Arm rest problem!!
I have a stock 07' Yaris Sedan. My arm rest doesn't stay down..as you can see in the 1st pic.. its opened and it always pops back up when i push it down. The problem is the hook on the top part doesn't grab the bottom part because the top part is pushed out and it stays like that like a mechanical umbrella that wont stay closed all the way. the 2nd pic, you can see the arm rest has a little gap.. thats what i need to somehow push back in and make it stay.. the 3rd pic is how the gap is supposed to look like..nice and tight. with a teeny gap. so the hook for the top part of the arm rest can grab the bottom. can anyone please help me with this situation? thanks!!!
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
I suppose I shouldn't comment, as I don't have an armrest, but I would think that there
is a hinge back under there. Perhaps you could check to see if there are screws that hold the hinge on and make sure they are tight?
Learn to Relax
Show us a picture of the hinge and latch. There maybe some adjustments you can make.
Here's the picture. Hope this is any help... ;/
Learn to Relax
Whatever is loose is not exposed. Look behind the armrest to see if there are screws you can tighten. If it is broken plastic, it will be a harder fix.
Scrubble with a poke.
Drives: 2009 Yaris LB Join Date: Jul 2009
The plastic latch is just worn out. Go to a local dealer and pick one up. Should be very cheap. More than likely under 10 dollars. Well worth the aesthetics to fix it.
"If you cannot find truth right where you are, where else do you expect to find it?" Dogen |
![]() There are 2 screws(maybe 4) in the cupholder behind the console lid. Remove those, and then pull the big piece of plastic on the back off. That should leave you with the above picture. Tighten the four screws in the top of the picture, and the four on the bottom of the lid at the bottom your picture I had this exact problem, and this fixed it perfectly. Here's how to assemble it: ![]() And these are the four screws you need to tighten:
#9 | |
Thanks a lot man! I'll be sure to try that out. |
#10 | |
WHOO thanks man it works!!! |
| FS: Lift Back Arm Rest | kenkyd | Items for Sale by private party | 5 | 04-09-2009 12:21 AM |
| Anybody installed the factory 2 door hatch arm rest? | firebird1999us | DIY / Maintenance / Service | 4 | 02-09-2009 02:52 PM |
| Center Arm Rest | Rotorheader | Items for Sale by private party | 12 | 09-27-2007 04:25 PM |
| Arm Rest | Big1Dave | General Yaris / Vitz Discussion | 10 | 09-12-2007 11:40 AM |
| Arm rest review | Chaad32 | General Yaris / Vitz Discussion | 36 | 09-19-2006 06:42 PM |
