground is still bad!?) - 649 ohms when on/off is pressed - 0 ohms when set is pressed In my understanding, in my circuit, pin40 is always grounded when the switches are untouched and is grounded with a load when I press on/off... The set switch has absolutely no effect. I dont understand what I'm doing wrong... Last edited by Vince87; 07-22-2009 at 08:03 PM. |
#393 | |
It looks like you have set and on/off reversed. On/off should be 0 ohms to ground and set should be 649 ohms. With how it's wired now, just try pressing the opposite switch and see if it works. |
#394 |
I've already tried that.... And the on/off switch I'm speaking is the one before the resistors and were the pin40 and ground wires are attached...
#395 | |
"I did check the extra switch with the meter before doing the swap and they were ok (0 resistance when unpressed, high value (1) when pressed)... " This indicates that the switches are the wrong type. They are normally closed, rather than normally open switches. Unpressed should be high resistance and pressed 0 resistance. |
#396 |
Wow ! I thought that normally open switches were "normally" allowing current to flow but it seems to be the opposite... sorry for that I should have checked by myself before... Thanks a lot
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 01:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
